Question about Refrigerators
Won't make ice - Refrigerators
  • 583 Answers
If the refrigerator is not making ice then it can be any of this 2 issues.
1)the freon gas (refrigerant) is gone low so not able to cool it till the freezing temprature so its not making ice.
2)the timer is faulty so its not defrosting the blogged tubes and not allowing the cooling required by the freezer to make ice.
in most cases its freon problem.it is advisable to get your freon pressure level checked by a tech initially.
thanks for using fixya.keep updated.
please do not forget to accept and rate this solution positively
Posted on Jul 01, 2009
Line clr60b wont stop making ice
http://www.aramislashes.com/wholesale-mink-eyelashes/wholesale mink eyelashes WHOLESALE MINK EYELASHES MANUFACTURER-ARAMIS LASHES Our wholesale mink eyelashes is more lighter,softer and more Flexible, our 10 year's experience in wholesale mink eyelashes can bring you more hot fashionable mink lashes, you can get top quality from our lashes factory with fast delivery. Most luxury package wholesale mink eyelashes box is available.
May 08, 2018 | Ice Kitchen Appliances - Others
Kitchenaid ice maker full of ice but won't release it
What is the model number of your unit?
Nov 29, 2012 | Refrigerators
Ice won't come out
if it's making ice, but the ice won't come out, it is likely going to be the dispenser motor (found behind the ice bucket).
the other possibility is the lever where you put the cup could not be hitting the switch, but most likely it is the dispenser motor.
May 21, 2012 | GE Mwf Ge Refrigerator Smart Water Filter...
Not cooling
There are many things that can go wrong with a Kenmore refrigerator ice maker. Your ice maker may be leaking. It may not make any ice at all, or the ice that comes out smells or has an odd appearance. The problem may have an easy solution, or it may require a technician's expertise. The troubleshooting tips in this article will minimally make you aware of what is likely the source of the problem. You may be able to fix the problem yourself and save a bundle.
When it Won't Make Ice
1. Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
2. Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
3. Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
4. Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
The question is too short so i guess that your refrigerator maybe won't make ice & reason for not cooling so i gave this tip.
Have a good day. : )
Apr 17, 2011 | Kenmore Refrigerators
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
