I'll assume that your notebook is otherwise working fine. Generally most laptops will play simple games with no problems. They do not have the hardware to run something demanding such as Call of Duty. I don't know what version of windows you have but I think the 530 should have come with Vista. Vista is a wee bit of a resource hog so that is one problem. You only have 512mb of ram and that really isn't enough to run Vista let alone something demanding such as a game. The 530 supports up to 2gb of system ram and that is important for a few reasons. First you need to have enough to let Vista run properly and that will use everything you can give it. If you could get it over 1gb you would notice a substantial increase in performance. The last and biggest problem is the video hardware. In this laptop is uses shared memory. This means it does not have dedicated fast video ram but instead relies on the using the system ram. So while you might have 512 of system ram the video card will take probably about 64 mb of that. If you update it to say 2gb then this can increase to a max of I think 225mb. That sounds like a lot but it is shared slower system ram. You do find new gamer laptops with high spec video chips and dedicated vram but even those do not perform as well as a desktop with the same or smaller amount of video ram. Unlike a desktop you cannot change out the video on a laptop so what you have your are stuck with. When it comes to gaming especially something like first person shooters the video card is the key to everything. I have a dual core laptop with 4gb of ram a very stripped down version of windows and 1gb of system ram dedicated to the video. I also have a old 2.8ghz single core pentium with 1gb of system ram but it has a new 1gb video card (important as these have a video processor and do not use the system one) and this does play call of duty at 60-100fps and anything else I can find to try on it. I tried the video card as an $75 experiment as I was about to replace the system. I didn't do that. It makes that much of a difference.
I hesitate to call these fixes as they really won't get you what you want out of any laptop with similar hardware like yours. That really isn't possible because of the slower system ram and shared ram probllems. The first thing is to max out the ram. It will cost a few dollars but then you can max out the size of the shared video ram.Nothing else will have as much effect as doing this to your laptop. Turn off anything you can in vista to speed up performance. It probably has most of it turned off now due to the low ram you have. Disable anything you don't need running. Fir instance office and adobe will load speed loaders at boot up. They are supposed to make these pop open faster. Disable them and you won;t notice the difference for those programs but you will in the system resources they consume. Also make sure anything like msn or yaho do not start with windows. msmessenger especially can at times be a real hog for resources. There are very few programs that ever need to load something at start up to run. Most are for convenience and each then steals resources. Not a big deal if you are not gaming and have plenty to spare but in your case very important. If you are dealing with simple games such as web based card games then usually the issue is with jave. You may need to download and install the java package from sun. As I mentioned you can't really make it into a hardcore gamer machine but hopefully you can see what the problems are to doing that with almost any laptop (not just yours).
If you are a "gamer" and you have 1GB of RAM, and you have Windows XP, you probably need more RAM.
If you are a "gamer" and you have 1GB of RAM, and you have Windows Vista or Windows 7, you DEFINITELY need more RAM.
Some motherboards support "dual-channel" mode, when you have 2 or 4 _IDENTICAL_ sticks of RAM. What happens is that each byte written to the RAM is "split" into 2 halves; one half is written to the 'A' stick of RAM, while, simultaneously, the other half is written to the 'B' stick of RAM. Obviously, this takes 4 "cycles" of the RAM, rather than taking 8 "cycles", if there was only one stick of RAM. So, your RAM seems to run at "double-speed".
So, when you buy more RAM, either try very hard to "match" your current 1GB stick of RAM, or purchase a "2GB dual-channel kit", or two "2GB dual-channel kits", to upgrade to 2GB (or 4GB) of RAM.
Depends on what kind of hardware you have
-Memory-
2 gb ram is "ok" if you use windows XP but if you have Vista or Windows 7 you should have a minimum of 4gb ram.
-Processor-
if you have a Dual core processor you are ok, if you have a p4 or p3 you dont want to waste money on a new graphics card because it will not help you get better games, your processor and memory will slow you down instead.
So my advice is, if you have a OK computer, go ahead with buying a new graphics card
if you computer is old and slow, DONT buy a new card! put your money on +2gb ram instead (cheap,and gives you more benefits) or maybe buy an "upgrade package" with new motherboard-memory-processor.
depending on what oem u r running can determine what the max ram u can use if u are running 32bit try upgrading to a 64bit if u already have 64bit and the max ram then i would suggest a newer laptop
this is possibly due to the settings in your BIOS. the specs for your laptops says that it is a 64bit PC w/ 4GB RAM and 1GB of video RAM. check your BIOS settings for the video card and set them accordingly.
It should work because this game runs on XP systems and your specs are fine... Try uninstalling then reinstalling, download the patch from http://www.3drealms.com/downloads.html It should work if it does not you might have a bad copy.
right click on the game icon and click propreties. On the Compatibility tab check the "Run in compatibility with" box and select windows 98/Mil and then you will be able to play the game. Alternatively go to gamecopyworld.com and search for max payne and download a crack for the game witch will let you play the game on any OS even Vista or Windows 7
According to Acer your system can support a max of 4 gb RAM. It has 2 slots so you would need 2, 2 GB RAM modules. Hope this helps & please remember to rate my answer. Thanks.
hi
you cannot directly use any game without cd key . but if you just can mount the image file of the game it will work fine but the multiplayer is't going to start unless you buy a new copy of the game
Laptops are usless for playing games. They may play some low quality games but there is really nothing you can do to upgrade a laptop to make it suitable for playing games. If you are planning on playing PC Games, buy a good Desktop Computer.
