Question about HP (350208-001) CD-RW/DVD-ROM (Combo) Burner
Hp 300 n
My dvd writer / cd- writer combo used to record discs fine for audio.Now it starts to record yet it stops and gives an error message
Sense: 03 ASC: 0C ASCQ: 00 (Command 2A)
when using record now 9 Music lab in the audio record for audio disc selection. It also will shut down my PC on other occasions when a disc is inserted that was recorded on same pc by a HP cd writer plus 8000 series from mp3 on pc to disc.Havent had problems before and the same message came from using a sonic record now 6.0 software.Tried many different CD-R discs of different brands.It worked for a long time but now both or at least one has a problem and a conflict.Upon looking at the driver device manager I noticed the location says 0 (0) wheres as my hp 8000 series says its location is 1 (1) perhaps normal ? I cannot seem to remedy this newfound problem.Drivers are the same with attempts at update.I run microsoft xp pro media center edition version 2002 w service pack 2 on an HP Pavilion intel pent 4 CPU 2.80GHz w 1.00 GB of RAM.
  • 91 Answers
Re: hp 300 n
I know your problem however it is easily fixed, the burner has worn out, the laser basically is not putting out enough light for it to work properly, the best and easiest fix, goto and replace the burner, they now start as low as 24.00 and go up to around 65.00 so it's not an expensive fix.
Posted on Dec 30, 2008
DJ Skywalker
  • 507 Answers
SOURCE: Error Code: 1004 CDB: 2A 00
Checkout the solutions on this forum:
Posted on Jun 28, 2011
0 characters
3 Points
When I insert blank DVD disc into DVD/CD-RW, and click it say insert the disc?
My first test would be to determine if the blank DVD is faulty. Try using a different brand of DVD and see if you get the same error. My experience tells me that your combo drive is faulty however. It is possible for a combo drive to read a CD but not a DVD. I would replace the combo drive with a DVD writer as they are not too expensive.
Best wishes,
Mar 04, 2011 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
I have a Hp Pavilion dv6000 and iam having problem with the dvd writer, while burning files with nero 7 its stopping and giving an error message . Please help me resolve the issue
hi friend, you should buy a DVD lance cleaner DVD. which is avilable in your electronic market. use it.bcoz, your dvd lance have dust on it.
if, it again give you same error then, goto your nearest service center.
Regards: Rakesh
Jan 26, 2011 | HP DVD1040i 20x Super Multiformat Dvd...
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
My drive will regognize and burn cds but when i try to watch or burn a dvd it says unkown or invalid its an hp dvd writer 420n
install the corect hp drivers and check the windows settings to make sure it is not sean as a cd drive instead of a dvd
Aug 03, 2009 | TDK Indi DVD 420N (AID+420N) DVD+RW Burner
MY HP 840i dvd-rw can read CD but can't read DVD
if you have cd writer and dvd rom then change your cd drive with cd/dvd writer because in the case of cd writer and dvd rom it gives error but sometimes the dvd play also but computer freeze from sometime and when we copy data then give us error messages i give you suggest to buy new cd/dvd writer
Jun 29, 2009 | HP CD & DVD Burners
Cdrom doesnt recognise blank dvd. error message
Its only cd writer burner and can only that it can read dvd disc also. That is why its called combo. But burning blank dvd it can't. But if you want buy some dvdburner too.
Apr 19, 2009 | Memorex (32023244) CD-RW/DVD-ROM Combo...
Audio works but not installation disk
HEY is it playing other DVD'S check is it a combo drive , dvd wirter or a cd writer, if its only a cd wirter then it won't play DVD
Aug 26, 2008 | LG GCE 8481B CD-RW Burner
Not recognizing disc in D drive
Hi, well the short answer is NO. You cannot use DVD's in a CD Writer at all. So the simple answer is to get some CD-R and copy the files to them. OR get a Combo DVD/CD writer and install that as well.. and then you can use both..
Aug 06, 2007 | HP (178373133) (Refurbished) (178373133)...
Copying data on to a DVD
What type of application are you using? I know that the new nero requires you to choose whether you want to write to dvd or cd before it will work. maybe your application is similar.
Aug 01, 2006 | HP CD-Writer 9900ci CD-RW/DVD-ROM Burner
HP (350208-001) CD-RW/DVD-ROM (Combo) Burner Logo
468 people viewed this question
Top HP CD & DVD Burners Experts
Lawrence Oravetz
Clive Gray
Are you a HP CD and DVD Burner Expert? Answer questions, earn points and help others
