Speed touch modem problem.
I can't get a speed touch modem to work with my router. I have had it working befor. I tried installing the router with the instlation cd and it says that it can't detect the internet connection, even though all the lights say it is working. The modem works fine if it is directly connected to the pc but not when its connected to the router. Please help me.
  • danner_16 Jul 01, 2009
    All the lights are green that are suspose to be.
    Scholar:
  • 103 Answers
On routers most of the time you can see 5 RJ45(LAN Cable) ports. Four will be close together and one is more apart. On this port you need to connect the modem. And on the other port the computer , no matter which one. Check for the lights in front of the router. One will be the WAN connection and needs to be green. Amber color is no good.
Posted on Jul 01, 2009
How to speed up internet network
The speed of your internet is determined by your service provider and their modem. If possible, connect directly to the modem to check the speed. If you suspect you D-Link router is not allowing you to get full internet speed, first a Hard Reboot of you Router and Modem.
If that did not solve the issue, try a known working LAN 5e cable between your modem and router. After you have established it is not a cable issue, do a factory reset.
I had an issue where my speed to the internet modem was fine, but the router LAN connections only provide a faction of the internet speed. After testing cables, etc I did a factory reset and it restored full connection speed on my router LAN ports.
Feb 27, 2016 | D-Link Computers & Internet
I upgraded my DSL recently to a higher speed. Computer and IPhone worked fine until Friday. IPhone will not see my network and computer cannot connect to Internet. Tried re-installing with disk. Get...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Nov 30, 2009 | Linksys Wireless-G WRT54G Router
D-link wireless wont work after high speed disconnect.
it's pretty easy to remedy...
1. turn off all computers including wi fi laptops... turn off routers, modem, wifi router as well.
Here's the trick:
Turn on your main router... the one that is plugged direct to your modem.
turn this on before anything else... once it's booted up, turn on your modem... it will cycle up and find the first ip address which will be your router that was turned on previously...
Then turn on all the other routers, wifi computers.... the main router should give all the other equipment their addresses automatically and you should have wireless working at that point...
Good luck... let me know if it gets you up and running.
May 27, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
My speed touch routers internet light is staying red and i cannot set my laptop up on the wirless
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Jan 13, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Wireless router problem
Try first to reset the router , since your have a new modem the router should be configure first to work with it, so after resetting the router now just run the setup CD of the router to configure it to work with the new modem that you have.............
Sep 26, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Need help
tesco broadband is not your ip address
IP address is 66.75.89.145, 192.168.1.6 something to that effect.
Aug 28, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My router is not working i tried to plug everthing on the router that is supposed to be plugged in and the modem and the router arent wokring together and when i plug everthing of of the router and put it...
ok.... did it work before and just quit? Have you recently treid to update the firmware? And.... if this has never been on the system before, have you installed any software that came with it? Of course....model of the unit, what type of modem and PC system you have would be helpful info as well.
THANKS
Jul 30, 2008 | Computers & Internet
Trying to install router, no success
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
Apr 14, 2008 | NetGear WGR614 54Mbps Wireless Router...
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
