Question about Dryers
Drum does not revolve - Dryers
    Sergeant:
    Champion:
  • 235 Answers
Belt is off the pulley or it could be busted.
Posted on Jul 01, 2009
Squeaking noise when drum revolved
Most likely a worn belt idler pulley, drum roller, or drum slider.
Feb 19, 2017 | Dryers
I keep finding holes in my t-shirts and other jersey clothing, i lost a bra wire in the washing machine a while ago is there any way to get to the outside of the drum? i think if i can get the wire out it...
It is very difficult to get the outside of the drum. The revolving drum is put inside a watertight drum. This drum supported with shock absorbers, front door opening with gasket. To balance the movements heavy counter weights are attached to it. To get outside of the revolving drum, it is necessary to open the front opening, remove the gasket. Hence it is difficult. To do all this two people are necessary. The best way could be find out the one end of the wire, if you can & pull it firmly by using a nose plier.
Sep 13, 2011 | Hotpoint Aquarius WD640 Front Load...
Machine will not final spin
I was given wrong info. the machine did go through the cycle and drain. However, the drum DID NOT revolve at all. Main motor Brushes replaced. Now OK. Thanks.
Feb 15, 2010 | Hotpoint Washing Machines
Not printing on left side of page
The problem is that the revolving drum doesn't contact the OPC drum proberly. You have to open the left side off the machine and replace the little white gear on the shaft that drive revolving drum. The gear has "jumped"one step and the revolving drum isn't parallell to the OPC drum. I fixed my 2840 last night it takes some time but now it works perfect.
Feb 25, 2009 | HP LaserJet 2840 Printer
Cannot revolve cartridges
Doing a complete power off/on and following the notes on Konica/Minolta website for changing cartridge
Jan 27, 2009 | Konica Minolta magicolor 2430 DL Laser...
Zanussi zwf 1020w drum not revolving
The drum will not rotate until the draining process is satisfied, there is either something in the pump or pump is broken
Oct 20, 2008 | Zanussi FJD1666W Front Load Washer
LG ELECTRIC DRYER
Henry, its going to be 1 of 2 things. Check inside your drum, see if the vent in the rear has burning or discoloration around it. If it does, it sounds as if your vent is restricted causing the unit to overheat, so clean/fix/replace the venting and your support pulleys will need to be repalce ie flat spots from overheat. If there is no scoarching marks and you know its not the vent or heat issue, the drum seam may have parted causing the thump as every revolution is made.
Apr 04, 2008 | LG DLE2514 Electric Dryer
Noisy Gas Dryer
possible problems are 1.) drum rollers are bad. These support the back of the drum and allow it to roll freely. 2.) Tension pulley that keeps tension on the belt could be bad. This shouldn't be a difficult problem to diagnose or an expensive one to fix if you do it yourself.
Oct 11, 2007 | Dryers
MAIN CIRCUIT BREAKER TRIPS
check heater element first then check motor , maybe motor carbons if relevant
Oct 10, 2007 | Washing Machines
Dryers Logo
35 people viewed this question
Top Dryers Experts
