Question about Legacy 2 Channel 1600 Watt Bridgeable MOSFET Amplifier - LA1468 Car Audio Amplifier
Need to know what size fuse do i put in this amp .
Amp was given to me but it has no fuse in it so i dont know if it works can you help !
  • 631 Answers
Owner's manual
According to the manual, the maximum current draw is 30 amps.
Posted on Nov 09, 2007
I need to know what size fuses go where?
jsut put 15 amp everywhere,should be enough but to large to cause any problems.
Jan 05, 2012 | 1991 Dodge Dakota
Fuse on main battery to starter/alternator cable , what size is it i need to do a temp repair fith a mega fuse but dont know what amps to get , thanks
The fusible link amp rating is based on the output of the alternator. I would assume your alternator is no more than 90 amps -- a temp fuse rated @ 100 amps should do it.
Charlie
Feb 12, 2011 | 2004 Volvo V50
There was a fire on the connection part on a fuse, how do I replace that? and what kind of fuse do I buy and where do I buy it?
you will probably have to replace the whole fuse box to be on the safe side but before you do that you must find out why you had a fire. was an incorrect size fuse used? was there shorted wiring? etc, then i'd call up a salvage yard and ask if they have the whole unit that comes the wire harnesses and connections already attached... just remove the screws that hold in the box and disconnect the two plugs and reverse it for installation. Warning! please make sure key is turned off or better yet disconnect the battery before attempting this. The fuses for cars and motorcycles will work fine just make sure on the new unit that you can read the amperage amount and use the correct size dont put in one thats only 5amps more unless it the first time its ever blown, and you need to get off the highway for saftey reasons. And dont even think about using the big 35 amp starter fuse to bypass anything, that would be *** bad as using a piece of tin foil. let me know if this info helped thanks
Apr 09, 2010 | 1989 Yamaha FZR 250 R
Amp
you want to put a 30A into the amp and the inline fuse that you put onto the wire should be greater than 30A but not too high for what the wire is rated. The best bet for wire is to buy a wiring kit which comes with fuse holder, right size fuse, wire for main power ground and remote. You may want to double check what is written on amp for the size to put in there. Technically you can put a 100A onto the wire if it is big enough and the fuse on amp will protect the amp from problems. Hope this helps, Good Luck
Mar 25, 2010 | Ultra Linear UL801 Car Amp
How do i know what size fuse i need for a hitron hra 2500 amp?
im assuming you dont have the old one. typically it will be 20-50a. i recomend consulting the manufactures website.
Apr 25, 2009 | Hitron HRA-2500 250W 2CH Amplifier Car...
I dont know waths the amp for the two fuse on my Legacy II LA890
On your normal mid range amp it uses 20 amps, but on your up scales amps they use 30 amps
Dec 15, 2008 | Legacy Audio American Legacy II LA890 Car...
12v wire
hello . what has happen is one of a couple of thing .? the wire could be burnt becouse of to menny amp's going throught it . becouse it's fuse is to big for the size of the wire. that you are using for your hot wire.to run your amp.!!! it work like this !!! the wire is gaged buy it's size .!!! and that determine's what size of fuse that could be used .!!! for that gage of wire.!!! in amp's.!!! that it let flow through it.!!! and a fuse is determin in it size in amp.!!' it will let flow through it the fuse. !!! and most likly you or someone has put to big of a fuse in .!!! you inline fuse holder .!!! that run's from the + hot of the battery all the way to your + side of your amp's.!!! that's mostlikly where you will find your problem.!!! check it first.!!! ok .!!! then check your amp it should have a fuse that plug's in to it .!! on the side of the amp.!!! you need to make sure that you use the right size of fuse for that gage of wire.!!! if you use to big of fuse you will have a wire fire or a melt down that burn's the wire in half or worst.!!! hope this help's you let me know. "GOOD LUCK"
Aug 03, 2008 | Car Audio & Video
Legacy 2 Channel 1600 Watt Bridgeable MOSFET Amplifier - LA1468 Car Audio Amplifier Logo
347 people viewed this question
Top Legacy Car Audio & Video Experts
Tygh Duval
Tygh Duval
Putter71
Level 1 Expert
Robert Little
Level 1 Expert
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
