Question about Philips Magnavox 51MP392H Rear Projection Television
Picture shrinkage to 16:9 rather then 4{3
Picture had been shrinking for around a month or so, now it has completely disappeared. sound is gone as well. occassionally, when I try to turn it on it will work, but usually, it makes a squeak from the back and just turns on the power light
  • video-tek
    video-tek May 11, 2010
    model number???????
  • Philips Master
  • 3,459 Answers
This is a common problem. You can get parts and instructions from www.TvRepairKits.com . Find your model on their site and get the shrinking and expanding kit.
Posted on May 07, 2010
    Filmmaker:
    Uploaded 5 video answers.
  • 162 Answers
Try the site www.TvRepairKits.com for a kit. They may have a fix. They seem to be experts with Magnavox problems.
They helped me with my set recently.
Posted on Aug 09, 2009
Why does hotpoint maschine, only 15 days old, suddenly shrink wool clothes?
I was under the impression that only HOT water will shrink wool clothes. Did you buy mistake set or forget to set your temperature setting. Think back to the previous load that was washed. This may be the reason for your shrinkage problem. GOOD LUCK FRIEND.
Feb 25, 2015 | Hotpoint Washing Machines
I HAVE SHRINKING KIDNEY WHAT ARE THE SYMPTOMS
Symptoms of Kidney Shrinkage? Since kidney shrinkage is one indicator of the loss of kidney functioning tissues, patients are more likely to experience several symptoms as follows:
- Swelling: Fluid retention may appear in patients' face, legs, feet, head and some other loose tissues easily.
- Hematuria: Urin presents red, black or tea-colored that means there is blood in urin.
- Back pain: Back or flank pain is indeed one sign of kidney shrinkage.
- High blood pressure: Most often, the worse patients' illness condition, the higher blood pressure.
- Fatigue: It usually results from renal anemia or deposits of uremic toxins.
- Nausea, vomiting, skin itching, or other symptoms
Jan 04, 2015 | Britannica My Body, Myself (LBSCIMYBOJ)
Tv picture shrinks
This is a common problem on certain models of Philips Magnavox TV sets. The most common symptom is the screen will shrink and expand over and over. After the TV heats up for a while the video will work like normal. After a few weeks or months your TV will eventually stop working and not have video. You can get complete parts and instructions from www.TvRepairKits.com
Nov 17, 2009 | Philips 9P6031C 60" Rear Projection...
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
May 12, 2017 | Mitsubishi VS-5077/78 TV
Screen shrinkage
The vertical shrinkage is a fault in the vertical deflection circuit, suggest replacing capacitors around that area along with a vertical output IC. I can provide more info if you've got some electronics experience and going to try and tackle it.
May 18, 2009 | Zenith Televison & Video
No picture
This is a common problem with this model. The site www.magnavoxhelp.com has a chip kit to fix the video shrinking problem
Aug 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Toshiba 36 inch TV (8 Years Old)
If the shrinkage is just the top & bottom then it is relatively easy/low cost fix. Most probably, a capacitor in the vertical section is nearing end of its life. This would be the biggest of the bunch and would be something like 47uF/50V.
If however, the shrinkage is on all four sides, then it is the master power supply that is at fault. Chances are the main B+ is getting low which cold be caused by the big filter capacitor or an erratic regulator. This is not a simple fix and would require the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 10, 2008 | Televison & Video
Shrinking picture
All symptoms indicate a problem in the vertical circuit,the first thing to look for will be loose conection on the vertical output IC,sometimes this IC goes bad completly and it needs to be replaced.If you are familiar with soldering electronics you can take care of it but if you are not too familiar you can play it safe and take it to a servicer ,it will be a lot less expensive than if they come to your house.Let Us know how it goes or if you need more information.
Oct 26, 2006 | Quasar SP-2722 27" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
