Question about Refrigerators
Water inside leaking onto the floor
Water inside the refrig under the crispers which is leaking onto the floor
  • rickath15 Jul 01, 2009
    The door closes and the seal is good. There was quite a bit of water under the crispers which caused it to overflow onto the floor. Refrig in the same place for several years so we assume that it is level because this is the first time that this has happened. The drainage pan under is dry.
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Is the door hard to close, doesn't seal well? Box on even, level floor?
  • 232 Answers
UNPLUG IT FIRST.clogged drain in freezer remove freezer pannels inside remove ice dont use annything that is sharp. heat some water in the micro and pour it in the pan under the evap coils do this till it drains keep your eye on the the drain pan under the frige
Posted on Jul 01, 2009
Water appearing on glass above crispers and onto the floor under the crispers. Happens only occasionally. No obvious source of leak. Back of fridge wall not wet.
Do you have a cooling plate at the rear or the fridge with a narrow tray at the bottom to collect the defrost water? Check the drain hole for obstruction.
Apr 08, 2016 | Refrigerators
Ge profile side by side 2005 psh25pswass small amnt of water on inside of refrig on the bottom of refrig floor on side next to freezer. vents in refrig appear to be bringing in very humid air that is
It can have an air leak, but also a clogged drain pan under the freezer evaporator coil. If the refrigerator is getting warm, then it may be another issue
Dec 17, 2014 | GE Refrigerators
WATER LEAK SAMSUNG RB215LASH
When water is leaking inside of your refrigerator, the problem could be as simple as condensation from humidity or a worn gasket, especially since you purchased your refrigerator used. The problem could also be a clogged drain or frozen evaporator.
To help you determine the problem, along with solutions that you can use, check out Refrigerator leaking water inside for some simple troubleshooting steps. I hope that helps!
Aug 02, 2012 | Samsung RB215LASH
Water leaking onto the floor and down the back of refrigerator to the bottom under the vegetable crispers?
You have a problem with the auto defrost drain system.Carefully take off the cover by the light and control and see if you can clean out the drain. Sometimes you can get to it from behind the refrig. but that means you have to move the refrig out from the wall.Hope you find this helpful.
Jun 12, 2011 | Whirlpool Refrigerators
Water comes off somewhere in the bottom of my fridge. what could have caused it?
When your refrig goes into defrost , the water runs down the back of the refrig ( inside ) and out to the drip pan thru a drain hole under the crispers . If water is under the crispers , remove the crispers and you should see a " cap " covering the drain hole . Sometimes crud will cover the slots where the water is supposed to drain , causing water to pool under the crispers . Just remove this cap , clean , and reinstall .
Mar 20, 2011 | Magic Chef Refrigerators
Water is leaking onto the inside floor of the fridge. when u used the water dispenser it leaks even more
You have a leaking water tank inside the refrig behind the crispers . The tank ( now plastic hoses ) is easily replaceable . Called a water resevoir technically .
May 12, 2010 | Refrigerators
Water pooling inside of refrigorator
sounds like the drain line for the defrost cycle is plugged. the water is supposedto end up in a pan under the refrig. the drain probably needs to be defrosted and cleaned.located behind the back panel in the freezer compartment
Jan 21, 2010 | Frigidaire Refrigerators
Water under crisper drawers and then leaking outside underneath.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Sep 28, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Feb 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Refrigerators Logo
509 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
