Question about Samsung LN32A330 32 in. LCD TV
Connecting xbox 360 to tv
Tried all the cables everywhere still cant get xbox on tv
    Sergeant:
  • 299 Answers
Are you using HDMI cable or how you trying to connect?
Posted on Aug 25, 2014
2 Suggested Answers
SOURCE:
  • 31 Answers
SOURCE: XBOX 360 will not display on my TV NOW!!! HELP!!
Sometimes cables will just go out, especially standard ones that come in the box on gaming consoles, DVD players, etc. My recomendation would be to narrow it down to either a problem with the XBOX, the TV, or the cable.
Step 1: Find a friend with another TV to try the cable and console on. If this works, we can automatically determine that the problem is with the TV, however it most likely isn't.
Step 2: If you know someone with an XBOX, take your console to their house and connect it to their TV with their functioning cable. If this works, we can rule out the gaming console.
If Step 1, 2 yield no results, then the problem most likely is with the cable. You can pick one of the up pretty cheap on Ebay, Buy.com, etc. However, I would recommend going with an HDMI if you get to this step. You will experience much higher quality picture, sound, etc, and have a much higher gaming experience than before.
Posted on Apr 13, 2009
No sound on Technika HD TV when using my Xbox using HDTV cable
i cant get soun when playin my xbox 360 on my technika tv. how do i obtain sound?
cheers
Jan 12, 2010 | Microsoft Xbox 360 Console
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
HDMI Problem
ok i think you need to reset the video settings here is a step by step procedure which you can follow
To reset the display settings of the Xbox 360 console to the default settings, follow these steps:
  1. Remove any discs from the disc tray.
  2. Turn off the console.
  3. Turn on the console.
    Note If you are using an Xbox 360 Wireless Controller, turn on the console by using the Xbox Guide button on the controller. Wait for the guide light to indicate that the controller has linked to the console.
    Note Make sure that you use the player 1 controller when you do this. The player 1 controller is indicated by the upper-left quadrant light on the console.
  4. As the console starts, press and hold the Y button as you pull the right trigger.
    Note This action causes the Xbox Dashboard to reset the display settings to the default settings. The console then automatically restarts.
Jul 10, 2009 | Microsoft Xbox 360 Console
CONNECTING XBOX 360 TO SAMSUNG HOME CINEMA SYSTEM VIA OPTICAL
For some reason you can only have the component leads with optical cable, if you put hdmi cable in there is no connection for the opticle cable out.
Jun 10, 2009 | Microsoft Xbox 360 Console
Xbox 360 Console, Faulty, NO DISPLAY!!??
What do you mean, no display? Is is game-related display issues? Have you checked the AV cable connection? Or is it about the settings? Is this the first time that you are going to connect your xbox console?
To determine whether the display issues are specific to a particular game, try playing a different game to see whether the same symptom occurs. Reminder, some Xbox original games that were released for the original Xbox console may show some display issues when you play them on the Xbox 360 console.
Next, make sure that AV cable is connected correctly to the Xbox 360 console and to the TV. To verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, you can disconnect the AV cable and then reconnect the AV cable to both devices. Note: If you are using composite cables, do not try to set any HDTV settings. If you try to set HDTV settings, you may lose the picture.
You might also want to check your TV's settings because some display issues can be caused by how the TV is set up. To make sure that this is not the case, please check your TV's settings.
In your TV's settings, you should check the following:
- Make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- If your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- If your TV has a type of picture compensation enabled, disable it
- If your TV's settings are correct, you may want to try using a different TV, if you have one available. Try connecting your Xbox 360 console to another TV to see whether the same display issues occur
Next, reset your Xbox 360 console. To reset the display settings to the default settings, follow these steps:
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
Mar 09, 2009 | Microsoft Xbox 360 Elite Console
New XBOX 360 no picture / sound
ok your lucky, you just need to by a new av cable.. or if that dosnt work you need to get the av caple connection fixed (only about $25)
thanks, Domo
Dec 23, 2008 | Microsoft Xbox 360 Console
When x box 360 is plugged in to tv,there is no signal
try reconnecting all the cables and make sure you have the right setting(normal tv or hd, theres a switch on the cable), if that doesnt work, you might have a faulty cable, or even worse your xbox has an interal problem(very hard to explain, read this if you cant connect to tv....(http://xbox-experts.com/e/errorcodes.php) and you'll need to send it to microsoft for repairs.
Nov 12, 2008 | Microsoft Xbox 360 Console
Sound no picture
your cables are probaly broken go to xbox.com for trouble shoting tips.
Jun 19, 2008 | Microsoft Xbox 360 Console
Orange livebox
a bit confused with the question. This question is listed under "network hub" meaning you have a physical cat5 cable running to the xbox 360. and the xbox 360 is asking for a WPA key.
WPA is one of the standards for wireless security. please clarify the question and let us know more about your home network.
Jan 03, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
Samsung LN32A330 32 in. LCD TV Logo
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
