Question about GE WBVH6240F Front Load Washer
What causes a front load washer to leak
Moved from one location to another
3 Suggested Answers
SOURCE:
dutchman05
  • 487 Answers
SOURCE: ge front load washer leaks from bottom
full display
And for the part numbers look here
Have fun with it and please rate me on this site
Posted on Apr 20, 2008
mikedurland
  • 481 Answers
SOURCE: leaking from the front
take a butter knife and release the two clips on the top of the front panel (look in the seem between the top and front panel and push the butter knife directly into the clips), this will release the front panel from the machine. then you can see where the water is coming from.
Posted on Jun 27, 2008
Water shooting from top
Hello Betty Lamey - That is an interesting location. The location from where the unit is leaking is not a common failure/complaint. The washer could possibly have a poor door gasket or damage/crack door. Contact a professional to move forward accurately.
Feb 16, 2013 | Electrolux EW1000i Front Load Washer
Tip
Water leak from door of LG front load washer
First, clean off the bottom of the door glass where it contacts the gray tub gasket when the door closes. Any hair or other build up can result in leakage. Second, if that does not completely solve your leak, you can move the location of the spring which holds the tub gasket from the very bottom (6 O'clock position) to the hinge area (9 O'clock position). Third: Sometimes, the reason you get a leak is due to the installation. If the washer was pushed into place by applying pressure in the center front of the washer, the outer front panel can be slightly deformed (inwerd) resulting in leakage from the door. If that is the case, sometimes you can remove the outer clamp and outer part of the gray seal and pull out on the front panel to correct the situation if it is not too severe, rather than replacing the entire front panel.
on Jul 03, 2009 | LG WM-2277HW Front Load Washer
Error code e13
Hello Mark Depner - Typically error code E13 indicates that the washer is detecting a water leak in tub or air leak in air bell. You will need to contact a professional to move forward accurately and verify where the leak is located.
Oct 06, 2012 | Frigidaire ATF6000ES Front Load Washer
LG front load washer -- water leaks out the bottom of the door -- if I push on the door while its running, the water slows/stops leaking...
Jun 25, 2009 | LG WM-1832C Front Load Washer
Soap leaking out of the bottom of washer
highly likely if you didn't use your shipping bolts when moving your tub cracked bottom of soap dispenser inside of washer buy warrnnty sear about 250.00."less soap plz"
Nov 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG Front Load Washer Problem
The washer is not leveled correctly.  You will need to adjust the front feet to level the machine.  Run a load of clothes in the washer.  When it gets to the spin mode, check the level of the machine by pushing the front left corner and the front right corner.  If the noise quiets down on either corner of the machine, adjust the legs on that side.
Jul 22, 2008 | LG WM-1832C Front Load Washer
Leaking from the front
May 14, 2008 | GE WHRE5260E Top Load Washer
Ge front load washer leaks from bottom
full display
Apr 19, 2008 | GE WSXH208A Front Load Washer
Just moved. New washer leaks water and appears tub is off center
CHECK THE BALANCE SPRING LOCATED (INSIDE LEFT REAR OF MACHINE). IF SPRING IS OFF IT CAN CAUSE THE TUB TO TILT TOWARD THE FRONT AND THE TUB FILL HOOD WILL NOT BE OVER THE TUB DURING FILLING OR THE TUB WILL BE ERATIC DURING THE SPIN WHEN RINSE WATER IS SPAYING IN CAUSE ING THE WATER TO MISS THE TUB AND SPRAY OUTSIDE. THIS IS COMMON IF THE UNIT HAS BEEN MOVED OR PLACED ON IT'S SIDE OR CARRIED AT EXTREME ANGLE.
Jan 17, 2008 | Whirlpool LSN1000LW Top Load Washer
Washer leaking
There are several things that will leak under a GE washer. The the usual suspects are drain hose connections, or hoses that have cracks or holes. I would inspect the hoses first as this would be the easiest fix. The other thing that can causes problems is the wash tub seal on the bottom of the tub. If the spanner nut (under the agitator) comes loose, the seal will unseat and the tub will begin to drip (I've had this one happen to me). Another cause can be the wash tub itself (I've also experienced this one). Inspect the wash tub for cracks. The tub can develop stress cracks and begin to leak. Especially if this is a washer that was involved in a move. To access the inside of the machine, the front should come off by pushing under the front lip of the machine with a putty knife. There are metal clips that hold the front to the top. Look in the crack with a flashlight to locate them. Push in with a putty knife to release and the front should just come off. I hope this helps you.
Jul 05, 2007 | GE WBSE3120B Top Load Washer
GE WBVH6240F Front Load Washer Logo
48 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
