Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
The picture is pushed to the left of the screen. Reds are VERY red.
  • Panasonic Master
  • 3,459 Answers
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Posted on Aug 31, 2009
RCA model #f27648 reds missing from picture
It sounds to be a video output stage circuit fault. Check all the solder terminals at its CRT base card, including the solder terminals of the CRT base to the card. Re-solder all the suspected solder terminals by applying a little more fresh solder. Contact any service technician. Check the solder terminals of Red color output transisotor. If needy, replace it with a new one with same number printed on it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
The fault is 'one colour predominant/absent screen'
Mar 26, 2014 | RCA F27648 27" TV
My 32LD30UA LCD TV is 16 months old, when you switch TV on the picture has a band of reds and greens running down screen for about 30 minutes then returns to normal.Help?
My HITACH 32LD30UA LCD TV when you switch TV on the picture has a band of reds and greens running down screen for about 30 minutes then returns to normal.
Dec 12, 2010 | Hitachi 32LD8700 32 in. LCD Television
My reds on my picture screen are showing now in browns ,cant get the real red to show,the other 2 colors are fine.The convergence is fine I changed these ICs a while back ,its the red color I need.Do I...
I remembered that when I was watching my DVD player earlier,the reds were just fine ,its when I used the converter box cable channels, that the reds were brown,an so I rechecked it by using the DVD again..Yes the reds were fine an so I went to the converter box an found that the red cable at the rear of the converter box was defective, an so upon changing out the cable my problem was solved thanks again Val
Sep 12, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Picture turns to shades of greens except the reds. doesn't happen all the time but more often lately.
it's a crt socket problem.try to clean the screen cable coming from the flyback and change the capacitor in the left side ot the fly back .you may also have an unsoldering resistor or capacitor around the flyback area.
Sep 04, 2009 | Toshiba 57H81 57" Rear Projection...
My phillips model 60pp920217f has a horrible picture...no green to the color
The green CRT coolant has congealed thats whats giving you the green halos. Change the coolant in the green and blue and your set will be fine. red is never affected so the red coolant should be fine.
May 07, 2008 | Philips 43PP9202 43" Rear Projection...
Convergence Problems
GREEN-YOU HAVE TWO STK392570 CONVERGENCE ICS' GETTING READY TO FAIL.SOME FOLKS HAVE REPLACED THEM ON THEIR OWN,OR YOU CAN GET A REPAIR TECH TO DO IT FOR AROUND 300.00$.JOE TV
Oct 29, 2007 | Mitsubishi WS-55819 55" Rear Projection...
I have 47 inch with double color in picture, reds and green
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
convergence amp ic bad
Oct 14, 2007 | Samsung HCL552W 55" Rear Projection...
Green wave-like color distortion over reds
do you happen to have any speakers of any size within about 3 feet in any direction of the tv?? move them if so, I have large speakers about 5 feet from my tv at home and i still get some distortion once in a while with red and dark green streaks.
Aug 15, 2007 | Sony WEGA KD-34XBR970 34" TV
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
60 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
