Minolta Bizhub C652 printing faults
Printer makes strange black marks on prints
    Sergeant:
  • 299 Answers
Check your cartridge.
Posted on Aug 25, 2014
SOURCE:
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
Posted on Dec 20, 2007
  • 214 Answers
SOURCE: Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Posted on Dec 31, 2007
Bubbabear64
  • 2794 Answers
It is supported for Vista according to this chart
Here is the drivers for 32 bit Vista
Posted on Jul 06, 2008
waqar697
  • 67 Answers
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Posted on Mar 30, 2009
nchalabe
  • 4 Answers
SOURCE: Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Greetins.
Nolasco from argentina - DPI Grafica
Posted on Jul 09, 2009
How do i clear a funny noise in a konica bizhub c652 indicating that there is paper jam while it is no where to be seen?
Noise and jamming to different for the noise fuser unit replacement, for the jam where does it say the paper is at???
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 14, 2015 | Konica Minolta bizhub Office Equipment &...
Printing black ground in konica minolta bizhub c220
have a tech come out clean the machine run require procedures to determine problem
Apr 26, 2014 | Konica Minolta Bizhub C220 Color Copier
Bizhub C652 has horizontal lines.
its important to find out whether the \'lines\' are in scan direction/ or only through Radf or only from scan glass,
if the lines are only showing when documents are fed throught the Radf, then the problem lies with the document scan plate( left of the main glass platen (about 2" in width)) or with the scan plate blade cleaner
if the lines ONLY appear when copying from the Glass then the issue lies within the optics (probably nothing more than a clean will be needed)
another question would be to ask if the lines are solid (black line overprinting image) or if they are \'missing\' lines where the image has failed to copy, sometimes it can be hard to work out which side the fault lies,so try shaded greys as a copy original .
if the scan lines are appearing on both Radf and Glassplatten ,mode then the issue may be dirty optics/ccd sensor or it could e an indication of the ccd failing or image control pwb in error while interpreting the image file.
what to do
1) place a grey sheet of paper in the Radf and have the copier photocopy both sides of the original and print to single sided sheets ( so the printer turns the original over to complete the task)
observe the result.
2) have the copier photocopy directly from the platten glass- single sided.
observe the result.
ckeck to see if the error has appeared on both sets of prints ,
if the error has only appeared in the first set of prints then the issue may be a tiny DOT on the slit glass (left of platten) - a dot on this glass will indeed appear as a Line as the original is scanned across the glass.
hhope thhis helps
Feb 19, 2014 | Konica Minolta Bizhub C652 Color&b/w...
Bizhub c652 service codes
What is the service code being displayed????
Jan 23, 2014 | Konica Minolta Bizhub C652 Color&b/w...
Error code C-2704 mean on C6500 Bizhub Pro
Abnormality in the black charging unit.
Possible causes:
Black charging unit
HV Unit
Print Control Board
My best guess is that you have a faulty charge unit. Try swapping the units around with another colour and see if the fault code shifts.
Dec 30, 2013 | Konica Minolta Bizhub Pro C6500 Color...
Free service manual
error code c-c173 bizhub c652 wat solotion
May 08, 2013 | Konica Minolta Office Equipment & Supplies
Pages keep covering with cyan
Try removing both the toner cartridge and the drum (for extra efficiency i would recommend restarting the printer at this point). Then re-install them both firmly to ensure there is not danger either of them is not making contact at the relevant points.
If the issue still occurs and the drum unit is not reading s being nearly expired the problem is likely to be with the cyan toner cartridge. Unless of course the problem began to manifest immediately after changing the drum.
Sep 08, 2012 | Konica Minolta Bizhub C652 Toner Black...
Black and white printing
the black cartridge has ink in it and is useable? I have had printer cartridges dry up but the printer thinks it is full and if there is no black available they will use whatever is available to them
Apr 05, 2012 | Konica Minolta bizhub 250 All-In-One Laser...
Black lines running down on the Konica Minolta bizhub c252 copier?
Does this happen when you print? does this happen when you make copies on the big glass. Does this happen when using the document feeder?
Jan 23, 2012 | Minolta Office Equipment & Supplies
50 people viewed this question
k24674
Marvin
Marvin
