Question about Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX FL 511 bad fuser rollers
I have a KX FL 511 a with a damaged fuser roller. How do you remove the fuser unit to repair? I tried removing the four screws from the top but no luck.
  • 167 Answers
SOURCE: error
clean the drum unit by opeing it and cleaning the wiper blades etc. In case it does not help please replace the drum unit Happy faxing Omipresent
Posted on Sep 26, 2007
tech435
  • 284 Answers
SOURCE: UF-8000 jamming and not transmitting consistently
what exactly is the error code on your machine, and if you replaced some of the fuser parts already you might have pinched the ribbon cable by the fuser
Posted on Nov 05, 2008
leroyal
  • 2120 Answers
SOURCE: "Check Document" message
look for a switch trapped down in the document feeder
Posted on Jan 29, 2009
SOURCE: Have a Panasonic KX FL 511 it it printing very
I made this suggestion to a person who's printer wouldn't recognize his new cartridges: Reconnect the printer to the computer as if it was for the first time. Complete every step as it is written.
Printers are indeed very finicky devices and sometimes they are just not any good any more. New printers are as cheap as the two new cartridges, which makes it just as cheap to upgrade to a newer printer. Good luck!
Posted on Feb 19, 2010
FixinFax
  • 3085 Answers
SOURCE: roller or part that grabs paper to FAX will not grab
No spare parts available, sorry
Posted on Jun 30, 2010
Fuser location
Open left side. Fuser is located near exit. Need more info. Fuser lamp could be out this is in middle of fuser roller pressure roller is on top. Check all paper path switches or sensors. Use canned air if possible. Remove toner cartridge first.
Sep 17, 2014 | Panasonic Kx-mb2000 Laser Multifunction...
What call service 3 in Panasonic kx-mb1900
CALL SERVICE 3" means that the temperature of the fuser does not rise up to or exceed a constant temperature.
The temperature is monitored with the thermistor inside the fuser and detected with the voltage input into IC 300-D19
Apr 26, 2014 | Panasonic KX-FL611 Plain Paper Laser Fax
How to clean HP4100 TN laser printer? I am getting black streaks down side of page. . .ink is smeared.
There are 3 things to be checked. 1: toner cartridge,try replacing it with a new on. 2: Transfer roller w/c underneath the toner cartridgelying on the printer. Removed toner cartridge,you see a roller w/c is foam like outlook,wipe it with clean dry lint free cloth or paper towel. 3: Fuser unit w/c fuse the ink on the paper.It is lacoted at the back of the machine.Remove the bottom rear cover,just by pulling it. Then you will see 2 blue color lever on left & right,turn those levers up to unlock the fuser unit,then pull out the unit. taking a look in the inner part of the unit you will see rollers . Any bad coating or damage on the roller will create smears on the prints.
Jul 14, 2009 | Office Equipment & Supplies
E002 canon 6317
E002
1)due to fuser unit temperature control fault.
2)try to reset the machine by tuning on and off
3)fixing thermister or thermoswitch faulty due to cannot maintain fixing heater temp causes E002 appear.
4)check any paper roll over the surface of fixing roller.try to remove it.
5)fixing roller or fuser roller located near to printing output.
Jun 10, 2009 | Canon imageCLASS D761 Copier
Fax rollers
what kind of roller do you want to install...in feeding unit or in fuser unit?
Dec 17, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Help
hi im jules_09,check the fuser unit paper are folded because the rubber roller is worn out then the black line is also cause by scratch or damage upper or hot roller in the fuser unit.if the hot roller or uuper roller is fine check the drum unit if the opc drum is damage or scratch then check also the drum cleaning blade or roller,blak line in copy indicate one or two part either in the fuser unit or drum unit is damage.
Nov 15, 2007 | Panasonic FP-7735 Black and White Copier
Error code 3
do you mean..call service 3????
check the fuser unit.. check the fuser roller,see if it it deteriorated.. check the fuser thermistor.. check the physical apperance,, see if the plastic seal is already tampered.. just give focus on fuser unit
Nov 01, 2007 | Panasonic KX-FLB756 Plain Paper Laser Fax
Brother 4100e paper jam
Can be tricky people usally damage the fuser rollers removing this jam with pliers/tweezers, it has concertined and stuck after fuser rollers and before exit rollers it will be stuck on the switch best bet is to dismantle properly and remove fuser then dismantle fuser and remove jam, another thing to be concerned about is why did it, three seneraros, Damp paper going threw fuser dries and crincles(use fresh paper from sealed packet), fuser is worn(have fuser replaced), just a bad bit of paper (just have fuser jam removed. Fusrr runs on 240v, covers break easy
Oct 15, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Panasonic KX-FL511 Plain Paper Laser Fax Logo
218 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
