Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Kenmore elite - Water dripping from freezer to refrigerator
Kenmore elite Refrigerator
water dripping from freezer onto top shelf of fridge also small amount of ice build up in back of freezer Dripping water from freezer on to top shelf and freezing Water drips down into the refrigerator section and sometimes forms ice.
  • Kenmore Master
  • 4,655 Answers
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
  • 1 more comment
  • Nirmand Choquette Oct 03, 2013
    Where can I see a picture of the back panel so that I can see where is the drain? There is a lot of ice behind that panel and I am looking for the drain...
    It is a kenmore refrigerator, with the freezer at the bottom, model 59669932011.
  • John Tripp
    John Tripp Oct 04, 2013
    The parts breakdown for the freezer can be found here http://www.searspartsdirect.com/partsdir...
Water is dripping from the top of the refrigator onto the top shelf. We defrosted the freezer; no change
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 04, 2010 | Whirlpool ET1RHMXKQ Top Freezer...
Water dripping from freezer department into refrigerator department, coming in from around the fan in the top of the refrigerator and dripping onto the top glass shelf. could there be something clogged up...
9 times out of ten that is your problem. You need to pull back panel off of freezer and check drain. Also the thermostat control panel can be removed to checj=k the catch panel in there.
Jan 09, 2010 | Kenmore Refrigerators
Water inside refrigerator
Even though it doesn't seem like it's coming from your freezer, morre than likely that's where it's coming from. At the back of the fridge there will be a drip tray that actually catches the water from the thawing freeze. One way to avoid access water is to simply turn down your freezer and fridge. Usually if they are number 0-10, both frigde and freezer should be set on the 5 level.
Aug 31, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaking inside of refrigerator from freezer
IT SEEMS LIKE YOU HAVE A CLOGGED DRAIN . CHECK YOUR CONDECER COILS BEHIND KICK PLATE .. AFTER THAT YOU CAN UNPLUG FRIDGE FOR 24 HRS WITH DOORS OPEN AND SOULD DEFROST ENOUGH TO CLEAR DRAIN . IF NOT . DEPENDING ON MODEL YOU SOULD BE ABLE TO GET THROUGH DRAIN THROUGH MOST FREEZERS .
Feb 03, 2009 | Kenmore Refrigerators
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
1,835 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
