G60-120us having small lines across the screen, but if i connect an external monitor there is no lines
  • 315 Answers
A quick test and perhaps even fix would be to grasp the right and left sides of your display while it is on (displaying the offensive lines) and gently twist like you were wringing out a towel. Again, and I emphasize, gently using only a couple of ounces of force. Watch to see if the lines disappear, get worse of make the screen flash or change.
If you do then its likely cause is the connector from the LCD panel to the electronics has oxidation or a loose connection. If you're lucky the flexing might even fix your problem, if not you will have to take it apart to find out exactly what is going on or take it to your local repair shop.
Posted on Jul 01, 2009
Horizontal lines across HP laptop TE11HC screen - faulty screen?
If shown during the boot up process then you have a physical damaged screen.
Sep 18, 2014 | HEWLETT-PACKARD Computers & Internet
I have voice only no picture how do i fix this problem
First you want to test the screen and graphics card. If you have an extra external monitor, hook it up to your external monitor connection. If you can see the full screen of the laptop on the external then the problem is probably with your laptop screen . If you still have the same line, you probably have an issue with the graphics card or the driver software. If you can see the external screen try uninstalling the graphics card, then turn off the laptop and restart. That should reset the card and may work.
Jun 28, 2014 | Netflix
Pink screen
If the pink lines or streaks are across the screen then this indicates the CCFL lamp will fail soon.
To confirm it is not the video chip on the motherboard, connect an external monitor to your laptop, power up the monitor first and then boot up your laptop. The video will automatically divert to the external monitor and if the Windows image is normal then this confirms a problem with the CCFL lamp and it needs to be replaced.
Sep 23, 2012 | Samsung N150 (36725723009) Netbook
Pink lines running across screen
Sounds like your lcd screen is bad and needs to be replaced. Try connecting an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok without the lines, then your video card inside the computer is good but your lcd screen is bad. If the Borrowed monitor displays the same lines as your lcd screen then your video card inside the computer is bad.
It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Jun 07, 2012 | Computers & Internet
White lines across my laptop screen
Either your lcd screen is going bad or you could have a loose lcd cable. Either one will require you to disassemble the lcd screen. Try connecting an external monitor to your laptop and see if the screen image displays ok on it. if so that means your video card is ok, the problem is with the screen. You'll have to hit the FN (Function Key) + (F1 thru F12) key to get the image to display on an external monitor. It can even be one of the old fat crt monitors as long as it connects to your laptop's vga port. Hold the FN key and hit the corresponding key that allows the external monitor to display. Normally the correct F1 thru F12 key will have the words lcd/crt or an icon of a display on it.
Mar 19, 2012 | HP Computers & Internet
My laptop monitor has vertical lines all across it, so I have an external monitor, how do i connect it to the laptop
Connect the VGA cable to the VGA port of the laptop then restart the computer.
Go to display properties and enable the second screen, then disable the notebook screen to display only on the external screen.
Nov 18, 2010 | Computers & Internet
Periodically the screen is captured by horizontal lines completely across the screen. Cannot access programs or even shut down properly. Any suggestions. Presario 700 laptop using Windows Vista. Thanks
This issue is due to the malfunctioning of the screen or due to any other internal hardware malfunctioning of the notebook.
To further isolate the issue, I request you to connect the external monitor and check.
Once after connecting the external monitor, please tsp Fn+F3 Switch between the display and external monitor in the following order:
Display
External monitor
Display and external monitor
If the external display is fine then the issue either could be due the malfunctioning of the display cable connector between the screen of the notebook and motherboard or due to the malfunctioning of the screen.
As this the hardware issue, Please contact the nearest repair center to get it resolved.
May 29, 2010 | Compaq Presario 700 470024-192 Notebook
My toshiba laptop has a thick white line down the screen
The normal cause of lines across the LCD of a laptop is a damaged video cable. The unusual cause would be the video card itself.
To determine which item is at fault, you need only attach an external monitor to your laptop's video-out, and then swap your monitor view to 'both' or mirrored (usually just the function key (FN), plus one of the Fkeys...look for an off-blue picture of a monitor on the Fkeys).
If the lines across the screen also appear on an external monitor, then the video card is damaged.
If the lines only appear on the laptop's LCD, but not the external monitor, then just the laptop's internal video cable is damaged.
Hope this helps.
Aug 21, 2009 | Toshiba Satellite p105-S6114 Notebook
Lcd display
Try connecting your laptop to an external monitor.Connect it with a vga cable to your monitor and press Fn+ monitor key(I don't know what it is for acer) to switch displays.If there are no lines on the external monitor then the problem is due to the notebook lcd.If there are lines then it is due to a driver.Reinstalling the driver should fix that then.
Aug 24, 2008 | Acer Aspire 4315 Notebook
23 people viewed this question
k24674
jasbo
jasbo
