Question about Motorola Talkabout T5420 (14 Channels) 2-Way Radio
Hi there i have a strange icon in one of my radios
Hi there i have a transmitting problem with one of my radios there is this icon in the one that doesn't transmit. it's a circle with two waves coming out.does anyone know what this is?
  • Motorola Master
  • 1,654 Answers
The icon you are describing is the "roger beep" icon. It would not be the reason your radio is not transmitting. Most likely your programming has been changed. Here is a link to the manual where you can read how to program the radio's frequency and interference eliminator code. http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5320_T5410_T5420_User_Manual_E.pdf
Roger Beep/Talk Confirmation Tone
When you turn on this feature, your two-way radio transmits a unique tone when you
finish transmitting. It’s like saying “Roger” or “Over” and lets others know you’re
finished talking.
• To enable Roger Beep/Talk Confirmation Tone, press and hold + (plus button) as you turn
your radio On. Now, when you release the PTT button, your set tone lets your
friends know you’re finished talking and will appear on the display.
• To disable the Talk Confirmation Tone feature, turn your radio Off and then back
On while pressing and holding the + (plus) button.
Posted on Jul 02, 2009
Why is humming coming from speaker when mic is keyed?
this is strange as most times if a proper transmit key is depressed , then the radio switches from receive to transmit , the mfg know this would cause some great squeal from receiver /transmitting so close to a receiver so the part that is the receiver is muted to keep this from happening , id say there is some fault in the part that does this muting of receiver
Apr 13, 2016 | Radio Communications
Talkabout MH230R does not Receive or Transmit on channel, can just Transmit (only clicks when Recieve) when programmed 2 channels higher (i.e. all radios on 5-3, one is on 7-3)
Strange. Could it be any of the radios are from different countries? The channels are not worldwide. For instance, Canadian radios are on different frequencies than USA radios. They look identical.
Dec 30, 2015 | Motorola Talkabout MH230R 2 Way Radio
Every time I press the talk button the radios show low battery icon and I'm not able to transmit on either radio. How can I rectify this problem?
Are you SURE that your batteries are up to snuff? I.E. when they have a light current load on them they are ok but as soon as you try to increase that current load they die off quickly. With two-way radios, the actual current drain depends on whether you are transmitting or in standby (receive) mode. Transmitting requires significantly more current than standby mode. So, I would look at what kind of batteries you are using. If they are a good name brand alkaline, check to see if they measure close to 1.5 volts with a voltmeter or check them with a battery tester to ensure they are good. If they are ni-cad or ni-mh rechargeable batteries, make sure they are rated at least 1200 mah (milliamp hour). I use Sanyo eneloop rechargeable batteries. They last a long time for me. One other thing, make sure your battery compartment is clean and there is no corrosion on the contacts the batteries are placed into.
Hope this helps,
Jim
Sep 08, 2014 | Uniden Radio Communications
Transmitter problem
See the Antenna connection and change the Power Amplifier.
Jan 13, 2014 | Motorola Talkabout SX900R Two Way Radio
Strange sound coming from walkie talkie, strange beeping
Most Motorola radios give a beep-beep when the batteries are low and need changing. Make sure to use a good brand of battery. One other thing to check for is leaking batteries, the crud with cut down on performance.
Oct 20, 2008 | Motorola Walkie Talkie 2-Way Radio
Not transmitting or receiving when plugged in
The head set is stuck in Transmit. try shutting off the radio and then plug in the headset then turn on the radio. some radios can since the presence of accessories but the accessories must be connected before powering on the radio.
Jul 21, 2008 | Midland AVPH1 Motorcycle Headsets 2-Way...
Model LXT 300 FRS/GMRS RADIO
There could be three (3) reasons why the display shows the battery icon at the top left side of the LCD display:
1. weak/undercharge/discharge batteries;
2. dirty/corroded/loose battery contacts/terminals; and/or
3. internal fault with the electronic sensing for battery level/state.
Corrective measures would require:
a. replace/recharge batteries. The rechargeable batteries need at least 12 hours of charging time;
b. clean, scrape, tighten (need to bend a little more towards the battery terminals) the spring/contacts of the battery holder;
c. (on the internal fault) your best bet might be to seek the services of a professional electronic technician since this would need familiarity with electronic components, their circuitry and diagnosis, perhaps a bit of soldering and the use of a DVM.
On the other hand, if the "low" is the "L" icon at the bottom right side of the display, this would indicate that the radio's transmit power setting (H/L - high/low). Transmit power level can only be changed in Channels 1-7 & 15-22. The radio will also auto change to lo power when batteries are weak.To switch to high power, press on the Menu button thrice or till "Pr" icon shows, press on the up/down to select H or L. To save & exit, momentary press the PTT.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 31, 2008 | Midland LXT303-A 2-Way Radio
Muting the sound
The sound produced by a Motorola radio when the mike is keyed refers to the "Transmitting Call Tone" which is another feature other than the "Interference Eliminator" or the "Roger Beep" feature.
On most Motorola GMRS/FRS TalkAbout radios, setting the "Call Tone" to 0 disables the feature. This is done with the radio ON by pressing on the "Menu" button 3 times which will result in the display showing the current Call Tone setting (flashing) and the letters CA; pressing on the <- or +> buttons will change selection (you will also hear the different Tones), select 0 (it may be up to 5 or 10 depending on the version). Press on the "Menu" or "PTT" button to set, save and exit.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Nov 25, 2007 | Motorola TalkAbout T5530 2-Way Radio
Motorola Talkabout T5420 (14 Channels) 2-Way Radio Logo
273 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
