Question about Ford 8n,9n,2n, Tractor Starter With Drive
Ford 601 cuts out few minutes after start up
My Ford 601 starts fine and idles great. I take it to the field and within 15 minutes it starts to cut out. I have taken the card off and cleaned out and replaced plugs. Still doing the same thing. Any help would be greatly appreciated.
  • 218 Answers
Hi..my name is Keith..and i restore 9N's,2N's and 8N's...but the systems are basically the same...so..you know and i know its either ignition or fuel..on the ignition side..i would suspect either the condensor or coil is breaking down when the engine gets hot...and on the fuel side..if you have already cleaned the carb..i would suspect trash in the fuel tank or trash in your sediment bowl and valve..which can be cleaned or replaced..i hope this will help..its the simplest thing to check or replace..if it didnt help..please write back
Posted on Jul 02, 2009
  • asring May 30, 2012
    There is a little bit of sediment in the bowl......besides cleaning out the bowl....what else do I do?
What goes a idle position sender do on a 97escort
Low oil pressure switch is designed to cut off engine to prevent damage. If you are sure oil pressure is good when light starts blinking, replace pressure switch. Idle position sender IDK.
Jul 21, 2016 | Ford Cars & Trucks
Fuel system running rich and stalling
Sounds like it is slightly out of time.
Apr 14, 2014 | Ford Cars & Trucks
Idle rough runs
usually that happens when your coil is getting old and weak and starts missing spark when it warms up
Oct 16, 2013 | Motorcycles
When i first crank the car it idles at like three or so then goes to zero and cuts of it does this a few times especially if i push the brake, i have learned to rev engine lightly and press brake and put...
Might be a leak on your brake booster (this will most probable give you a hard brake pedal or a "sucking sound " when applying brakes) also check the vacumm pipe from the engine to the brake booster. It might have a leak, so when you press the brakes it influences the air mixture.
Dec 14, 2012 | 2000 Nissan Maxima
'84 Ford Ranger cuts off after about 30 mins of driving.
sounds like the auto choke isnt turning itself off properly but to be totally honest i would need this to happen when i test drive it to diagnose it correctly .
Sep 01, 2009 | 1984 Ford Ranger
YKEHSO2RWHO starts o.k. but stop within a few minutes
that dryer has a moisture sensor probably is not sensing moisture
Jun 23, 2009 | KitchenAid KEHS02RMT Electric Dryer
Speedo will cut out when driving
Sounds like your "speed sensor" is failing. When it fails it will cause irregular shift patterns and engine idle speeds.
Jun 10, 2009 | 2000 Ford Focus
Ford 8n,9n,2n,  Tractor Starter With Drive Logo
529 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
