I should set the pressure switch that turns on the submersible well pump it was set when the valve to the house was closed and i used a hose to get down the pressure while adjusting it .it ended up around 30-60 cut in /cut off. the way i wanted now after opening the house valve its always on the lower side sometimes 42 or 34
Take the grey cap off pressure switch and adjust spring under bolt you take cap off with to make pressure adjustments
