Question about Refrigerators
Water is leaking from the bottm - Refrigerators
  • 4,070 Answers
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jul 01, 2009
Hsm25gfre sa
u need to replace the water inlet value
Apr 06, 2014 | Hotpoint Refrigerators
Why does frigidaire mrs26lgj side by side redfrigerator have water/ice in the bottm of the freezer
Hello - Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. Try confirming that the vales are tightened. If the connection is still leaking, turn of the water supply line to the water valve and take the connection apart. You can try using Teflon tape when retightening the connection to ensure a good seal. Should this suggestion prove to be ineffective contact a professional to properly diagnose the refrigerator.
Oct 19, 2012 | Frigidaire Refrigerators
Leaking - think from the bottm
The most likely cause is the drain pump located at the bottom front of the machine. Look at the pump for signs of leaking. You may be able to see it if you tilt the machine back. Some of these washers have an insulating piece on the bottom not allowing you to see the pump. In this case you would need to dissassemble the washer and remove the cabinet. Please rate this post.
Dec 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Why is my dishwasher. leaking from bottm of the door? It is aLXIH modle
first you need to make sure the d/w is not overfilling, if that is o.k. check btm washarm for crack or split. this will cause a water out the door btm problem.dont forget to vote,hope this helps you
Nov 30, 2009 | Dishwashers
Water comming out of the bottm of the freezer door i think the hole to the evaportor pan is frozen can i use a hair dyer to melt it an were is the evaportor pan
This is a very common problem and has several reasons that may cause the problem. I have a lot of information that covers the different ways that this takes place and how to to resolve the problem all on one page. So read the complete page and choose the part that most fits your refrigerators condensate overflow. Thanks, Sea Breeze
Click on link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 16, 2009 | Kenmore Refrigerators
My 2002 Impala has an A/C leak. The leak is on the driver's side around the top of the radiator but I'm unable to see the actual leak. Is this a condenser issue or possibly just an o-ring?
On my 2002 3800 V6 Impala the leak was at the bottom of the condensor on the drivers side. On mine the condensor connections were near the bottm driver's side. If you sure it's at the top, it's pretty certain to be the condensor.
I replaced my own. As I recall, the condensor was less than $100.
Jul 05, 2009 | 2002 Chevrolet Impala
My Maytag Neptune fnt loader Model# MAH9700AWW
I have a Maytag neptune mah8700aww
With mine the large grey rubber seal that seals at door slipped off! When this happens if you do not put back on correctly it will leak or even poor out the front center bottom of the door! My husband fixed it. But it still leaked really bad! I just took a couple of min. to refit the seal and it does not leak at all now! maybe your seal is not placed around the edge correctly! as it is easy to place it wrong! good luck!! keep my email address if I was helpfull!! We can always share problems and solutions for our neptunes in the future ! good luck
Anne Marie
Feb 27, 2009 | Maytag MAH6500 Neptune Front Loading...
Steam carpt cleaner
If water is leaking out the bottm, remove the top housing, and look for a water line that has come off or is cracked.
Jul 13, 2008 | Vacuums
Refrigerators Logo
392 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
