I'm trying to fix my alienware area 51-m laptop (766, about 5 years old). It was plugged into a surge protector and the phone line a couple years ago when the phone line was struck by lightning. The laptop didn't power on, no fans, no lights, no post. I recently got around to taking it into a repair shop to have it fixed. The guy said it needed a new motherboard (which is what I had already assumed) so I ordered one, and gave it to him. He says he put the new motherboard in, it powered up enough to give lights and fans but no post, and then died within a few seconds. Apparently he hadn't checked any of the other parts or even tested the motherboard with the bare minimum of parts before putting it all together. He claims some other part (he thinks the video card) is shorted and fried the new motherboard. I'm going to RMA the new motherboard, but is there a way for me to check the power supply to see if that fried it? It is a 4 pin, liteon pa-1161-02 20v 8 amp power supply. I need to know which pin is what normally. Thanks for your help and any other advice in advance!
  • drahcirdk Jul 01, 2009
    Thanks for your help Dageezer. However, I've already shelled out $80 for the motherboard, and they probably won't give me my money back, only a new board. The modem etc are all on the board, so the parts that were put back in were the processor, ram, video card, battery, screen and inverter, and cd/dvd drive. If he had put the parts in, I'd at least know which one had fried the new board. He didn't so now I'm trying to figure that out without frying the next board. Any ideas on how to identify the part without just putting them back in one at a time until it dies again? That's why I want to know which pin is supposed to be what on the power supply. Thanks again Dageezer and anyone else willing to help.
  • 3,940 Answers
Generally, portable power supplies are pretty rugged, and the items you need to be concerned with are what interfaces with the motherboard. Video card, RAM, Wireless, and Modem. If any of these were in the system during the strike, then they are suspect. If these componets are removeable, then booting without them in the new board it suggested. I would tend to agree, and a discrete video card would be toast after a lightning strike. This project may not be worth the cost in parts
Posted on Jul 01, 2009
    New Friend:
  • 10 Answers
First, I admit a certain bias against switching power supplies. Their only claim to fame is size and efficiency. Take that away and a cheap linear beats them in every metric... long term reliability, percent regulation, output noise and something solid you can drive nails with.
Anyway to answer your question...
1. Hold the Liteon PA-1161-02 output cable such that you are looking at its output pins.
2. Turn the cable such that the notch (indentation between pins) is on top.
3. The top two pins are connected or shorted to each other.
4. The bottom two pins are connected or shorted to each other, the shield (the shiny ring that surrounds all four pins) and to the ground or third pin of the power cord
5. Carefully connect a DC meter between one or both top pins AND the shield.
6. The meter should read approximately 20.35V DC when not connected to the laptop.
NOTE: If you could measure it, the output voltage should be less than 20.35V DC and more than 19.5V DC when connected to a turned on laptop or one that is charging its battery.
Posted on Sep 27, 2014
We have a telephone handset and base the Gigaset A265 which is not ringing in the house but going straight to our message system on our computer via our internet provider orange. We can call out but are...
Hello.
Reset the phone:
Unplug the battery in the handset, unplug the phone line from the base and unplug the electricity from the base. Leave everything unplugged for an hour or two instead of a couple to five minutes. That way you can get more of an idea of whether your phone will work. After an hour or two plug in everything. If resetting the phone doesn't work then try the next step.
Check the surge protector:
Is the phone line plugged into a surge protector? The surge protector may have stopped working or blown a surge, a sudden burst of electricity, which may have caused the dial tone in your cordless phone to go. Unplug the phone line from the surge protector then plug it back in and see if you get a dial tone. It could be that the phone line plugged into the surge was loose or not plugged in securely.
Try a different phone plug, outlet.
Check the base:
Is the base dusty and have possible dirt in the prongs where the phone sits? Lift the base and blow off dust.
Check the handset for dirt.
Rub metal connections on handset and base:
Use a pen cap or coin and rub the metal connections on the bottom of the handset. Rub the prongs, metal connections on base.
Hope these suggestions help.
Sep 01, 2011 | Siemens Cell Phones
My DECT6.0 telephone will not give me a dial tone nor answer any calls neither will the additional handset..Although my verizon direct line functions as it designed
Hello.
Here are some tips, found online:
Reset the phone:
Unplug the battery in the handset, unplug the phone line from the base and unplug the electricity from the base. Leave everything unplugged for an hour or two instead of a couple to five minutes that way you can get more of an idea of whether your phone will work. After an hour or two plug in everything. If resetting the phone doesn't work then try the next step.
Check the base:
Jul 25, 2011 | Uniden Cordless Phone
I had a power outage a couple nights ago, which has caused my television to not turn on. It is a Toshiba model CZ27T31, which was off & plugged into a surge protector at the time the storm knocked the...
Please check if your surge protector is working properly now. There is possibility that the surge protector is blown off due to high voltage surge. Check if your surge protector has a reset switch which some of the surge protectors have. If the problem still persists then you have to call the technician to replace the safety fuse which is inside the TV. The cost will not be much. I will personally recommend that you change your TV as it has outlived its life being 10 yrs old.
Aug 10, 2010 | Toshiba Televison & Video
Alienware Area-51 7500 R5 BIOS AHCI problem
I changed mine by hitting F12 at boot screen. that brings up a menu where you can change boot methods
Jul 09, 2010 | Alienware PC Systems Alienware Area-51®...
No dail tone --but phone line is connected
Hello.
If the dial tone is not heard check the volume. It may have accidentally been muted or turned down.
Is the phone line plugged into a surge protector? The surge protector may have stopped working or blown a surge, a sudden burst of electricity, which may have caused the dial tone in your cordless phone to go. Unplug the phone line from the surge protector then plug it back in and see if you get a dial tone? It could be that the phone line plugged into the surge was loose.
If the other phones on that line work OK, disconnect all the phones connected to the line, leave them all disconnected for 3 minutes, and then connect one at a time.
If still a problem and the other phones on that line work OK, give this a try:
Unplug the battery in the handset, unplug the phone line from the base and unplug the electricity from the base. Leave everything unplugged for an hour or two. That way you can get more of an idea of whether your phone will work. After an hour or two, plug in everything.
Hope this helps.
Jan 04, 2010 | Uniden 2.4 GHz Expandable Phone System...
Blinking standby light, dead dvd player
Hello illeanaceres,
I'm sorry to hear about the bad news, I had something similar happen to me around a month ago.
Honestly there is not much you can do if it is damaged due to a power surge. Resetting it would be the normal procedure.
Surge protectors only protect equipment up to a certain amount of joules. Basically if the lightning is powerful enough it can damage electronics with that initial surge. You should replace your surge protectors every few years if it is 2-3 years old then it may not be as effective.
Post back if you have anymore questions or comments. Thank you for choosing Fixya!
Jul 13, 2009 | GPX D1816 DVD Player
The computer does not work I was told buy a tech person it would cast $500. to fix I said no way. what does it cost for a D900T motherboard. My computer is a look a like of Alienware computer laptop 17"...
Well he wasn't that far off.
Motherboard : $359
Labor: $160
Total = $519
Unfortunately, because laptop motherboards on fit in a very few select machines, their prices are much higher. And, since it is an Alienware, the price is higher still. In fact, the cheapest I found is what I quoted for you and it is a used one and I even discounted labor since replacing a laptop motherboard can take several hours, I only charged 2 hours max even though it is likely to take 3 - 4.
Jul 01, 2009 | Alienware PC Systems Laptop Keyboard for...
Computers & Internet Logo
370 people viewed this question
Alun Cox
David Payne
David Payne
