Question about Akai LCT2070 20 in. EDTV-Ready LCD Television
    Problem Solver:
  • 7 Answers
Re: akai problem
You have a bad power supply. Just replace it and you should be good to go. The green light may come on the black box, but the supply is putting out a low amp value.
Posted on Mar 07, 2009
0 characters
3 Points
My akai television won't turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 16, 2014 | Akai LCT2715 27 in. LCD Television
AKAI PDP5006H Plasma tv
1) Is the TV plugged directly into an outlet or is it plugged into another device, such as a cable box or audio receiver? If it is, try plugging directly into a wall outlet. Sometimes, devices like cable boxes don't provide enough current to power on more powerful newer TVs (like Plasma, LCD, etc) .
2) Check the manual to see if the flashing LED is a code for something you need to troubleshoot. The number and color of flashes may correspond to a problem that may or may not be easily fixed.
Hope that helps. Let me know how you make out.
Jan 15, 2008 | Akai PDP-5006HRB 50 in. Plasma Television
My lct2662 will not turn on. The indicator light
Did you get this fixed?Please let me know.Thank You very much!
Mar 12, 2010 | Akai LCT2060 Television
Akai lct 2701td comes on then shuts down
You have power supply problem. Please go to ebay and buy cheaper price:
Mar 11, 2009 | Akai LCT2715 27 in. LCD Television
Remote that came with tv wont work
I stumbled across this page while the owner's manual for my remote was lost. I've now found the manual (after not having any luck finding the solution on the web)!
The AKAI KC02-D2 remote operates my AKAI PDP42Z5TA 42" Plasma HD Television. It may work with others as well, but that's the TV I use it for. If the batteries are removed (or dead) for a while, it will lose its programming. Here's how to reprogram it.
AKAI = 231, 218, 221, 222, 225, 226, 227, 228
1. Turn on the Device you want to program. The remote can be programmed by pressing the 3 Digit Brand Code number listed in the code table of this programming guide. If multiple codes are listed, you may have to enter several codes to complete the steps below. (Note: For programming the VCR, a tape must be loaded/inserted first.) If your Brand is not listed, please use the Manual Search menthod or Auto Search method (Section C & D below).
2. Press and hold the SET button for about 3 seconds until the current Device LED lights (TV, VCR, DVD, STB.), then release the SET button.
3. Press the device button you want to program (TV, VCR, DVD, STB.) then the selected Device LED will light on.
4. Enter the 3 Digit Brand Code for the desired Device. For example, enter "2" "1" "8" for AKAI TV. When entering each digit, the Device LED will flash one time. After all 3 digit numbers are entered, the Device LED will turn off. If the code is not valid, the Device LED will flash three times then turn off. Check the code list and repeat from the above step 2.
(*The manual contains a huge list of 3-digit codes for various devices. If you're looking for a specific one, just ask.)
Nov 22, 2008 | Akai LCT3215/26 32 in. LCD Television
Akai LCT2701TD Won't turn on. Red light in front blinks.
There is a high power supply failure rate on these LCDs. The power boards are not longer being manufactured or not easy to find.
Write to for more info.
Sep 14, 2008 | Akai LCT3201AD 32 in. LCD Television
The power supply on your LCD failed and will need to be replace or repair.
Let me know if you need further assistance.
Aug 28, 2008 | Akai LCT3201AD 32 in. LCD Television
Akai tv wont come back on
Nothing......bad capacitors in power supply need replacing.....T.
Jul 16, 2008 | Akai LCT2716 27 in. LCD Television
Akai cftd 2011
Power supply, replace C31 (1000 25v), C32,and C35 both (1000 Uf 25v) and C33 (680 Uf 25) and it should be good as new...
Dec 01, 2007 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Akai Plasma TV's screen suddenly went blank -model PDP4294
Same thing for me. TV just turned off one day and won't come back on. LED flashes red. Someone said it's because a cooling fan went out. If I can't find someone to fix it I'll take it apart and tinker myself. 32" with dvd built in was barely over a year old.
Nov 04, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai LCT2070 20 in. EDTV-Ready LCD Television Logo
245 people viewed this question
Top Akai Flat Panel Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Akai Flat Panel Television Expert? Answer questions, earn points and help others
