Question about HP Compaq WF1907 Monitor
NO SOUND FROM MY WF1907 MONITOR
I USED TO USE A PAIR OF EXTERNAL SPEAKERS BUT THEY GOT LOST IN MY MOVE. HOW DO I GET THE SPEAKER DRIVER FOR THIS MONITOR?
    Scholar:
  • 103 Answers
Check on the back of the monitor for headphones plugs or cables.
Posted on Jul 01, 2009
  • 83 Answers
Go to the makers website and search for driver!!swampratt200!!AAEE!!!!
Posted on Jul 22, 2009
The speakers no longer work. They were working 2
selectbanker, As a test only try this. Remove green plug from rear of pc. Find old am/fm stereo transistor radio or even a portable cd player and connect the green plug to your "new" audio source. Can you hear anything coming out of the monitor's speakers? Also try a set of stereo headphones in the green audio "out" jack to see if sound is coming out of the pc. Narrow down where loss of signal occurs first. 12fixlouie
Apr 07, 2010 | HP Compaq WF1907 Monitor
No sound from monitor speakers
Make sure that Green output is plug into green input on sound card and make sure the power is going to the speakers.
Nov 28, 2009 | HP Compaq WF1907 Monitor
I have a Sceptre X7G Komodo II 17" LCD monitor/built-in speakers
You would need to connect the speakers to your computer. There should be a little jack on the back of the monitor marked audio. This will need to be connected to your soundcard jack for front speakers. Once this cable is connected you should have sound from your speakers. Hope this helps.
Aug 15, 2009 | Sceptre X7G Komodo II 17 in. Flat Panel...
No sound..relocated computer, thought everything is hooked up.
Make sure the speaker wire to the computer is to the lime green plug on the computer and power to speakers and make sure volume control on the computer is not muted
Aug 07, 2009 | HP Compaq WF1907 Monitor
Junky speakers
One of the speakers is blown so unless you can find a replacement speaker for the blown one then you have to either buy a set of other speakers to replace the speakers in the monitor or buy speakers you can hook up to output of the computer.
Jun 18, 2009 | HP Compaq WF1907 Monitor
Low volume sound
I was afraid of that. The speaker system is only half in the monitor the other part(Amplifier section) was in your old computer. Here is a possible solution. Buy an external sound /speaker system. The amplifier comes with it and many can be had at a reasonable cost at **** places as  Walmart , target ,etc. Sorry. but the speakers on  your monitor, I believe ,  will not work with you new computer. Sorry.
Mar 09, 2009 | HP Compaq WF1907 Monitor
My sound system stopped working
what PC, non stated , only that old monitor
that monitor is 16 years old today, wow , 99% are dead now
long ago, dead when the CCFL lamps burned out long ago
you be lucky it works at all, a fact.
no the USB port is not sound, but they sell USB speakers and head phones that have its own sound system (CHIP_) total that replaces
the sound in your unstated PC, (but is topic 2 not #1)
lets do sound blind, I cant see your pC can I, no photos
or names or models or what cables are attached can I, now.
so sound 101: day: (forget USB for now, ok?)
1: my guess is desktop of some kind, (i use a monitor on a laptop)
2: remove all usb devices now, cept keyboard and mouse.
3: now see rear of PC, see those 3 or more 3.5mm phone jacks.?
sure, see that green round phone jack, that is LINE out.
1.5mm diameter it is, (no set of pins , no USB this)
if you connect ear buds or a real phone jack head phones this works now, (does it , bugs are 1 buck at the dollar store)
eg: click control panel of your unstated windows, click sound
click speakers, mine has many speakers to chose, 7.1, but if old PC it has one speaker click that,. (mine is fancy express sound card,with surround sound, so can yours if you buy the card)
then click tab called,sounds , see asterisk. and test button
this is the best way to test sound first. only this.
This is built in to all windows made. all.
and always works if the sound driver is present.
if the test button fails to work at all. is gray out that is windows way of telling you the sound driver is borked up, missing or corrupted, one of my PC run linux, so.... that be different...
lets say you get this far, ok?
4: lets say a real head phone works on the 1green jack. it must.
forget USB for now, that is advanced stuff that MS does not support but can function good with hard work later.
5: now that monitor or any external speakers sold are all ampified speaker,, no they are NOT just speaker with only a voice coil inside. not at all.
the monitor needs that 3.5mm cable attached,
the amp in the monitor must be accessed, just like real exteral speakers that same do.
on the monitor,here I will read your manual to you now.
so can you why not do that first??????
6:push the menu button on the monitor to get to sound volume/
the FP5012 as a 2watt amp inside that can fail
or someone reset the monitor and the reset puts volume to 0
zero.
the jack is named on mon.
1 x audio - input - mini-phone stereo 3.5 mm - 1
why not just by new external speaker kit (amplified for PC)?
spend like $10?
i found your manual, want it? push center button now.
push menu choice (OSD) 5 , for sound volume
bingo? page 15, in dah manual.
omg, its got its own button on front of mon.
its not in the OSD on this monitor as is most.
http://www.manualsdir.com/manuals/67592/compaq-5017.html
end stock sound systems.
USB is a totally different and more complex topic,
as all USB devices can be, MS even has a warning on the use of these usb sound devices, ask and can send it to you
in short MS says zero support on them ask your vender for that.
do not run onboard sound with USB sound or they will fight each other, until you learn how to control that, ask. we do it all the time here.
ok here is the V button set, below. if this fails
and buds work, the monitor is BAD.
if the buds fail the PC is messed up, (USB not used)
cost of testing $1 (buds)
v-y5lcaykkf42lwqqbpm0ein5s-3-0.jpg buds means ear buds, sold in just about all stores now.
for nada, get some keep them handy of cheap testing.
Jan 18, 2018 | Compaq FP 5017 15" Flat Panel LCD Monitor
Using a Compaq WF1907 monitor with a Playstation3
No. HDMI transfers picture and sound, but DVI does not. You need a audio line as well.
Oct 25, 2008 | HP Compaq WF1907 Monitor
Re No sound from monitor speakers
Thanks for the info,
Ok heres what I would doo to fix this.....
Get the original disk with the drivers on it and reinstall it.
If you don't have the disk then you will have to ......
(unplug sound card - if its a plug in)
Remove the cables,check for model and make,download from net.
or
if sound on motherboard then download the model and make also.
You will have to load the downloaded drivers on to a disk.
2.update your device drivers and point the wizard at the disk,
Reboot and that should be it sorted,
Thanks and let me know the outcome,Cheers
try this site.....
http://www.opendrivers.com/driver/211081/sound-blaster-audigy-driver-5.12.4.252-windows-98se-2000-xp-free-download.html
Jul 24, 2008 | HP Compaq WF1907 Monitor
Dgm monitor no sound through speakers
have you got the correct leads plugged in?
have you removed and reinstalled the device???
Have you got another set of speakers to try???
HP Compaq WF1907 Monitor Logo
394 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
