Question about HTC Touch Pro Smartphone
Cant access the INTERNET thru wi-fi!!!
When i turn on the wifi on my htc touch pro, it detects any available network and also connects to it..... but i still cannot access any internet application.... my email, or any web page i type in from the opera browser, it says ERROR, cannot connect to the internet, etc, or something along those lines...... whats the problem? iv checked all theoptions on the phone, everything seems to be in order... anyone have any idea wats goin on with my stupid phone?
  • sidreenia Jul 08, 2009
    i checked the proxy server, tht was all related to the mobile connection i use, not the wifi... and i keep switching from connect to the internet to connect to work, and still none of the internet applications work although i continue to get successfully connected to the available wifi network
I solved this by configuring the phone settings to REMOTE-NDIS HOST on the tab "Configure network adaptors". Select this, press OK and add your network password (if any).
Rico.
Posted on Aug 20, 2009
    Scholar:
  • 136 Answers
Go to "settings" then at the bottom connections then click on "wifi"
this will take you to the screen where all available connections are located. Click on the connection you want to use and in the "CONNECT TO:" block click on "the internet".....keep in mind if you change from home to work using different wifi connections you also have to change or update those connections as well.
Posted on Jul 07, 2009
  • 813 Answers
Make sure that the proxy server settings are correct in your phone.
Posted on Jul 02, 2009
  • 56 Answers
Check the status of connection and check the driver curruption ........
if necessory update drivers ....
  • 1 more comment
  • pawan warkade Jul 02, 2009
    check the status of connection and check the driver curruption ........
  • Tina Tait
    Tina Tait Sep 29, 2012
    Hi none of the solutions so far has worked on the wildfire s. This has happened to me since I did the last update
  • Debbie Vause
    Debbie Vause Feb 07, 2013
    did u ever get this sorted ?
HOW TO CHANGE THE INTERNET SETTINGS IN THE HTC WILDFIRE A3333
Wi-Fi provides wireless Internet access over distances of up to 100 meters (00 feet).
To use Wi-Fi on your phone, you need access to a wireless access point or "hotspot". The availability
and range of the Wi-Fi signal depends on the number, infrastructure, and other objects
through which the signal passes.
Turning Wi-Fi on and connecting to a wireless network
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless
networks.
Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks
are displayed in the Wi-Fi networks section.
If the wireless network you want to connect to is not in the list of detected networks,
scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network
settings, and then tap Save.
Tap the Wi-Fi network you want to connect to.
If you selected an open network, you will be automatically connected to the network.
If you selected a network that is secured with WEP, enter the key and then tap
Connect.
Depending on the network type and its security settings, you may also need to enter more information
or choose a security certificate.
When your phone is connected to a wireless network, the Wi-Fi icon appears in the
status bar and tells you the approximate signal strength (number of bands that light up).
The next time your phone connects to a previously accessed secured wireless network, you
will not be prompted to enter the key or other security information again, unless you reset
your phone to its factory default settings.
Jan 28, 2015 | HTC Wildfire A3333 Cell Phone
Tip
How to Speed Up Internet on my Touch Pro 2?
<p>The HTC Touch Pro smartphone 2 is avaialble for T-Mobile and Sprint subscribers, and uses the data network cell phone to connect to the Internet. While the Internet connection is based on a strong 3G connection for fast browsing, you can also activate the Wi-Fi device to connect to a wireless network. Available Wi-Fi networks within range of the Touch Pro will be displayed on the device are on the list of networks. Once connected, your Internet speed is capable of data based on the strength of the wireless signal to send. <br /> <p><br /> <p>1. Slide your finger on the "Home" screen to the tab "Settings" appears. Play the "Communications" button. <br /> <p><br /> <p>2. Touch "Wi-Fi" on the phone screen, then hit the wireless network is displayed in the "Discovered Networks" list. <br /> <p><br /> <p>3. Type the network security key using the onscreen keyboard, and press "Done" for the network to connect. A wireless signal appears at the top of your phone screen when connected to Wi-Fi network successfully <br /> <p>4. Touch "Back" to return to the "Communications" menu. <br /> <p><br /> <p>5. Play the "ON / OFF" in "communication" from the menu for Wi-Fi off. It is important to turn off the Wi-Fi functionality when not connected to a wireless network, because this mode the battery is not on. <br />
on Aug 09, 2011 | Apple iPod touch
I am trying to do the wifi protected setup with the 8 digit pin it gives me, I get the pin press the wifi ps button, it fails everytime. what are the correct steps to take please help. Alcatel One Touch...
What is giving you the 8 digit pin is it coming from the wireless router or wireless network provider ?
on your phone
To turn Wi-Fi on and connect to a wireless network
Drag down notification panel and touch
to access
Settings
Touch the switch
beside Wi-Fi to turn on/off Wi-Fi.
Touch
Wi-Fi
, the detailed information of detected Wi-Fi networks is displayed in the Wi-Fi
networks section.
Touch a Wi-Fi network to connect. If the network you selected is secured, you are required to enter
a password or other credentials (you may contact your network operator for details). When finished,
touch
Connect
Nov 02, 2014 | Computers & Internet
My ipod recognises the wifi network but can't connect
The iPod touch has the ability to connect to Wi-Fi networks, giving you access to information while on the go.
The iPod detects both protected and unprotected networks, and can remember which Wi-Fi networks you have used before, eliminating the need to enter passwords more than once.
Your iPod touch should automatically detect wireless networks, but you can also manually connect to a network or switch to a new one.
Tap the "Settings" icon on the home screen and tap the "Wi-Fi" button.
Tap the "On/Off" button to turn your Wi-Fi on. Press the "Home" button to return to the home screen.
Tap the Safari Web Browser application or any other application that requires Internet access.
A list will automatically open on your screen that names all available networks.
Tap the network you wish to use from the list.
The networks listed are all wireless networks detected by the iPod.
Protected networks will have lock icons to the right of their names.
Enter the password if the network you have selected is protected.
Your iPod touch will store this password for future use.
Type in the name of the network you wish to use if it is not listed.
A network that is set to not broadcast will not show up on the list of available networks.
Check the top left of the screen for the Wi-Fi icon to be sure you have connected.
The number of bars on the icon indicates the strength of the signal.
Manually Connect
Tap a network listed under "Choose a Network..."
A network set not to broadcast will not show up on the list of available networks.
http://support.apple.com/kb/HT2031
Nov 15, 2013 | Apple iPod touch
Ipod will not connect to wifi
Connect to WiFi for Your Apple iPod touch b> The iPod touch has the ability to connect to Wi-Fi networks, giving you access to information while on the go. The iPod detects both protected and unprotected networks, and can remember which Wi-Fi networks you have used before, eliminating the need to enter passwords more than once. Your iPod touch should automatically detect wireless networks, but you can also manually connect to a network or switch to a new one.
Tap the "Settings" icon on the home screen and tap the "Wi-Fi" button. Tap the "On/Off" button to turn your Wi-Fi on. Press the "Home" button to return to the home screen. Tap the Safari Web Browser application or any other application that requires Internet access. A list will automatically open on your screen that names all available networks. Tap the network you wish to use from the list. The networks listed are all wireless networks detected by the iPod. Protected networks will have lock icons to the right of their names. Enter the password if the network you have selected is protected. Your iPod touch will store this password for future use. Type in the name of the network you wish to use if it is not listed. A network that is set to not broadcast will not show up on the list of available networks. Check the top left of the screen for the Wi-Fi icon to be sure you have connected. The number of bars on the icon indicates the strength of the signal. b> Manually Connect Tap the "Settings" icon on the home screen and tap the "Wi-Fi" button. Tap the "On/Off" button to turn your Wi-Fi on. Tap a network listed under "Choose a Network..." The networks listed are all wireless networks detected by the iPod. Protected networks will have lock icons to the right of their names. Enter the password if the network you have selected is protected. Your iPod touch will store this password for future use. Type in the name of the network you wish to use if it is not listed. A network set not to broadcast will not show up on the list of available networks. Check the top left of the screen for the Wi-Fi icon to be sure you have connected. The number of bars on the icon indicates the strength of the signal.
b>
Feb 06, 2013 | Apple iPod Audio Players & Recorders
How do i set up wifi
To set up Wifi connection on HTC Smartphone:
  1. Press HOME
  2. Press MENU
  3. Tap Settings then Wireless controls
  4. Select the Wi-Fi check box to turn Wi-Fi on. The phone will scan for available wireless networks.
  5. Tap Wi-Fi settings.
  6. Select from the displayed network detected.
  7. Tap a Wi-Fi network to connect. If you select an open network, you will be automatically connected to the network. If you select a secure network, enter the key and then tap Connect.
Jul 02, 2011 | HTC F3188 Smartphone
WiFi just scans but does not find any available networks to connect to??;le
Hello Derek,
Connecting Wi-Fi in HTC Desire Cell Phone
From the Home screen, press , and then tap Settings > Wireless & networks.Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless networks.Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks are displayed in the Wi-Fi networks section.If the wireless network you want to connect to is not in the list of detected networks, scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network settings, and then tap Save.Tap the Wi-Fi network you want to connect to. If you selected an open network, you will be automatically connected to the network. If you selected a network that is secured with WEP, enter the key and then tap Connect.
Jun 02, 2011 | HTC Desire Cell Phone
How do i get my phone to connect to the internet
You must have internet service, example an anything data plan. Then all you do is tap on the internet ball and it conects.
May 24, 2011 | HTC Desire Cell Phone
Wont let me get on the internet
First and foremost: are you in a WiFi area? The iPod touch can only access the internet when it's able to connect to a WiFi network. In order to browse availible networks where you are follow this: Click "Settings" Click "Wi-Fi" And under "Choose a network" it will come up with a list of networks you can access. Just click on one, hopefully yours!
And make sure that Wi-Fi's on/off button is switched to "On".
May 23, 2009 | Apple iPod touch Second Gen (8 GB,...
Wifi issues
i think there is some kind of block from the network administrator
usually you can access wifi easily with out any problems.
di u install any third party application in your phone recently??
Sep 17, 2008 | HTC Touch P3450 Smartphone
HTC Touch Pro Smartphone Logo
427 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
