Question about Frigidaire FTF2140FS Front Load Washer / Dryer
My washer is holding water where you put bleach or softener after cycle is done. Help!
    Brigadier General:
  • 3,006 Answers
Remove the detergent drawer from the machine, the instruction book will tell you exactly how to do so, but usually you pull them out as far as possible and then push down on the rear centre top of the drawer to flex the plastic slightly to allow the drawer to come all the way out.
The softener/bleach compartment has a siphon built into it and this gets blocked, normally with a black scummy deposit made of microbes and softener residues. You need to clean out as much as you can, you may need a cotton bud to reach deeper crevices. It's usually possible to unclip the siphon from the drawer; it looks like a kind of lid partway over the rear of the softener compartment. If you can get it off you'll normally see two dead ended vertical tubes which are vertical and the top one fits over the lower one. Clean both thoroughly inside and out.
Reassemble and put the drawer on your sink drainer. Fill the softener compartment with water: it should drain out via the siphon if you've cleaned it enough.
Refit the drawer to your washer and in future clean it out every couple of weeks or weekly in the summer.
Posted on Jul 01, 2009
  • Obertelli
    Obertelli Jul 02, 2009
    Correction: "If you can get it off you'll normally see two dead ended vertical tubes"
    Sorry, this was a mistake. The wider top tube is dead-ended, but the lower tube which passes up and into the upper tube is not dead-ended. it's a siphon, so the water has to be able to escape from it!
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
Washer Feels like there are gallons of water in the bottom
Hello Holly Davis -
Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. Try setting the cycle to spin only and verify if water pumps out. If it does not, then the unit could possibly be experiencing an issue with a faulty pump, timer, door lock assembly or control board. Contact a professional to move forward accurately. However, regarding the odor my advice to you is first rub some bleach around the door gasket. Let this dry. Next rub some vinegar around the door gasket. Let this dry. (Do NOT mix the bleach and vinegar) Then run a hot empty load of bleach in all three dispensers. Put 1/2 cup of bleach in the detergent dispenser and fill the softener and bleach dispenser to the max fill line with bleach. Once that is done repeat the process with vinegar. Please make sure you run a load of towels or some sort of items that will not matter if you get a little bleach on them once this process is done.
Dec 11, 2012 | Frigidaire ATF6000ES Front Load Washer
After cycle, water is in the softener and bleach
Water floods the dispenser compartments at the start of the cycle to dilute/dissolve the softener, bleach, and detergent. The reason why water is in the compartment after the cycle is that, the detergent, the softener, and/or the bleach does not flow into the tub properly. It's either the dispenser assembly is clogged or excessive amount of detergent, softener or bleach is used. Clean the dispenser assembly and make sure to use no more than two tablespoons of powdered HE detergent or one-and-a-half ounces if liquid HE detergent.
  1. Unscrew the two screws on the back of the top plate then pull it back then upward.
  2. Pull out the dispenser drawer.
  3. Unscrew the two screws then push the dispenser assembly out.
  4. Unscrew the nut at the lower part of the dispenser.
  5. Remove the four connectors from the valves.
  6. Unscrew the two screws from the back of the cabinet.
  7. Reinstall the dispenser assembly in reverse order.
Dec 30, 2009 | LG WM-2277HW Front Load Washer
Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
Nov 13, 2009 | Maytag Washing Machines
Bleach and softener is going in with it's cycle
Pour a pot of boiling hot water through the softener side. Try this a couple times. Let me know how it works.
May 29, 2009 | Kenmore 43042 Front Load Washer
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
Dispenser
add water to them and then it will work
Feb 20, 2008 | Bosch WFMC 3200 Front Load Washer
Bleach and fabric softener don't dispense
pull the top off the washer and check the connector on the motor at the dispenser then ohm the motor where you removed the connecter let me know what it is should be 1400 ohms
Jan 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire FTF2140FS Front Load Washer / Dryer Logo
237 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
