Question about Porter Cable Tools & Hardware - Others
Where can I get a 1/4'collet for porter cable router model 690
  • rlpaddock Jul 02, 2009
    I live in Ontario Canada. Northwest of Ottawa.
    Postal code is K0J 1S0
    My manual shows the item I want as a 1/4" Collet Assembly that includes the collet,nut, and snap-ring.I require the full assembly.
    Do you have a list of repair centers in my area that I could contact?
    Thanks for the help.
    Ron
  • 2,176 Answers
I show the part number as 42999 for the accessory and they also list 876669 for the 1/4 collet. Give me the general area with zip code and I will try and find someone locally that can help you
Posted on Jul 01, 2009
  • David Ford
    David Ford Sep 09, 2009
    Just found your reply, sorry don't know where is was but tried finding somebody in Canada with no luck, Suggest going to Dewaltservicenet.com and click on the Porter Cable in the header and then on finding a service location. Hope this helps and also they might be able to ship if you place the order online.
How do I change bits on P/Cable 690LR?
If the collet was tightened without a bit in it, it may have been squeezed so it is too small for the bit shank. Completely unscrew the collet from the router and see if the bit will go into it. If not, you can try forcing an old bit in using your vice, and then using as hammer and punch to remove the bit, but most likely you will have to get a new collet. Just search "Porter Cable router parts to find a source.
Jul 19, 2014 | Porter Cable 690LR Router
How to remove the chuck from a porter cable router?
To remove the collet (not the collet nut) you must first take apart the armature from the field.
To do this,
1. Take the cap off the top by removing the two Phillips screws.
2. Remove the two brushes.
3. Remove the two Phillips screws hidden under the cap.
4.The only thing holding the top and bottom pieces now is a friction fit of the bearings. Tap with a non marking hammer on the top housing underneath the brush holders, and it should come apart after a few taps.
5.Use an armature split sleeve and put the armature sleeve in a vice to hold the armature.
6.Then use a wrench and unscrew the collet from the armature.
7. Just reverse this process to put it back together.
May 22, 2014 | Porter Cable Tools & Hardware - Others
My porter 1/4" router
Have you tried taking out the collet and cleaning it and the cavity where it goes? If there is any wood dust present it may be causing the problem. If that doesn't fix it, you may need a new collet.
Sep 06, 2011 | Porter Cable 690LR Router
Can the 1/2 collet be replaced with a 1/4?
A collet reducer or 1/4" collet may be available from service centers
Feb 26, 2011 | Porter Cable 7519 Speedmatic 3 1/4 Peak Hp...
Porter cable 7310 has broken spindle lock. THis is a brand new router and the spindle lock pin is broken and the motor will not spin. what is the best way to fix this
you would have to remove the bottom section of the motor housing. this would require removing the collet nut and the screws holding the housing in place. I would suggest going to "dewaltservicenet.com" and downloading a breakdown before attempting. It is not really that hard if you are mechanically inclined. The pin is more than likely jammed into the armature shaft that locks and that is why the motor won't turn. Let me know if you need more assistance.
Feb 20, 2011 | Porter Cable 7310 Laminate Trimmer
How do you remove collet from porter cable router model 690 I have purchace a new 690 to mount to a mortise lock base and need to remove collet, the shaft threads onto the router where the collet is,
I would suggest going to Dewaltservicenet.com and typing in your model number for an owners manual for this tool. If you still need more help let me know and I will try.
Oct 01, 2009 | Porter Cable 690LR Router
Slipping Bits
Any time I have ever come across this problem over the years the cause of it is a damaged collet due to overtightening. The solution is to replace the cone shaped piece ( the collet ) and take care not to overtighten in the future.
Sep 16, 2008 | Porter Cable 1 - 3/4" Hpfb Router with...
Laminate Trimmers Troubleshooting
Changing Bits: 1. Unplug the tool. 2. Turn the knobs on either side of the tool to loosen the base. 3. Remove the base. 4. Press the spindle guide to lock down the shaft. 5. Use a wrench to loosen the collet. 6. Remove the bit and collet. You may have to tap on the collet to loosen; careful not to tap on the cutting edges of the bit. 7. Insert the new bit and collet. 8. Use a wrench to tighten the collet into place. 9. Replace the base.
Aug 27, 2008 | Porter Cable Porter-Cable 309 Factory...
How to adjust the collet easily?
Look for a button that will lock the collet in place. This will allow you to adjust the collet with a single wrench, without having to wrestle with several wrenches.
Aug 27, 2008 | Porter Cable 75300 Height Adjustment Knob...
Tools & Hardware - Others Logo
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
