Question about Maytag MZD2766GES Side by Side Refrigerator
MZD2766GES: How do I level the doors?
I can't find our manual and our doors are not level. The fridge side needs to be raised. Can you walk me through the process? The manual is not available on the Maytag site.
  • 89 Answers
The door needs to be level, or the whole side of refrigerator. Pull off black strip at bottom front, there should be screws on either side to level the fridge. goodluck
Posted on Dec 16, 2007
My brand new fridge, one door style will not self close.
front raise 1 or 1 1/2 inches the side that is the door hinge side is 1/2 inch higher then the handle side. Tilt it on a slit angle towards the way that will force the door with the added weight of food on door shelf's. A perfectly level fridge is a useless fridge. If its only mission is for the doors to close from the maximum range its able to open.
Mar 16, 2017 | Refrigerators
How do i lower the rear wheels? The back end sits flat on the floor but the front is raised higher because the nylon wheels are fully retracted. I will also need to level out the fridge.
set the level that backside of the fridge must be lower than front side,so that doors may,must be closed automatically after open the fridge
Jul 08, 2014 | Amana ASD2620HRW
Refrigerator door closing automatically
Most refrigerators have the opposite problem with little kids pulling the door open then walking away leaving the door open. You can resolve this issue by raising the refrigerator up slightly. .it's helpful to have 2 people for this task. On the front of the fridge on each corner or there of. There are a adjustable leg and by adjusting the leg in you will change the level of the fridge. The farther they are turned out the fridge will lean back and that will with the force of simple gravity make the door close on its own without any help the further in the legs are turned the fridge will lean towards the front. But with some help you can make the cabinet of the unit perfectly level then when you open the door it will stay right where you leave it
Jun 11, 2014 | managemylife.com
The fridge door won't close all the way , is there an adjustment on the hinges
Check the bottom fridge door hinge. There should be two plastic cams, one that mounts to the door and one that mounts to the hinge. From your discription it sounds as if thoes cams have broke and need to be replaced
Sep 01, 2011 | Maytag MZD2766GES Side by Side...
The refrigerator door will not stay close. Is there an adjustment that needs to be made? How can I fix this??
Check the magnet seal around the inside pf the door and make sure they are grabbing. You can put the front legs of the fridge down a little more so it gives the doors a back swing when closing. Make sure your hinges are set plume (level) of the doors will not close right at all. Kids hanging on the doors will do this.
Mar 21, 2011 | Maytag MZD2766GES Side by Side...
MZD2766 fridge light works but the fridge does not
The only thing you need to do is let us test the auto vent. Yes you may need to take it out but it has a thermostat built into it. Drop the pig tail in cold icy water and warm the thermostat pigtail. If door does not open or shut replace it.Tell me your freezers temp?
Sea Breeze
Jan 17, 2010 | Maytag MZD2766GES Side by Side...
Door not closing properly
Hi: The Kitchenaid refs. us a gravity close along with the magnets in the door seals. Magnets getting weak seals getting old and what you told me you checked can cause this. The easy fix is to raise the front of the fridge by lowering the front wheels. Pull the grill off the front and find the leveling screws (usually labeled.) Raise the front of the fridge until the doors swing shut with a gentle push. Before you replace the grill make sure the fridge dosn't rock side to side as you want it even. This is what they call leveling a fridge. Not cabinet level. Just sturdy. Hope I helped, Jeff
May 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Doors stay open and need a push to close.
hi vicki,
i wouldn't recommend raising the front of your fridge, as the icemaker will not continue functioning.
from your problem description above, sounds like you need to check the door gaskets and make sure that the doors are not misaligned.
Aug 25, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Door adjustment
Move the left side leveling leg down (counter clockwise) and this will raise up the left side of the fridge also raising the door.  Let me know if this helps.
Oct 13, 2007 | Maytag MFD2561HEQ 24.8 cu. ft. French Door...
Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Aug 18, 2007 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
236 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
