Question about Car Audio & Video
Is it good or not
Is kicker solo X 5000W will work good with my amp boss RIP D3 3000W monoblock X 1 channel or not , becouse i like to buy kicker solo X 5000W. please let me know
  • 709 Answers
HI qq_lando,
Yes, you can get good bass from this setup. The Boos amp can handle 1 ohm but no less. You should be fine if your using one, no more than 2 kickers. You will need to configure the wires different for 2. Direct connect + to + and - to -. I must suggest if you have Dual Voice coil to wire your Solo X in series to keep the Ohms up. Main thing to remember is keep it below 8 ohm and above 1 ohm total impedance
Posted on Nov 12, 2007
Can I wire a 2ohm Kicker CVR with a 4ohm Kicker CVR to a monoblock amp 1 channel
yes. google, impedance calculator and it will help you out on how to wire it
Apr 12, 2015 | Kicker Car Audio & Video
I have 4 wires what do they do I no to of thim will go to my Kicier ame I Ddont no were the other to go
OK, I am assuming that you have 4 wires coming from the subwoofer itself. Your subwoofer has dual voice coils, this means there are two positives and two negatives. Look closely at the posts on the subwoofer and you can tell. These wires will go to your amp, all four of them. Here's the tricky part. You need to know if your amp is a monoblock (single channel) or two channel amp. Also, what ohms is it stable at (4, 2, or 1). If you have a monoblock stable at one ohm, take both positives from the sub and put to the positive of speaker output on the amp. Then put both negatives from the sub to the negative speaker output of the amp. If your sub is dual 4 ohm voice coils, this will give you a 2 ohm load. If you have a dual 2 ohm voice coil sub, this will give you a 1 ohm load. If you amp is 2 channel, just hook one set of positive and negative to one channel and the other set to the other channel. Hope this helps
Aug 28, 2011 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have a "12 kicker
If it is the amplifier that is shutting on and off:
Check to make sure the power and ground wires for the amp are secure, with no fraying, knicks or exposed wire. Check your fuses and connections to make sure everything is correct. Also look at the grounding location. be sure there is exposed metal around the grounding point (paint may cause intermittent power problems). Lastly, the amplifier's remote wire may be improperly secured to the wiring harness. Check the harness for exposed wire grounding out connections.
If the amplifier is continuously on, the subwoofer may be to blame. Check and double check wiring schematics to ensure correct ohms rating.
Feb 28, 2011 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Ihave 2 kiker 15 inch solo l5 1500 max 750 rms so what kind power , how many chanal am.p i need ? im confused......
If they are 2 ohms I would recommend dropping to 1 ohm for maxium out put. To drop to 1 ohm you are going to run the 2positives and 2negitives together in either a bridged or monoblock 1500w amp. After doing so i would get the spects for the speakers freq. ect. or go to a quality audio store and most of them will help tweek it for free. I would recommend Kicker ZX1500.1amp for best compatiblity.
Nov 07, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Need An amp for 2, 4ohm Kicker 12" L5
i bought two Audiobahn A2300hcx on ebay for a little over 400. look around on ebay you can really score sometime dirt cheap........ Check out audiobahn amps, never did me any wrong...........
May 06, 2010 | Kicker Solo-Baric L5 Car Subwoofer
My friend jus bought 2 10 inch kicker l5s and when we hooked them up to his boss 1100 wat amp and hooked everything up they are moving but are not producing any sound. boss amp i do not know any thinbg...
it must be reversed polarity in coil voices of speakers check + - wires from amplifiers fit on coil voices of speakers try to get each speaker to 8 ohms wiring in serial the two coil voices n'd put in paralel both speakers in bridge mode output from amplifier to get most stable power ,
Nov 04, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Car amplifier
Jun 03, 2009 | ElectroVoice EVM10DLX Car Subwoofer
Wiring my kicker solo-baric 15's
The best you can do is connect the dual 2 ohm voice coils of each respective sub in series (4 ohms total per sub) and then connect each sub to one channel of the amp. This will give each sub 1000W, which is the rated maximum from Kicker.
Mar 13, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Bridging to 12 inch kicker competition subs to my 1000 watt alpine 4 channel amp
I'm a bit confused. For Alpine amps, the "M" prefix is for monoblock (aka single channel) amps and the "F" prefix is for multichannel amps. The only M550 I find is an MRD-M550, which is a monoblock, not a 4 channel like you say.
Unfortunately, I can't give you accurate help until we know weather it's truly 1 channel or 4 channel. Then I'll be glad to help!
Mar 05, 2008 | Kicker 01C8VR4 Car Subwoofer
Kicker zx750.1& two 15"kicker solo L7 2ohm
if the amp could handle 1ohm paralell would work if not they wire in series
Apr 08, 2007 | Kicker (ZX750.1) Car Audio Amplifier
Car Audio & Video Logo
122 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
