DLP tv trouble shooting
Why does my tv turn off by itself. sometimes after an hour and sometimes within 5 minutes of turning it on.. just turns off, then i turn it back on and watch it for a few more minutes and sometimes 30 until it turns off again.. picture is good, not dim.. could it be a fan?? help , mike
  • 2 more comments
  • wmorris4x4 Nov 25, 2007
    i also have a Samsung that turns off by its self, i added a extra small fan to help cooling in the back area , but hasnt helped. mine will work all day some times and shut off 4-5 in a hr at other times. if any body has a fix or what is wrong i would appreciate it.
  • 81jimmy Jan 01, 2008
    i have a rca and my set does the same it turns off in 3-5 minutes every time does anyone have a solution?
  • BigSlimmy Mar 08, 2008
    My Mitsubishi WD52631 turns off by itself randomly, then you have to hit the restart button on the set before the remote will turn it back on again. Sometimes this happens 20 minutes after viewing, sometimes 3 hours after. Also, when I turn it off at night, the next day when I try to turn it on, it won't turn on until I hit the reset button.
    Once it is on, it operates fine. The manual says the set is designed to shut down if it sees a voltage surge, but I've tried 3 different surge protectors. Maybe it's overheating? It's been fine for a year and a half - does not make sense.
  • Anonymous May 14, 2009
    i have sound no pitcher jest lines
  • 372 Answers
Hi.
Yes it could be a cooling problem, If your tv has any filters remove & clean them ensure fan can turn freely & that nothing can or is snagging it.
http://dysonmanuals.inc.io/
Chris.
Posted on Nov 11, 2007
What's the matter with my Mitsubishi Big Screen Tv Model VS-5041?
just re-read the trouble-shooting section of your owners manual and check the setup on your remote
May 26, 2013 | Mitsubishi VS-5043 50" Rear Projection...
I have an InFocus Screenplay 61 in. DLP TV. For most of the time, it won't turn on except for the blue buttons on the TV itself. Sometimes, however, the TV would work for a couple of minutes completely...
The tv projection Lamp inside tv now like 1 1/2 or 2 years already?Tv on and in used every day 4 or 5 hours every day?Yes,this problems,the tv projection Lamp live are ending.Replacement of the tv projection Lamp,tv will work again.
Jun 07, 2011 | InFocus ScreenPlay 61" Rear Projection...
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
The tv turns itself off periodically. Sometimes it goes for hours and other times it happens several times in a 5 minute period.
I suspect a bad connection/dry joint in the power supply.
Look for regulator I/c's on heat sinks. They are favourite to get dry joints and anything that is heavy like transformers and chokes.
Oct 18, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung dlp HL56A65 turns off and on by itself
It looks power board problem.
You need to get service from Samsung.
Mar 04, 2009 | Samsung DLP HL-P5663W 56" TV
Try and clean the filters or the plastic fan guards.
Jul 30, 2008 | Home Security
Problem with tv turning off by itself.
I had a friend with the same problem. He had to clean the components and fans in the set. The accumulated dust had caused the set to run hot and a safety switch was the tv off. He purchased a few cans of compressed air and, as he blew the components and fans out, used a vacuum to capture the blown dust. Good luck.
Dec 27, 2007 | Samsung HL-S4266W 42" HDTV
Televison & Video Logo
989 people viewed this question
Top Televison & Video Experts
