Question about Whirlpool 3362624 Washer Control Timer Knob
HOW TO REMOVE TIMER KNOB ON A WHIRLPOOL WASHING MACHINE MODEL LST8244AZO. Thanks
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: remove whirlpool wtw5300vw2 washing machine timer knob
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%^^&^
Posted on Oct 01, 2010
SOURCE: I have a Whirlpool washing
I have a Whirlpool washer #LA8800XT and want to remove the Fabric Softener dispenser so I can remove the agitator. Does it just screw off? It seems to be stuck and I didn't want to break it if it didn't screw off.
Posted on Jul 29, 2011
I want to replace a timer on a Whirlpool washer Model# LSN1000KQW
Good day Mr.james dant..
Whirlpool manufactures many types of washing machines. Whirlpool's top load models rely on an analog timer that controls the cycle used to wash the clothes in the washing machine, rather than a digital control board found in most front load models. The timer contains a number of moving parts and is physically turned to choose the wash cycle. Because of the high usage of the timer, it will eventually break, requiring replacement. Rather than calling a service technician to repair the timer, replace the timer yourself to save both time and money.
Instructions
1. Unplug the washing machine from the wall outlet
2. Turn the dial to the "Off" position and then unscrew the knob from the timer. To unscrew, hold the dial with one hand and turn the knob counter-clockwise.
3. Lift the dial off of the washing machine.
4. Remove the two mounting screws securing the timer into position. 5. Remove the two screws from the bottom left and right sides of the control panel, then rotate the control panel up 180 degrees.
6. Remove the wire harness from the old timer and remove the old timer
7. Connect the wire harness to the new timer.
8. Place the timer into the control panel. Hold the timer post with one hand and rotate the control panel back down. Secure the timer into place using the mounting screws that were removed from the old timer
9. Place the dial back onto the timer post and then screw the knob onto the post.
10. Plug the washer back into the wall outlet
Try to watch this video:
Nov 25, 2011 | Washing Machines
I have a Whirlpool washing machine LA8800XT. It seems the timer knob can no longer engage the timer shaft. Part number of the timer is 3352091. I am positive the machine and the timer are fine. I tried...
Oct 09, 2010 | Whirlpool 3362624 Washer Control Timer...
Removeing timer switch knob
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
See the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=d09053515715195798276a5664b79cf0
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If this is a basic top load, direct drive washer, these units may have one of two different timers. (See the Whirlpool PDF).
On models with a metal timer, you have to release the console, pull it forward and tilt it back in order to get to the back of the timer.
The knob screws onto a medal shaft that goes through the timer.
Usually, trying to un-screw the knob won't work by itself since the shaft will also turn.
I found that if you hold the back of the shaft with a thin needle-nosed pliers, you can unscrew the knob.
Then you simply have to disconnect the timer.
The Whirlpool PDF also has troubleshooting and testing procedures for the timer.
Jun 08, 2010 | Kenmore 24032\24036 Top Load Washer
Remove whirlpool wtw5300vw2 washing machine timer knob
Feb 22, 2010 | Whirlpool Washing Machine Knob - 3362624
How do I remove the rotating knob on a Whirlpool washing machine
theres a black pin on the back of the timer pull that out and the knob should release,put it back to snap the knob back on
Feb 04, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Hello, our whirlpool keeps washing and washing, never getting to the next cycle. thx for help.
Hello there:
The most common problem with this is that the timer is failing and will not allow the machine to go to the next cycle
So what you are going to have to do is to take off the back panel and remove the wires that are attached to the timer (this is the part that you select the different cycles from ) better know as the timer ok?
then remove the knob and remove the timer and replace it than hook up the wires back into the new one and put the knob back on and the test the machine ok? and hopefully you will be good to go from here:
I hope this is very helpfull for you
Best regards michael
Dec 16, 2009 | Whirlpool Washing Machines
My washing mechine Timer not working
look online for appliance parts give model no. and u should find it
Aug 28, 2009 | Whirlpool Washing Machine Knob - 3362624
How to remove knob from panel
If there is a black tab on the back of the timer, it needs to be pulled out of the timer before you can remove the knob
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't spin
The first thing I would check is if your timer is advancing. Set it at th beginning of a wash cycle and let it go. See if the timer knob arrow advances. If it doesn't, your timer is bad.
Oct 18, 2008 | Whirlpool LBR4121JQ Top Load Washer
Whirlpool 3362624 Washer Control Timer Knob Logo
432 people viewed this question
Top Whirlpool Hardware & Accessories Experts
Joseph Mueller
Joseph Mueller
Whirlpool
Whirlpool
Are you a Whirlpool Hardware and Accessory Expert? Answer questions, earn points and help others
