Question about Frigidaire Washing Machines
Frigidaire gallery front load won't spin
It sounds like i have the same problem as mike889 and dubusons. after the rinse water drains, the drum spins arounds slowly 4 or 5 times and then it shuts off. of course the clothes are soaking wet. i have tried the rinse/drain drain/spin cycles-- high, medium and low spin- the washer does the same thing every time. it gets down to 7 minutes left and turns off. i tried reseting the washer at the fuse box and pushing on the door in case it was the latch. everything was fine yesterday-- figures my DH is away until tomorrow night!! thanks for all imput - i've never done this before
I had this exact problem. After draining, it tumbled. until 7 minutes left, and then just stopped. I replaced the door lock and switch yesterday, and that fixed it. The spin cycle works again.
Posted on Oct 22, 2009
  • 370 Answers
Does the washer spin after the wash cycle? It sounds like the door switch. This is a common problem with frigidaires. 90% of the time a door switch fixes it.
Posted on Jul 01, 2009
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
GLTF2940E not spin rinse drain problems
I would check the drain pump for objects. There is a trap that will collect coins and stuff. As this trap builds up it restricts/blocks the water from being drained from the washer.
Aug 07, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Washer will spin while in rinse mode, but does not
this could be a main control board problem.how ever i would check the drain pump for any kind of foregin object that may be causing the drain but to stop functioning.last resort bad drain pump
Sep 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire Gallery Series Front Load washer won't drain or spin
It sounds like there may be 2 things wrong. If the drier is not draining then the pump is clogged. Remove the drain hoses and check the pump(IMPORTANT!!!!Before you remove the hoses get a pan to put under the hoses. Alot of water will go on the if you do not do this...)The pump most likely has a coin in it.
The klunk you heard... If the drum spins and seems to be out of balance. If could be your rear bearing or your spider bracket.
Jun 22, 2009 | Frigidaire GLTF2940ES Front Load Washer
High speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Mar 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
659 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
