Question about Garden
Hi, I have a PM 145-14 chain saw. The problem I have is that the primer bubble has a cut in it and I do not know where to get it repaired. Can you help me ? I live in Vankleek Hill , Ontario. One hour from the West Island of Montreal, Quebec and an hour and a half from Ottawa, Ontario
  • jpeterjarvis Jul 02, 2009
    Hi, I do not want to know where to get the part. I would like to know of a location that I can take my chain saw and have it serviced. Thank you for the information though.
  • David Ford
    David Ford May 11, 2010
    You might try the website psep.biz for the part, they have a large selection of gasoline engine parts when you go there make sure that you have all the information available so if you need to contact them they can look it up. Good luck
    Brigadier General:
  • 4,088 Answers
Order the part online if you can. This is a relatively easy part to replace.
Posted on Jul 04, 2009
My Husqvarna 235e chain saw starts, runs, and cuts fine but will not idle without stalling. I notice a little air foam in the primer bulb and a few small air bubbles in the clear fuel line when running,...
sounds like you may need to make a very slight adjustment to the air fuel ratio try by turning your adjustment screws just a 1/4 turn in first then out...
Aug 09, 2014 | Garden
How to start ozito petrol chainsaw
1.fill with bar oil an 2stroke petrol
2.put the chainbrake on
3.if there is a primer bubble 5-10 pushs might say next to bubble
4.IF YOUV\'E NEVER STARTED A CHAINSAW PUT IT UPRIGHT ON FLAT GROUND and put you right foot as far in the trigger handle as you can, put enough weight to stop the bar or chain touching dirt, dirt will blunten a chain very quickly
5.grab the top bar with left hand firmly
6.pull out or raise the choke the whole way.
7.switch on the on/off switch
8.make sure your as much weight on your hand an foot holding the saw and pull the cord fast but never the whole way out or else it will snap over time and when it cant come out anymore it will jerk the chainsaw which can make the bar hit dirt and your chain will get blunt!!! or your leg but that wont blunten the saw
9.keep pulling the cord until you hear the engine fire,
Probably 3-5 descent pulls, it just revs a little loader and longer.
when it fires push the choke back in the whole way
10.pull the cord a few more times and it will start up dont pull the trigger till youv\'e taken the chainbrake off, or youll burn out the clutch. dont forget dont let the chain touch dirt a blunt chain makes cutting really hard on you and the saw.
If you know how its worth stopping and sharpening it as soon begins to lose its edge your back will love you for it, and you get more wood cut. But if you dont sharpen evenly and at the right angles it can be as bad as hitting dirt because it wont cut straight and get stuck
Jul 09, 2014 | Garden
McCulloch ChainSaw Model: 600035-18. Looking for manual. Replacing the Primer Bulb and hoses to fual tank, carborator, and from opposite side of carborator are bad. replaced the lines connected to the...
Hi cmiller290...
The hose in the tank with the filter on the end connects directly to the carburetor input connection.
When the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
The pressure side of the primer returns displaced fuel to the tank as it is depressed.
To get your manual for your McCulloch chain saw, you need to call 1-800-521-8559, ask for parts, than ask for a PDF user manual,you will need the model number of the saw..
It will be e - mailed to you for FREE.
1-800-521-8559
MONDAY - FRIDAY - 6:00 AM - 4:30 PM (MST)
www.mccullochpower.com
Please take time to rate me
Aug 18, 2011 | McCulloch Garden
14 inch, Factory refurb, FR2.0. After I replaced all fuel lines and primer bubble, won't start. Gas runs out the exhaust.
I did a lot of research but didn't find your problem.But I did find an online store that deals with your 2.0 Eager ****** chain saw. http://store.chainsawr.com/
and a way cool saw repair website. http://www3.telus.net/findNchoose/smallenginerepair.html
If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions. I hope this is of some use to you.Thanks for choosing FixYa.com.
May 19, 2011 | McCulloch Garden
The saw s primer bubble split ...i replaced the primer and it ran fine..then just quit... i changed the gas and checked the plug for fire .its ok..........but it will not fire ????
I would see if you have a air pocket in your gas lines.Try removing plug and pumping primer bulb until you know engine is flooded. Then let dry out before you put plug back and try to start. Thank you.
Apr 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Primer bubble
The primer bubble just pulls fuel from the carb and dumps it back to the tank, to replace it diss connect the two hoses, there are then two small plastic legs on the back, press them both in and the primer will just pop out.
Feb 26, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
HAS NO POWER AND DIES OUT WHEN GIVING MORE THROTTLE OR TRYING TO CUT
I have the same problem. Can't find my manual to look up trouble-shooting guide. Did following, but same symtom after:
1.) Clean air and fuel filter
2.) Replace gas lines with "tygon" tubing; check for kinks in gas lines.
Observations:
1.) Runs good for about 20 seconds then dies slow death. Starts and idles good.
2.) Air bubbles in primer squeeze bulb.
3.) Gas tank is pressurized.
My next trial and error mission:
1.) Fresh gas and oil mix.
2.) Remove gas and oil filters for bench test
3.) Replace primer tube (it is smaller than gas tube) so I cut ends and re-used old.
If you have pin-pointed the problem let me know. It sure seems like gas starvation.
Jan 13, 2011 | Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2...
I have a Husqvarna 455 about 2 years old. At about 1 year point it would no longer start using the primer pump button on the side when cold. If I take off the air cleaner and give it a a shot of gas down...
Your seeing the problem. Air in the fuel lines usually caused by a cracked fuel line or a pin hole in the primer bulb. Until you can stop the air bubbles by either replacing the actual primer bulb or fuel lines your always going to have the hard to start problem. This can also cause the engine to run lean at high RPM settings and eventually burn a hole in the piston. You should repair the fuel problem ASAP. If you do not find any fuel line / primer bulb problems then it is time to start looking at the carb diaphram.
Thanks for choosing FixYa,
Kelly
Oct 08, 2010 | Husqvarna Chain Saw 20" Bar
I need a repair manual for a McCullough gas, 35 chain saw
Mc chain saw fuel lines rotted away need to know where they go
How the primer lines go! There are 2 outlets on carb. two tank lines two primer lines
Jan 11, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
264 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
