Question about Toro Lawn Mower With Toro Power Tools
White smoke and blade won't engage
Toro 2008 self-propelled electric mower starts great but immediately white smoke billows from front of mower. As soon as the blade control bar is touches the handle the mower cuts off. As long as the blade is not engaged, mower will continue to run, and smoke. Suggestions?
  • 62 Answers
Sounds like a low compression problem. The piston rings have most likely failed and oil is seeping past them and burning, thus the white smoke. An engine needs three things to run...Spark, Compression, and Fuel. Just take the mower back as it is still probably under warranty. Mike. Rate 100% please.
Posted on Sep 19, 2009
Have a vibrations only when blade is engaged
vibration when the blade is spinning is a sure sign that the blade is bent and out of balance , maybe you hit something solid in the yard ??? anyways blades need to be replaced / rebalanced) if you continue to use a out of balance blade then shaft seal on engine will wear out prematurely and leak motor oil leaks out
Jul 29, 2015 | Toro TimeMaster 30" Self-Propelled Lawn...
Toro self propelled mower. blade won't stay tight
Use a block of wood to hold blade stationary while tightening bolt. Ensure threads are cleaned with a wire brush before tightening. Is there a spacer or washer missing?
Jun 26, 2012 | Toro Power Lawn Mower
Smoking lawn boy mower
Check head gasket hopefully that is only problem.
Sep 25, 2017 | Briggs & Stratton Garden
I have a Toro 20" self propelled, electric start
I am strictly Briggs&Stratton. They are hard to start when the fuel tank is half empty. Clean the plug and air filter.
Jun 15, 2011 | Toro Power Lawn Mower
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
I bought a self propelled Toro mower and it is hard to pull backwards. I removed the plastic toe guard and that did not help. I also have a White "brand" self propelled and it is easy to pull backwards.
The self propel system uses a type of racheting pinion drive that sometimes gets greased up and wont release like it should.
You would need to remove the wheels and pinions and look at the shaft ends for a key, a ball and a spring. This is the "pawl" that locks the wheels going forward and rachets when the wheels go backwards.
Clean up the parts of all the aluminum colored grease and reoil with something lighter. 3 in 1 would do nicely. Reassemble.
Now the next time you start going backwards and it jams...just push the mower forwards slightly without engaging the drive and see if the unit doesnt free itself.
Good luck and be careful!
Jul 19, 2010 | Toro Garden
Toro self propelled model 20066 loud noise once engaged
They will honor it - go now - - quickly and simply explain things - Toro is a good stand up company.
May 25, 2010 | Toro Lawn Mower With Toro Power Tools
Front ppropelled mower
You dont adjust the belt,you adjust the cable that moves the pulley into the belt. There will be a small single bracket close to the engine side of the mower that holds the cable in place. Simply loosen bracket and move cable until pulley contacts belt enough to engage self propel.
Aug 08, 2009 | Toro Lawn Mower With Toro Power Tools
Billows of white smoke when Toro lawn mower runs
You overfilled the oil. If the mower runs, just go ahead and mow grass until it runs the oil out of the gas tank. Or you can empty the gas tank and fill with new gas. White smoke is not a serious problem. Only a hassle.
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
569 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
