Question about Motorola Mobility RAZR V3
Razor alarm clock
When I go into tools to set the alarm, it shows (New Alarm) but when you push options, it just goes to New in the left corner and when you hit select it just goes back to (new alarm)
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 74 Answers
Re: razor alarm clock
Once you open alarm, select "set" for alarm 1, go to the time and change it to what ever time and click "set" again. After shut phone. I thought it was wierd that it did not confirm but It works. Let me know how it goes.
Posted on Jan 30, 2008
0 characters
3 Points
How to set an alarm on a Samsung T255G Phone?
Hi there!
You can set an alarm to alert you once, or daily at a specified time. Once set, the alarms are easy to change or turn off completely.
1. In Idle mode, press Menu > Tools > Alarms. The following options appear in the display:
• Wake-up Alarm
• Alarm 1
• Alarm 2
• Alarm 3
• Alarm 4
2. Select an Alarm. The alarm screen appears in the display containing the following options: the alarm name, the on/off setting, the time, AM/PM, alert type, alarm tone options, the alarm volume setting, days if the week to sound, snooze option and auto power on/off setting.
3. Highlight the options you wish to change, then select values for the options using the Left and Right navigation keys.
4. When you're finished entering and selecting values for the alarm, press ok. The alarm is set and the alarm icon appears in the top of the display.
Hope this helps
May 01, 2011 | Cell Phones
I can't find the alarm clock setting anywhere on my nokia surge phone! is this normal? I've searched everywhere for it, and it just doesn't make sense for there to not be such basic thing... I must have...
hiSelect > Tools > Clock To set a new alarm, open the Alarms tab, and select Options > New alarm. Enter the alarm time, select whether and when the alarm is repeated, and select Done. hope this will work. regards aniruddh
May 28, 2010 | Nokia 6790 Surge Cell Phone
How do you set the alarm clock on a motorola clutch i465?
There's an option in "Download Apps" from the "Java Apps" Menu called "Factory Preloads." Choose that option instead of the "New Purchases" option that you usually choose when installing other/new apps and it will give you a list of the default apps the phone came with. Alarm Clock Plus will be in the list.
You'll have the ability to re-download any of them, Alarm Clock Plus included. Make sure to uninstall the existing installation of Alarm Clock Plus first before doing so.
Mar 29, 2010 | Motorola Mobility Clutch i465 Cell Phone
Set all 3 alarms and they never go off. Big problem since it is my only alarm clock for work and just recently quit working have used for almost 2 yrs
You need to make sure the Ringer is enabled. Here are the instructions:
Alarm Clock
The Alarm Clock tool allows you to set up to three
When you set an alarm, the current time is displayed.
When the alarm goes off, Alarm 1 (or 2 or 3, as
applicable) will be displayed on the LCD screen and
the alarm will sound.
1. From standby mode press the Center Select
Key c [MENU], then press the Directional Key
r right twice for SETTINGS & TOOLS, 2
Tools, 4 Alarm Clock.
2. Press the Directional Key j up or down to
highlight an Alarm (1, 2, or 3), then press the
Center Select Key c [OK].
3. Enter the alarm information including:
• On/Off
• Time
• Frequency
• Ringer
4. Press the Directional Key j up or down to
highlight the information you want to set, then
press the Left Soft Key L [Set] to view your
5. Set information and press the Center Select Key
c [OK].
6. Press the Center Select Key c [SAVE] after
setting all of the applicable Alarm Fields.
Feb 24, 2010 | Casio G'zOne Boulder Cell Phone
Need help setting the alarm on my iphone ka08
Ok, go to the clock face on your App screen, then ensure the alarm clock at the bottom, second from left is highlighted. Tap edit, top left, tap which alarm you want to edit just to the right of the time and then use the wheel at the bottom to set your time by dragging up and down. You have various other options to play with but you can hit save, top right and thats your alarm set. Confirm this by seeing a small clock face at the top left of the screen next to the battery.
Hope this helps and please vote if so.
Jan 20, 2010 | Apple iPhone 3G
2 alarm times appear at the bottom of my screen. I only want one
I had the same issue. For the last few days I had the double alarm icon with the one you describe showing 8:00 am. I had no alarms etc set so I had no idea what it was until today at 8:00! A notice came up about a friend's birthday. Apparently when I was in my calendar a few days ago I attempted to put the birthday reminder on my calendar. In the menu I thought I selected "New" however just above the New option is the New Alarm option which is what I must have selected. When the alarm came up the icon went away from my home screen and the clock page. I went in and deleted this recurring alarm and scheduled it as I normally do on my calendar.
You probably have an alarm that either already came on by the time you have read this and you likely set it inadvertently like I did. I hope this helps.
Mar 15, 2009 | RIM BlackBerry Storm 9530 Smartphone
How do i change the main display?
go to settings, then to phone settings, then to quick search. select yes. now when you open you phone type in 25276 (alarm) on your keypad and press the down button. sholud come up with alarm. or 2252 (calc) for calculator
Jan 07, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Alarm clock
I had the same problem. Finally in frustration I did the following. Press MENU, then 6, then 4, then Options, then 3 (Reset All). This apparently clears all the alarm memory and my alarm settings would then save properly. I hope this helps you!
Oct 20, 2008 | Samsung SCH-u340 Cellular Phone
Alarm snooze
prees the menu button'
select the Office tools
scroll down and select the alarm clock
you can choose by pressing the right soft key
by choosing the disable the alarm clock..
Jan 08, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola E815 alarm full
At the alarm screen, highlight one of the alarms, then press the main menu button, several choices, including a delete option will be given. There is even a delete all option
Dec 17, 2007 | Motorola Mobility E815
Motorola Mobility RAZR V3 Logo
216 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
