You should be able to go to your settings and change the language to English. If not you may have to do a reset and set the tablet up again and if you do then the addition applications and data you put in maybe lost. Not sure with this tablet. I was unable to tell if you could get to your settings but I hope so. Good Luck.
I'm afraid you are right. There are too many cheap chines tablets on the market. And when you really don't know what brand or what model, you even can't put in new software. I would send it back or put a complaint on e-bay for that part.
In case your Android smartphone is complete frozen and not responding to you at all, the above restart method won't work for you! To unfreeze Android smartphone that is dead froze, force restart it by holding the Sleep / Power key and the Volume Down key simultaneously until your device's screen goes blank.
This force restart key combo varies from device to device, so it is advised to check your device manual for the right combo. If your Android device has a removable battery, you can remove it and put it again and it will restart the device.
Try holding the power button until it shuts off or prompts you to power off. If that doesn't work, try locating a reset button, if it has one, and press it with a pin or other small object. It can then be restarted and be back to normal.
