Question about Whirlpool Duet GHW9150P Front Load Washer
My wirpool duet is leaking the sealing is not good no more
How can i replace the seal
  • 5,911 Answers
If you are talking about replacing the rubber door seal (called a "bellow"), the following link explains how:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If this isn't the seal you are talking about, please post back and let me know. If you have any questions about this repair, also let me know. I hope this helps you.
Posted on Jul 01, 2009
Water leaking from under my 2010 Whirlpool duet washer
First places that I would check are hose connections and the seals on the water pump...
If the seals are leaking the pump has to be replaced.
Dec 22, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Broken ceil on whirlpool duet front load leaks water from rubber part
You need to get a new seal. You can probably change this yourself. There is a wire clamp holding it in place that you will have to remove before getting the old seal off and installing the new seal. Finally, you will have to replace the clamp.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Just wondering can the rubber seal be changed on my Whirlpool duet front load washer? The seal around the tub of my machine has a small rip in it and now the water flows out when I am washing my clothes.
yes they can, the bellow seal is about $100 and take care when removing the outer tub spring and the front seal spring so you don't kink these or the new seal will leak around the edges
Apr 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9100LW1 the machine is leaking and not draining property what do i need and where can i find these parts
depending where the leak is,in the rear it could be the wash tub seal in which you need new seals and while its out replace the bearings,if its in the front,then either your door boot seal is torn or the drain "weep" hole is plugged by soap scum and mildew
Mar 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water leaks from whirlpool front loading washer when washing heavier loads
Check your rubber seal in the washer by the door and make sure your getting a good seal. Part of the seal has probably pulled loose.
Jan 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water on my floor
Is it the bottom or coming out the door at the bottom? When your seal is bad it will leak, mine leaks only on handwashables and delicates. I have had to have my seal replaced twice in the three years i have had one, and the last seal was not put on right and leaks.
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet 6hw9150p leaks when i put a full load
Is the door seal dirty?
A dirty door seal can cause a leak. Remove and clean any dirt or deposits around the inner door seal with a damp cloth. The door glass seals against the rubber seal; dirt or deposits can prevent a proper seal and cause leaks.
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GHW9100LW@ whirlpool Duet grey seal leaks
Here's the instructions you need to replace the door bellow on a Whirlpool Duet:
Let me know if you need further assistance. I hope this helps you.
PS I know it's a lengthy read, but it's a simple repair if you follow the directions.
Jun 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frotnt door seal ghw9150
why ? is it torn and leaking or just mildew? if not torn cleaning best bet with chlorine bleach and water.if you still want to change it remove spring front front edge pull seal back toward drum on back section big clamping band remove band pull seal off and reinstall reverse order can be a dog if not experienced good luck
Apr 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
152 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
