Problem with HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook
HP laptop display issue
My HP Pavilion dv6045nr will not show any display when booted up. Screen remains completely black, not just dim. Error code is 1 long beep, followed by two short beeps. Information I've found elsewhere indicates that may be a problem with the RAM, but I've tried replacing it and it had no effect. It has two RAM slots and I've tried swapping the cards, as well as running off one at a time. Basically i covered every possible combination of RAM placement, but got the same error every time. It was working one night with no indications of trouble, but a few hours later when I woke up it seemed that it would not "wake up." When I tried rebooting, I got the error beeps and it hasn't had a display since. I have NOT tried an external monitor yet, I would have to find someone with a desktop and don't know anyone off hand. I appreciate any help anyone can give!
Posted by avatar on Nov 09, 2007
    • By avataramaru0 Nov 09, 2007
    • I was able to access both RAM slots through the standard removeable panel. Incidentally, I did remove the keyboard in a desparate search for anything else wrong, and saw no RAM slots.
      On the bright side (depending on perspective), I tracked down the beep codes and regardless of the BIOS, 1 long and 2 short beeps translates to a video adapter problem. I'm not positive which BIOS I have, but it's either an unseated adapter or "An error was encountered in the video BIOS ROM, or a horizontal retrace failure has been encountered." So now the new question becomes where do i find the video adapter to reseat it? And the golden question, whats a horizontal retrace failure?
    • By avataramaru0 Nov 24, 2007
    • Okay, just to follow up:
      After trying all the solutions offered here (and I thank everyone for their input), nothing worked. I took it in to the shop eventually and was told that the only shot was to ship it back to HP for repairs under warranty. If warranty repairs don't cover it, I was told that it's going to run a couple hundred to replace the mainboard and possibly display, which means cheaper just to buy a new system. For the guest that said he's having the same problem, I would suggest finding a 2.5" SATA hard drive enclosure to plug in your drive and backup your data somewhere. Unfortunately, they're a pain to find (BestBuy, CompUSA, Circuit City were all no-go's...), but you can find them online through the more techy retailers.
    • By avatarklaussprecht Apr 23, 2009
    • I too am having this problem of black screen on boot up. This only happens randomly, and sometimes will work after a force shutdown, and sometimes not. Unfortunately everytime I try to use an external monitor the screen works. I have been speaking with a very experienced IT friend, and he is thinking that it could be a loose connector to the LCD itself. We are going to dive into this idea this weekend and see what we can find. Unfortunately the CPU is not under warrenty anymorel.
      On a seperate note. I too am done buying HP laptops. Not only have we had problems with the screen, but we have also had problems with the wireless card. Even after a replacement...but that is a differant thread. Good luck all
    • By avataruaehoney77 Apr 01, 2009
    • My HP Pavilion DV6291EA will not show any display when booted up.
      beep, followed by two short beeps and it continued. Information I've found elsewhere
      every possible combination of RAM placement then i buy new ram, but got the same error
      every time. b4 It was working Per a problem I was having with my HP DV6291EA laptop overheating and causing problems with ms windows vista ultimate 64bit I decided to upgrade the BIOS. According to HP the BIOS upgrade changed some settings that would help with the overheating issue. So I downloaded the updater version from F29 To F.2D from HP directly and followed all the precautions because I know how easily the computer can be messed up during a BIOS flash, I ran the Windows based FLASH executor provided by HP it was successfully Done as per bios update. now wen i Power ON my laptop totally nonfunctional brick just beeps an error code at me (1Long beep-2Short beeps?)after Remove/changing everything 1by1 (LIKE) RAM, HDD, DVD Rom, Wifi Card, Battery, work only with AC Power no battery, i find removing ram sound stop? then i changed the ram to new ram but same problem?, then i changed AC Adapter & battery but nothing happens? also i try removing bios battery for 10mints pressing power please if any1 know how to help me with this please.
      Thanks
    • By avatarlinux4all Jan 13, 2009
    • Have same problems with HP dv9372eu 17" AMD X2 Turion 64 TL-60 2GHz 2gb RAM, 1 long beep followed by 2 short beeps, sometimes not even that anymore, laptop just recursively rebooting.
      Have tried many previous tips. Doesn't look like I'd get HP support anymore (GG54....) so I tried to open my laptop by removing all screws below but I seem to be unable to remove the bottom casing to get to the rest of the hardware. I have already removed two drive bays and the memory covers and the hard drives. My questions at this time:
      Are there more screws around I haven't found yet?
      This is my first laptop I haven't managed to screw apart in one effort and I have really had many I had screwed apart and reassembled after repair/modding.
      My BIOS is version F37. If I get the laptop going again, should I upgrade the BIOS and to what version, latest?
      While my laptop did work most of the time, it did also hang on me or refuse to wake up from sleep mode after having been put to sleep for the third or more time in WinXP without having been switched off inbetween.
      Are these signs related to this BIOS version or rather a sign of beginning defects?
      I have never been able to get my network card going on this laptop. It was an Nvidia forcedeth type which did link up when connected to a network, but seemed to fail on transmition side, because packets were received once in a while. Does anyone have a clue as to what part I can modify on board to get it going once I get to the mainboard level?
      That is it for the mean time on my questions.
      Can anyone help? Please allow longer response times.
    • By avatarwhereonica Nov 21, 2008
    • I faced the same problem i.e. the beep and a blank screen. Ive checked with hp technical support and they said that this was a problem with this particular model dv6284. It was a waste of money and no one even wants to buy this model from me. Its real ****. Dont ever buy this.
    • By avatargeorgeasfour Sep 25, 2008
    • Got the same problem 14 months old laptop died overnight.
      I know it need a new motherboard = 400plus tax
      and I know that I'll never buy HP again.......................!!
    • By avatarjaideepg10 Aug 22, 2008
    • i have a dv2117Tx and it is just out of warranty (14months old) and it also has d same prob of 1 lon beep n 3 short beeps....its a prob wid d graphics card it seems which seems to heat d motherboard and d fan or video card stops responding....more and more people wid d same problem should report drr problems so we can get a replcae.
    • By avatarGuest May 28, 2008
    • I have a problem of No display of my hp pavillion dv2117TX . After I
      start my system I hear one long beep and two short beep sound after
      that screen remains blank . The system can't boot up . I have tried
      with RAM and battery check but the system doesn't improove . I doubt
      It's a motheboard problem .
      If anyone can help .
    • By avatarGuest Apr 16, 2008
    • My daughters HP laptop has encountered the exact problems. It died overnight without any warning. The laptop is only 14 months old and out of the 12 months warranty.
      When we turn the laptop on it has a long beep followed be two short beeps and nothing afterwards.
      As I cannot send back to HP, I will need to sort out with a local repair. Does anyone have any idea in the region how much this will cost?
    • By avatarNicolomd Jan 03, 2008
    • Same problem
      1 long beep, then 2 Short Beeps: Video error
      The motherboard is not able to access the video card for some reason.
      Either the video card is not working, it's memory is not accessable, or
      it's BIOS may be corrupt. This error code could also mean something is
      wrong with the motherboard.
Solutions (24)
Best Solution
I was using a HP DV6910US and i faced a problem when my laptop froze and i had to press thepower button to reboot.
But on reboot my laptop had all the lights on keyboard light on with no dispaly on screen/blank.
I have called the HP helpline and they told me to do these steps...
1.Disconnect all cables and usb connections of the laptop including power cord.
2.Remove the Laptop Battery.
3.Do not connect the Power cord now,Instead press and hold the power button for 25 seconds.
4.Now connect the powercord and put the laptop battery in place.
5.Now press the power button on your laptop and as the lights come on immediately press the Function/fn repeatedly.
Your problem is now solved as the screen comes on to life.
I was told that the problem is something related to the memory of the battery.
I hope my answer will help many Hp owners to solve the simple problem.
If you cannot get through you need to call the HP Toll free helpline at your place.
You might see the presence of random lines all over the screen in some occasions in your HP Laptop.
Often, troubles are created due to this. You would see the vertical and horizontal lines.
You could solve this problem easily with the help of LCD BIST test.
For this you would have to press the function key and follow the instruction as the LCD BIST runs several colored screen.
Get more information to fix HP Laptop Display Issues . Hope this helps you.
Had the same problem. It is due to the graphics chip which cannot be reseated or removed as it is soldered directly to the mainboard. What's more is that the solder is between the bottom of the chip and the top of the motherboard so there's no way of getting to it to try and reflow etc. You could try a heat gun if you’re desperate but that would almost certainly end in the total death of it altogether as the surface mount resistors and wot-not start ice skating into another dimension!
I have just thought though that the chip resides under the heat sink it shares with the CPU. This is exactly the same as the Xbox 360 X-Clamp repair, being that the chip get's hot (which being an Nvidia - Big Fan! - it would) and then melts the solder and lifts from the PCB resulting in failure.
With the Xbox, removing the crappy inadequate X-Clamp that Microsoft fitted and bolting it straight through with decent bolts and some welly fixes it nine times out of ten. The only thing different is that with the Xbox I prefer to cool the CPU and fry the GPU for 15 minutes to reflow the joints. In this case that is not practically possible but as I said, just clamping the chip down often rectifies the fault.
Another interesting thing I have noticed about this is that the heat sink has five screws that fix it. This is interesting as it points to the fact that HP were aware of this problem from the start. Especially as the four screws that secure the CPU go straight through the PCB and into a steel bracket which gives it a good clamp but the fifth that secures the GPU screws into some naffy (definite afterthought) of a surface mounted ‘bolt pot’ with all the ‘clamp ability’ prospects that a flimsy PCB can offer! To add to that, in their wisdom HP decided that sticking some of that awful putty **** (loosely) between the two was enough to withdraw the heat thrown out by the Nvidia and transfer it to the sink!
My eight year old son could have done a better job than that!
Well I will rip it apart again later and see if I can lose the ‘bolt pot’ and screw straight through the PCB. I will also get some decent material to fill the gap and some thermal paste, I thinks. I will post the results once I have done it.
If anyone is going to attempt this then I will say that be careful if you drill the PCB as I am sure it has a middle ground plate.
Ah well, here we go again……
    • By avatarPhillip Thorne Dec 29, 2008
    • milonmahmud There is no solution to this problem with the link you provided. In fact there is nothing that relates at all except that it doesn't work. I suggest you read the post's before replying in future.
      sparkyuiop.
    • modonpak Again, not a solution just other people with the same issue. What's wrong with people on here!
    • By avatarPhillip Thorne Dec 30, 2008
    • Fix did not work. Hey ho, we live and learn.
Just for future reference, for anyone who had a 12 month warranty, HP has extended the waranties to 24 months on certain models which are showing similar display issues:
"HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000."
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&dlc=en&product=3224052&lang=en#
  • By Author imageATBLAC Jul 20, 2008
I own a HP DV6045nr. Was running into the same problem,however, I was not given any beep codes. The computer would boot but no display. Sometimes it would continue to reboot and the screen would occasionally work and windows would load. that was at least 10% oof the time. the other 90% is would just sit there rebooting over and over and over again.
Solutions:
If you are using the dv6045nr or similair model, the sata HDD is hot swappable meaning if you know someone who has a desktop with an available sata connector, you can connect your hdd to backup your files....
If you believe your problem is caused by overheating, HP has released a bios update specifically for an updated fan control algorithm to help reduce overheating problems....
Finally, if all else fails, like in my situation, hp is offering a recall on select models laptops due to but not limited to; no screen at boot up, no wireless on boot, no audio several other problems. This is an extended recall issued for 365 day after the original 365 day warranty expires. call hp or check out the link for more info....
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&dlc=en&cc=us&lang=en&product=3203586
Guess what everyone? We are all screwed on this one! You have an nVidia video controller in your machine, right? Yeah, well, it's dead - just like mine. nVidia has announced a major failure in MANY of their video cards, and their stock is on a downward spiral. Both Apple and HP have also announced the failures in many of their machines due to nVidia chips. HP has extended warranties on several of their machines (I'm sure more to follow as mine is NOT on the list... yet). Here are some links to get the info. You may be able to get your machine fixed for free if on the list, but I say even if they do fix it and put in the same nVidia junk, it's just going to break again in a year or two.
nVidia chips dying left and right and machines affected: http://www.engadget.com/2008/07/31/figuring-out-which-nvidia-gpus-are-defective-its-a-lot/
Be sure to mark this post as "FixYa!"
Problem resolved?
please nicu.genunchi@yahoo.com
same same problem
help please
Try this solution link . . . http://www.Laptop.com/problem-solution
To find your best solution.
20
  • By Author imageseojul Jun 26, 2009
HP Pavilion DV6000 Notebook main problem's are Power Problem, Vista Error etc..
For these problems you can visit a link by just Click Here .
For any other problems with this Notebook you can Click Here
  • By Author imageseruk Apr 30, 2009
Shiiiiiitt HP
  • By Author imageGuest Nov 05, 2008
I had the same problem the wierdest thing was that when I would get the beep noises and the screen would be black I would take the battery out and put it back in then hit the poqer button and the monitor would work fine. However cartain keys on the keyborad would not function so I connected a USB keyboard then it was ok but then Windows would not load up so i used a Live Linux CD and it would load onto that OS. But after all that even in the linux OS the computer would freeze up.
  • By Author imageGuest Apr 06, 2008
Many HP notebooks are failing for this same reason. It's a problem with the video card and the motherboard must be replaced. So many are failing that HP has extended the warranty to two years.
Excellent resources on the web that pinpoint this problem.
  • By Author imageGuest Jan 22, 2008
If you're sure it isn't a heat, dirt, moisture, or discharge problem before you woke, it could still be a defective/corrupted BIOS engaging a power save mode indefinitely. From your description, it doesn't sound like you moved it to unseat anything. No LCD TV or other to try it?
  • By Author imagepenulti Nov 09, 2007
Okay, good news, bad news and really bad news. Bad news first, it doesn't sound like the RAM, if you tried replacing it, but it could be the microprocessor (1.8 GHz AMD Turion™ 64 X2 Mobile Technology TL-56). If it overheated and cracked the ceramics in the CPU, you'll have to replace it. Now for the good news. It may just be a simple BIOS reset. It may actually be trying to boot from a non-existent device (like a USB drive). Try following these instructions on the HP website (it says if you get a blinking cursor, but the instructions are still valid for reseating RAM and pulling up the BIOS).
Now, just to verify, it sounds like you've got more than one RAM card. Those are DDR2 667MHz isoDIMM memory modules and should be able to run independently. Try using only one module at a time (in slot DIMM1) and see what happens.
Now for the really bad news. I think it may be the motherboard that's failed and not the memory. If so, game over. The replacement system board (part# EZ475UA) will, more than likely, run you at least $300, if you buy used/refurbished on eBay or elsewhere, or more than $500 if you buy a new one.
    • By avatarNot Available Nov 09, 2007
    • Hmm, took too long to answer and now new information. The video adapter, on that model, is part of the system board, I believe. Only the WiFi and modems are removable. Although I may be wrong. It would, in all likelihood, be located directly adjacent to the right-hand hinge for the LCD panel, just next to the power transformer circuit board. It uses a membrane ribbon connector that feeds to the LCD panel (that's how you know if it's the video). You may want to be sure that the ribbon connector is seated properly. To pull it, there's a bracket that flips up and then swings out to relieve the pressure against the membrane cable. Reseat the ribbon and then gently swing the bracket back and push down, firmly, to lock into place.
  • By Author imageuslek Oct 08, 2010
Bad MB, and HP knows it and refuses to fix the problems they created. Write your state attorney generals office and tell them HP acknowledges the problem is theirs, installed an extra year warranty, but failed to tell the people with the laptops they had a fix to a problem they know will happen. When the 2 years were up, HP feels they are free and clear the problem. You should have checked for the problems.
HP use to be one of the finest PC companies out there, now they're worthless like many before them. Remember Packard Bell? What can you do? To try to fix it the most reasonable way is Ebay, they have many MBs for all laptops available there. For the DV6000, under the memory slots is the MB part number. Mine is 443774-001, you must make sure you get the right MB for your laptop, a 443775 or 776 will not work, has to be 443774-001 for my laptop, your numbers must match or you'll have problems. For this MB the price ranges from $88 to $210 for the MB, excluding shipping. Many MBs are coming from China, and they claim to be fixed MBs or repaired. Make sure you get what you paid for. Removing the MB and replacing it is not hard, directions are on the HP web site. Good luck.
  • By Author imagerick Feb 11, 2009
I had this problem it was the mother broad it has 2 be replaced witch runs 350 buck then 4 weeks later the screen will burn out. Im glad i got the 3 year coverage
  • By Author image2748921 Feb 06, 2009
Well First off, I wouldent say it is because a hard drive. Thsts not going to cause the laptop to not boot(show something on the screen). I had the same exact problem *HP Pavilion ze2000* 1 long beep followd by 4 short beeps afterwords. what led to mine doing this I think coulda been moisture. after all my gf likes to keep it 60 or lower if possible. you should try to use a blow dryer. make shure you remove all cables and anything that isint high heat resistance. short blasts did the trick for me. my laptop runs like brand new besides the fact i need more ram.
  • By Author imagex_167 Nov 14, 2008
    • By avatarx_167 Nov 14, 2008
    • oh... forgot to mention... You might want to consider removing your hard drive completely before attempting this.. hdd is more sensitive to low level static than the machine it's self.
you need to get some software on a disk that boots at startup and checks ur disk.youll probably find that you have bad disk sectors.which would explain the beeps which incidently do usually mean mem fault but if ur disk have bad sectors it aint gonna get to the bit where it checks ur mem.
eg you have a perfect machine,take out ur hard drive and see what happens.
  • By Author imagetat4u Nov 07, 2008
It seems that I'm not the only who us facing the same problem, July 07, 2007 I bought HP laptop model of the unit is DV-6284 (which is using AMD Turion 64 X2), right after 2 months I encountered this problem ( long beep followed by 3 short ones). Now again for the second time after warranty expires the same problem happened again, 15 months to be exact. Still asking the local dealer if there is a possiblity of extending the warranty.
  • By Author imagejoefril Oct 20, 2008
I have a HP Pavilion dv6045nr i have the same problem the laptop turns on but no display i get the 1 long beep and the 2 short beeps. It's a video card problem so you would need a new motherboard to fix the problem. My warrenty was expired but i talked to HP tech support and they said there is a recall for that problem. They sent me the box to ship it they will fix it and send it back for free.
Suggested Solution (3)
maybe your video card is disabled ,so you need to
Removing the RTC battery and leaving it uninstalled for 5 or more minutes causes CMOS settings to be cleared and everything will be reset as factory defult and you video card will be enabled.
hope this is going to help
good luck
wahid h afandi
  • by Author image siako77 Over a year ago
Source: HP laptop display issue
Was this solution helpful?
No
Yes
First of all, try connecting an external display source like a Desktop Monitor to the VGA Port of the Notebook after turning it on and press hold the FN key and press the F4 key once to toggle the display to the monitor connected.
If you are able to see the display on the Desktop monitor connected to the Notebook, the issue is with the LCD, if not, the issue is either with the Graphic Card or with the Motherboard.
Additionally, I would like to inform you that HP had identified some hardware issues with few Notebooks installed with AMD Processors and is providing free repairs for notebooks purchased and currently available in US and Canada.
You need to get the Product Number of the Notebook which is indicated with P/N and is printed on a white sticker pasted at the bottom of the Notebook.
Check if the Product Number of your Notebook is listed in the list available in the link below :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01300427
If your Notebook product Number is listed in the link provided above and if the Notebook is installed with AMD Processor, you need to contact HP Chat Support and provide the required details and get the Notebook repaired by HP for free.
You can find more information about this repair offered by HP from the link below :
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Hope this helps...
  • by Author image Ravi Kumar Over a year ago
Source: error beeping 1 long beep follow by 2 shorts beeps
No
Yes
I have just experienced same p[roblem with my Pavillion laptop. Seems to be a graphics card problem. (Hp have issued extended warranties to cover this problem, which is apparently quite common in the pavillion range?)
I have had to send my machine back to HP to fix it. gah.
  • by Author image call554 Over a year ago
Source: HP Pavillion Laptop
No
Yes
Add Your Solution
See all HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Problems
