Question about Acer Aspire 5100 Notebook
Vista Wont Boot.
Had Ipod plugged in during a restart of my ASUS system, the error "windows has encountered a problem communicating with a device connected to your computer"
I have no Vista disc to do a clean install or repair from, its on a recovery partition which i cannot access.
I have removed all devices except wireless keyboard which is all i have and changed boot order to HDD first,
Not sure what else i can do.
  • 197 Answers
The cause of this is because the devices connected from your machine was not been remove properly.
boot up your machine and hit F8 to boot into safe mode. if it doesn't work you need to reformat your OS because I suspected it has been corrupted. Before doing so, back up all your files because everything will be wiped out and will load to default factory settings.
you can use your hard disk as an external drive connected to other machine so you could back up all your files.
Posted on Jul 02, 2009
Why is there a black screen on hp pavillion windows 7 "boot mnr missing"?
Windows 7 - black screen with blinking cursor
  1. Remove any CDs, DVDs, or memory cards from the computer.
  2. Disconnect all devices from the computer except the original mouse, monitor, and keyboard. Leave the power cord connected.
    1. Restart the computer.
    If it starts normally, start plugging devices in one at a time until you find one that may be causing the black screen
    1. Press the F10 key repeatedly during the first startup screen until the Entering setup message displays.
    2. Press the F5 key to restore the defaults. Use the arrow keys to select YES , and press Enter .
    3. Press the F10 key to save the changes and exit. Use the arrow keys to select YES , and press Enter .
      The computer restarts.
    4. If a Windows Error Recovery screen displays when the system restarts, select Start Windows Normally , and press Enter .
  • If this doesn't resolve it, follow the procedure below.
  • Aug 17, 2014 | HP 5188-7103 Compaq Motherboard Gl8e...
    How to install windows 7 from Asus p5pkl am se
    During the boot process you will see on the screen to press a certain key to enter setup
    Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
    note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
    (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
    after windows has loaded
    your computer will automatically restart it might restart 2 times one to finish the installation
    the next will be because the operating system is loaded and will boot from your cd
    during the boot process you will see on the screen to press a certain key to enter setup
    Press and hold that key during the boot up process to enter BIOS?using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
    hope this helps you
    Oct 26, 2011 | Computers & Internet
    I just setup my Asus CM6850 desktop computer and when windows gets ready to setup, I get the error "The computer restarted unexpectedly or encountered an error." When you restart it it goes...
    Run System File Checker. From a DOS/Command window type: sfc /scannow
    To open a DOS window, boot in safe-mode by pressing F8 repeatedly during the boot process (prior to seeing the Windows splash screen), then once in Windows go to Start > All Programs > Accessories > Command Prompt.
    Jul 12, 2011 | Computers & Internet
    Automatic restart my laptop.Windows vista
    If you are able to boot the computer in safe mode, you can disable the Automatic Restart from the Control Panel.
    Open Control Panel.
    Click on the System and Maintenance link.
    If you're viewing the Classic View of Control Panel, you won't see this link.
    Click on the System link.
    In the task pane on the left, click the Advanced system settings link.
    Locate the Start up and Recovery area and click on the Settings button.
    In the Start up and Recovery window, locate and uncheck the check box next to Automatically restart.
    Click OK in the Start up and Recovery window.
    Click OK in the System Properties window.
    You can now close the System window.
    From now on, when a problem causes a BSOD or another major error that halts the system, the PC will not automatically reboot. Rebooting manually will be necessary.
    If you're unable to fully start Windows Vista due to a Blue Screen of Death error, you won't be able to disable the automatic restart on system failure option as described in the steps above.
    Try the steps below:
    Just before the Windows Vista splash screen shown above appears, or just before your PC automatically restarts, press the F8 key to enter Advanced Boot Options.
    You should now see the Advanced Boot Options screen.
    Using the arrow keys on your keyboard, highlight Disable automatic restart on system failure and press the Enter key.
    After disabling the automatic restart on system failure option, Windows Vista might continue to load. Whether or not it does depends on what kind of Blue Screen of Death or other problem Windows Vista is experiencing.
    Since you disabled the automatic restart on system failure, Windows Vista will no longer force a restart when it encounters a Blue Screen of Death.
    Now that you have the STOP Code associated with the Blue Screen of Death, you can troubleshoot the problem:
    The following is the list of BSOD error codes with troubleshooting, you can find the troubleshooting steps using the error codes in the MS website also..
    http://pcsupport.about.com/od/findbyerrormessage/tp/stop_error_list.htm
    Hope this helped you. Please do rate me.
    Thanks!!!!
    Dec 21, 2010 | Computers & Internet
    Windows boot manager page with status 0xc00000e9
    If you don'yt have a Vista DVD,you can borrow any for startup vista repair. This is very common and HP/Compaq don't usually give operating systen vista dvd
    Oct 02, 2009 | HP Compaq Presario V6000T Notebook
    Windows boot manager-hardware failure
    Try pressing F-8 and look for last known good working configuration.
    If you are trying to reload from CD/DVD drive and it continues to boot into your old windows configuration, Enter your BIOS settings, and change the boot order to CD/DVD and then Hard drive
    Sep 15, 2009 | Acer Aspire 5520-5579 Notebook
    Need a system recovery? Tried the F8 method--doesn't work! Help!
    Just unplug the hard drive cable and plug it again. otherwise if problematic replace the cable.
    Apr 24, 2009 | Gateway GT5404 PC Desktop
    Compaq Presario 2800 boot error
    tried F8rapair your computer and startup repair and system restore...
    Jan 23, 2009 | Compaq Presario Notebook
    Imation atom usb driver vista
    vista has this problem , see below webite
    Error message when you try to install a new hardware device on a Windows Vista-based computer: "Windows encountered a problem installing the driver software for your device GET basis information
    http://support.microsoft.com/kb/940199/en-us
    Jun 06, 2008 | Electronics - Others
    Acer Aspire 5100 Notebook Logo
    Mohammed Ebrahim M
    Mohammed Ebrahim M
