Question about Nokia 5310 Cellular Phone
My phone keeps turning off when i turn it on....
After two or three times, the screen shuts down and looks like the display is damaged. It does this only after the NOKIA's handshaking greeting message. I guess it's not the display, because it works fine if I remove the sim card and waits until I select the option to work without a sim card. As soon as I say Accept, there's the handshaking, reboots two or three times and goes dea
Remove your memory card and turn it on again.
your welcome
Posted on Jul 21, 2009
My HTC HD 7 phone keeps turning off it goes to the white screen with green HTC then shuts off and keeps doing the same thing over and sometimes when i try to use it and i tap the screen then it shuts off...
I finally had to have them replace the unit. If doing a factory reset does not help, then I would have them replace it. Mine started rebooting infrequently, but then started doing it more often. They didn't waist any time getting my replacement out.
Please make sure you back up all your contacts/email before proceeding. I use Google on my phone through the Outlook option. Google/Outlook syncs all my mail, contacts, and calendar.
RESET: Software: SETTINGS > ABOUT > RESET YOUR PHONE
Hardware: 1) Turn off phone 2) While holding down both the Up/Down Volume buttons, turn unit on 3) Keep holding down the volume buttons until white screen appears 4) Press the Down Volume button to reset to factory defaults. 5) Restart phone
Jun 28, 2011 | HTC HD7 Cell Phone
The shutdown window keeps coming up and my computer shuts down
you have a virus, scan your pc with nod32, you can download from www.nod32.com
Sergio
Mar 22, 2008 | Computers & Internet
Phone wont turn on
Your phone is detecting a not genuine battery.You should use a genuine battery for your phone to avoid this kind of warning.
Dec 15, 2009 | LG VOYAGER VX10000 Cellular Phone
HTC Hero will not turn on. Phone shut itself off
I have a Droid Eris by HTC, on start up it freezes at the first screen showing the three Android men. I have let the bat. run down, taken it out and it still stays the same. I followed the instructions on the Verison site showing you how to hard reboot, but still nothing. The only change was I came to a screen with a red triangle with a exclamation mark in it with a phone in the back ground. Please help.
Dec 02, 2009 | HTC Hero Smartphone
N70 has white screen when startsit's not software nor hardware
Try the hard reset.
Try the green/3/* thing again (until you get it to work).
- Turn off PIN code requests.
- Charge the phone fully.
- Turn off the phone.
- Remove the memory card (not really needed, but I usually do it to be on the safe side).
- Put the phone on a table (easier to press the keys then, in my opinion).
- Press the three keys and keep them securely down and do not release.
- While the keys are still down, turn the power on.
- Do not release the three keys until you see the prompt for the home city.
If it doesn't work, retry until you get it right. It is easier if you have three hands.
OR:
A soft reset:
dial *#7370# after that it will ask for security code dial 12345 it's by default.
hp this will help.
May 07, 2009 | Nokia N70 Cellular Phone
Power on problem
try removing the memorycard first if there's any..then try switching on.when it turn on..then there's a malware in the memorycard..try formatting it using a computer.
Jul 14, 2008 | Nokia 6300 Cellular Phone
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
My cell keeps shutting down when i try to turn it on
i have a razor vx3 that was doing this every time i would get a phone call. I returned it for a new phone thought att.
Dec 03, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Shuts off
sounds like the high voltage transformer
or could be high voltage off the tubes.
not a good idea to keep this running as it will cause more damage, best to have service tech look at this since it's high voltage.
Be careful. This same problem burned a mark in the Blue crt on my pro730HD. Three months and the Service Tech and Pioneer have been unable to determine the cause (they claim). In the process they have blown two more crt's.
When your tv goes off, try turning it back on using the main power button instead of the remote. The button should be behind a flip-down strip below the screen. When it is working again, look for any faint colored spots in the picture most prominent on light backgrounds. Mine is a yellow Y in the center of the screen.
If there are no spots, I would suggest you don't use the TV until you get it fixed because eventually it will damage your crt ($750). Of course, as I said, they have been unable to fix my problem and I have had no TV for three months.
Nov 21, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Nokia 5310 Cellular Phone Logo
639 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
