Question about Electrolux Washing Machines
Foul smell after wash, like mould
Foul smell
  • 370 Answers
Try using affresh washer tablets. This is a easy way to clean your washer and is a 3 month supply. works very well!!!
Posted on Jul 01, 2009
The clothes r not washed properly n r dirty and also smells at times
It could be mould gathering in the machine, particularly in the dispenser and round the crevices of the door rubber. You are supposed to put machines through a service wash periodically to stop it building up. It can be worse if you do low temperature washes and use a non biological product because neither will kill the bugs that create mould.
Feb 09, 2013 | Washing Machines
My bosch washing machine smell's of mould
Try running it empty of clothes with bleach
Mar 10, 2012 | Bosch Washing Machines
When i wash clothes in my LG front loader it sometimes smell like rooten eggs,and my clothes never smell good no matter what detergent or softner i use...help
hi, it sounds like it has had standing water in it and this has caused mould to build up inside the machine the best thing for you to do is get some old towels and put them on the hottest wash setting not quick wash bot hot was use powder or liquid and put 3 or 4 table spoons of salt inside with the towels doing this softens up the mould and should solve your problem.
after doing that wash cycle check and see if the towels come out smelling good or not,
if they do you need to remember that their is always a small amount of standing water sitting inside the machine at all times so if it is not going to be used for a few days then the best thing to do is to leave the door slightly open doing this will prevent the build up of mould due to their being air circulating.
let me know how you get on or if you need further assistance ok
good luck and you should have no problems after doing the above
Aug 24, 2010 | Kenmore HE2 Plus Front Load Washer
Our Clothes seem to smell after being washed, checked drawer and found lots of mould etc how do get rid of this problem, why does the drawer attract this mould? i wash reguarally.
its a comon fault,,,i would put in a strong vinegar into the drawer and do a rince with nothing in the washer first this will kill off any mould after that do a fuw rinses and then leave the door open after you use the washer to stop any more mould growing in it this also works on wood and walls too!
Jul 30, 2010 | Washing Machines
Kenmore front load washer emits foul smell
you can order some cleaner to take care of the smell from WWW.SMELLYWASHER.com
Jan 21, 2010 | Washing Machines
Hotpoint Washing Machine smells mouldy as has mould
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Jul 02, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Rubber door seal mouldy
Wouldn't normallyexpect a few mould spots to leave that bad a smell, so likely you've got two distinct issues.
Starting with the water trapped in the seal: Open the door and very carefully slip your fingers into the seal where the water is gathering (to stop your hand getting trapped between the drum and the outer casing, put your other hand inside the drum and push it up out of the way - just be careful not to let it spring back too fast).
At the very lowest point,of the space inside the seal, either at the very front or the very back (so tucked into the corner between the floor of the seal and it's front or back wall), you'll find a little drainage slot. Once you've cleared the inevitable blockage from this slot, your seal problems should vanish.
If the foul smell is coming from inside the machine, the problem is likely to be grey sludge inside the works of the machine. This is usually caused by modern detergents not being quite as good at working at 30 degrees as they claim to be. The answer is to run a cycle every now and then with no laundry, detergent, or conditioner in the machine, on the longest, hottest programme the machine will support. This should be sufficient to dissolve the rotting sludge and pump it away down the drain.
A.
Apr 06, 2008 | Zanussi ZWF1440 Front Load Washer
Washing Machines Logo
173 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
