Question about Refrigerators
REFRIGERATOR NOT WORKING BUT FREEZER IS
I have a refrigerator that is 16 years old and in good condition. Never have had a problem but this morning everything was warm and the freezer was cold. There was a little frost around the upper left back (damper or dumper). I removed the front and cleaned the condenser (filthy). It took all day but seems back to normal temp. Shoud I still have technician come out or do you think by cleaning condenser my problem is solved?
  • 4,070 Answers
The ice could be related to a defrost problem. Check the back wall of the freezer for ice buildup. The evaporator coils are behind it and if iced heavily will block the circulation of cold air.
Posted on Jul 01, 2009
Can a Miele fridge freezer with both sections warm, fans working, be repaired?
You mean it's not an auto-defrost model? It should be, no older than it is.
Sep 05, 2014 | Refrigerators
GE side by side gss25jepbb not cooling any longer, probably 10-15 years old
HI LISA.getting old.could be a no of things.try these simple checks1-is motor making noise.(compressor).if not is hot?2- condenser is it hot or cold3- any ice at all inside freezer?if yes defrost all and try.(could be defrost timer/heater/t/stat/fan)4-if NOice it could be lack of refrigerant condenser fanmotor.or motor .hope this helps otherwise call engineer.good luck.Ali
Jun 24, 2012 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Hi KitchenAid fridge - 12 years old This morning
If you have a frost buildup in the freezer section (could require you to remove the INSIDE back panel to check). If there is frost then you need to defrost the unit and then test the defrost system.
Here are some links to tell you how to troubleshoot each component: The defrost heater is easy to check with a ohm meter. http://www.acmehowto.com/howto/appliance/freezer/check/defrostheater.php If you have continuity, then it is good.
http://www.ehow.com/how_4504020_test-refrigerator-defrost-timer.html is instructions on how to test the timer.
http://www.acmehowto.com/howto/appliance/refrigerator/check/defrosthermo.php is instruction on how to test the defrost thermostat.
You should also check to make sure the the condenser coils are clean and that air flow is good over it. I.E. the fan is operating, and not a lot of debrie on or around the condenser coils.
Hope this helps.
Jun 15, 2011 | KitchenAid Refrigerators
The freezer isn't cold enough to keep the food frozen
hi there,
eventually 4 years service gaurantee have been reached,but defend how you use your refigerator you can still check the thermostat if working properly or it may need to replace,occasionally thermostat is the one controlling your freezer temperature it may be defective there are several way you can check this
by removing this but this should be done by certified
refrigerator tech.If you have the tech ability and you can do it or bring thermostat to service center have check this one,If the thermostst was good.Check the compressor condition if working at its maximum effeciency.this should be done by certifed tech.have a good day and please dont forget to rate me.
Feb 21, 2010 | Refrigerators
Ge side by side not cooling
it could be two things your compressor is shot .check what date you bought it if less than one year you call the store you got it from or G.E but the store you got from sholud replace with a new one dont let them send a service tech out
May 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
If your light inside does not light when you open the door you problem could be power related. Your description sounds as a power supply problem. Try moving the power cord to another outlet.
Apr 29, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
