Question about Sony KP-41T65 41" Rear Projection Television
Sony KP-46S17 First I can't fine this tv model. I plug the tv in but when I turn the tv on it makes a click noise. Then it goes to standby mode. It was made in May 1996 and I check the number a few times it is KP-46S17.
  • 4,402 Answers
Re: Sony KP-46S17 - Sony KP-41T65 41" Rear Projection Television Projection Televisions
Does the standby light blink?
Posted on Jan 22, 2008
0 characters
3 Points
Don't know where the fuses are on the Sony kp-53s25 1996 year. Tv won't turn on, makes clicking noise and then standby light flashes.
the first thing you can deduce is the main fuse is good. secound the power on relay clicks whick means the set is trying to come on. the standby light flashes... how many times what is its pattern this could be an error code that could point in the direction of the problem
Oct 15, 2010 | Sony KP-53S25 53" Rear Projection...
Sony Rear Projection TV - KP-46WT500 Screen went blank
When Sony TV gets problem it goes to standby as protection mode and LED start flashing.
Do you see standby light blinking?
There would be 3 seconds interval between blinks so count from pause to pause and let me know.
Sep 20, 2009 | Sony KP-46WT500 46" Rear Projection...
The standby/timer is flashing 6 times on my Sony KP-53HS30 TV
no the 6 blinks indicates a missing voltage. If your talking about a sony lcd KD or KE model you probably have a bad thermal fuse. You must also clean or change the Lamp fan so it won't blow again.
Apr 16, 2009 | Sony KP-53HS30 53" Rear Projection...
I have a sony KP-57WV600 Big Screen Rear projection television. The problem is this: When I first turn the tv on the picture is fine, than after it warms up- the screen turns red. What would the problem...
Let me know when TV warms up does it go to standby?
If yes, standby light would be blinking, let me know how many times it blinks?
And if TV does not go to standby mode, does picture remain with red tone?
Dec 06, 2008 | Sony KP-57WV600 57" Rear Projection...
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
10 flashing lights then 9
make sure it is 9 blinking it may be 10
Aug 15, 2008 | Sony KP-46WT520 46" Rear Projection...
Timer Standby light flashing No pitcher
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Power goes on than quickly turns off
Please post the make and model. Also, is there any blinking of the standby light?
Mar 18, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-41T65 41" Rear Projection Television Logo
125 people viewed this question
Top Sony Projection Televisions Experts
Steve Sweetleaf
Steve Sweetleaf
Jason Harris
Jason Harris
Are you a Sony Projection Television Expert? Answer questions, earn points and help others
