My air conditioning started doing some noises and got freeze. I called the technician and he put some gas. But after few days, the compressor stopped working. What could be the reason for this to happened?
  • 8,220 Answers
Posted on Jul 01, 2009
Panasonic mini split air conditioner css9nkua error code h99 what does it mean
12.11 Freeze Prevention Control 2
• Control start conditions
o During Cooling operation and soft dry operation ? During thermo OFF condition, indoor intake temperature is less than 50°F or ? Compressor stops for freeze prevention control
o Either one of the conditions above occurs 5 times in 60 minutes. • Control contents
o Operation stops
o Timer LED blinks and "H99" indicated
You may need the assistance of a technician. Service manual located here:
http://www.mcaair.com/docs/panasonicac/CS9NKUA%20CS12NKUA%20Service%20Manual.pdf
Apr 29, 2015 | Panasonic CS-S9NKUA Ductless Mini Split...
Maytag MSD2454GR
You may need to recharge the condenser unit.
Jun 16, 2008 | Maytag MSD2454G Side by Side Refrigerator
Sometimes when starting 2000 lincoln signature tc the idle will surge as this awful sound like someone blowing a conch shell ?other times w /do same while driving. Only way to stop noise is to push qu
the compressor that pumps up the air suspension does make a horrid noise, and if you can turn it off, like I could in my crown vic, just long enough to see if that is indeed the compressor making the noise you hear, then try that. My switch was located in the trunk.
Mar 21, 2013 | Cars & Trucks
The air conditioning suddenly stopped blowing cold. It just blows room temperature air. It was working fine and then all of a sudden a few days ago it stopped. I have tried to put the A/C on auto climate...
you should check if there is gas on the air system, if you say the compressor its engaged all time perhaps you have a gas leak or too much low pressure on the gas system, its recomended that this work is done by a pro, as it involves hazardous gases and delicate procedures.
Aug 09, 2010 | Ford Expedition Cars & Trucks
My air conditioner is not blowing out "cold" air and makes noise
The anti coolant is what is added to your radiator so that the water does not freeze when the temp goes down and damage your pump. hence do not confuse this with the air conditioner. When you put on the a/c the load noise could be the engagement of the solenoid coupling your a/c compressor to the engine. If you notice within the bonnet for the gas filling inlet there must be signs of cooling. if not check over the condenser filter on the glass window for any signs of gas or gas pressure , smoky means low gas but a good pressure of gas indicates good visiblity. If not there has been a gas leak and your whole a/c system needs a check right from the compressor to the condenser to the cooling coils inside the dash. The leak has to identified by a pressure check with air filled, check for blocks before the gas can be filled. The compressor pump pressure must be checked or must be overhauled, replacement of the O rings, and reset. I hope you got an idea to proceed and hope I could help. Good day.
Jul 22, 2010 | 2006 Chevrolet Aveo
Power on are compressor, hear buzz, but pump did not start .
if its just humming and not starting you may have a motor start capacitor on the motor thats bad and can't supply the starting voltage against the compressor
May 09, 2010 | Campbell Hausfeld 28 - Gallon Air...
Compressor doesnt run.
There is a pressure switch on the accumulator. The compressor cyles according to the low pressure reading at the accumulatror. If there is low refridgerent pressure the switch stays "OFF" and wont turn ther compressor on. Whan a system is low, there will be rapid cycling of the compressor, (on and off every few seconds). When the system is charged with the correct amount, the pressure is related to the temperature of the refridgerent. The compressors are common to leak. So it it doesnt leak, or make knocking noises, the compreesor MAY be good, but a pressure gauge will tell you if the compressor is good or bad. If you keep having to charge it, thats bad, and there is a leak. You will need to find and repair the leak, replace the drier (accumulator) , and recharge the system.
Nov 09, 2009 | 1997 Ford Explorer AWD
Knocking noise coming from Whirlpool Gold refrigerator
I also have a new Whirlpool Gold fridge (bottom freezer with French doors) and it was making a knocking sound. The knocking sound would start when the fridge kicks in and starts running to cool, and would last for about a minute or less and be a slow knock.
I called Whirpool customer service since it is new and on warranty. They sent out a technician and he said the knocking is from gas/air built up in the copper tubing for the freezer because the copper tubing is too cold, and when the fridge first turns on it forces the air through, making the knocking sound.
His "fix" was to adjust the copper tubing so that it is closer to the heat of the motor/compressor and heat of another copper line so that the cooler line stays warm so the air/gas doesn't build up. His fix worked slightly, but the fridge is still knocking, just not as bad and not as long - it knocks fast for about 5 to 10 seconds instead of a minute.
Going to call customer service again soon and see where to go from here.
Dec 15, 2008 | Refrigerators
Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Jun 26, 2008 | Amana AFD2535DES French Door Refrigerator
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
