Question about Samsung HP-R4252 42 in. Plasma HDTV
When i plug in xbox to hdmi input it reads unsupported mode
  • 304 Answers
The X-Box will not work on the HDMI input on that model. Either use the Component input or the Composit input.
Posted on Jul 17, 2009
My element 32' tv is reading no signal when i plug up my hdmi cable from my xbox to t
Make sure you change the input to the proper HDMI port on the TV!! Ck to make sure the cable is in all the way as well.
Dec 27, 2012 | Televison & Video
HDMI "unsupported" on konka tv
Xbox signals are not contactable with this Konka TV inputs.
Dec 19, 2012 | Televison & Video
I have a Jensen (JE1909ACB) 19 LCD TV Can't get it to hook up as a monitor on my desktop. It reply's unsupported mode.
Are you using the VGA port on the Jensen TV? What is your computer's OS?
The usual reason for the unsupported mode message is that the the computer did not recognize the TV as a monitor on boot up or that the previous settings were incompatible with the TV. (For example, if you previously had a CRT connected to the computer and used a refresh rate of 75 Hz, the TV can't handle the refresh rate. It needs to be set at 60 Hz.)
First turn off both the TV and the computer. Then turn on the TV and set it for the PC input (assuming you are using the VGA port). Next turn on the computer. If you have Windows XP or later, it should find the TV and set the resolution without any input. (If it doesn't, use a different monitor and set the resolution to 1366 x 768 and 60 Hz. Then try again.) If you used the HDMI port, try the VGA port. This TV doesn't understand a computer signal over the HDMI port (only set top boxes).
I hope this helps.
Dec 08, 2011 | Car Audio & Video
My xbox 360 wont work with an hdmi cable all i get is sound and the screen just says unsupport
that normally means that the TV doesn't support the software version...need to contact either the tv makers support number, or Xbox.com/support, and explain your problem.... maybe there is a setting on your TV that can change the setting for your hdmi input
Feb 26, 2011 | Microsoft Xbox 360 Console
How to make it connect to an xbox 360
Easy, You plug either the HDMI cable into one of the HDMI inputs and then plug it into the XBOX 360. If you are using either the component or composite cables then plug them into the proper color coded input.
Dec 10, 2010 | Dynex DX-LCD37 TV
Hi, i have a flx-2211b element electronics tv and I have a xbox 360 hooked up to it through a HDMI cable but the tv says unsupported mode. what do i do to fix it?
I have the same problem with my 360 i am just going to by a new tv i cant find the remote code. or any thing and the hdmi port don't work that's my answer this TV sucks and it is ****..
Jan 07, 2010 | Element Electronics FLX2211B 22 in. LCD TV
My xbox 360 elite has no picture, I'm using the HDMI cable and the message I get is unsupported signal - any clues please
there is a switch on the av cable that says tv or hdmi be sure the cabel is selected to hdmi. or try to check all that chanels that that an input in them
Dec 15, 2009 | Microsoft Xbox 360 Console
Keep getting unsupported mode message after hooking up xbox360 using hdmi cable. can anyone tell me how to fix this.
It is complaining because it cannot support the resolution thaat the xbox is feeding it, what is the TV maximum resolution it can display?
Dec 13, 2009 | Televison & Video
Hdmi - out of range
If your hdmi cord is good, and you are going from xbox to tv via hdmi , make sure you have your input on input 1. Hdmi ports are usually by default set to work in the first input of any tv or monitor.
Apr 12, 2009 | Televison & Video
Samsung HP-R4252 42 in. Plasma HDTV Logo
414 people viewed this question
Jerry Greenberg
Jerry Greenberg
