Question about Epson Stylus CX4800 All-In-One InkJet Printer
Printer cx4800 Hi dear , I just bought this printer , but because th ink is expensive I try to refill it by my self I had some ink after I review how to make a hole in cartage and everything with the chipreseter . the printer and screen and resetter works well and it shows all of them full , and printer act like printiong something but seems like the ink is not the right ink or for some reson after many many times doing head clening the way manufacture telling to do , still doesn't print any thing do you think is it sensetive with the ink and it has to be same T0601 for black and T0602, 0603, 0604 for colors thats whay . any advise I can do refill please help me.thank you
  • Epson Master
  • 1,113 Answers
Inks aint Inks, buy epson cartridges and hope that the print head has survived the invasion, will probally need a few more cleans but with good ink. No Promise on survival.
Posted on Nov 09, 2007
Hi I bought a lexmark S405 and when my ink finished, i decided to refill the black catridge but the print wont print unless i buy a new catridge which is expensive than buying a new printer. I wanna...
The Lexmark S405 printer requires all cartridges to have ink in them to continue printing.
The 100/100XL cartridges are not licensed to be refilled. You can, however, refill the 100A or 100XLA cartridges available on the Lexmark website at You should be aware that a refilled cartridge will not be able to report its ink level, and you might not get the print quality you expect from ink that is specially formulated by Lexmark to pass through microscopic nozzles at extremely high temperatures.
Sep 20, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Empty ink
According to your problem it seems your cartridge has been damaged or choked so change your cartridge. Because some times when we use refilled cartridge, Ink goes dry and printer's sensor can not sense the ink.
Feb 23, 2010 | Lexmark X2600 InkJet Printer
Epson CX4800 cannot clean the print heads
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
May 27, 2009 | Epson Stylus CX4800 All-In-One InkJet...
The ink does not get recognoised by the printer but it is the exact one that was in hear before is there any way of refilling the original one?
Refilling the cartridge (actually it's an ink tank) won't solve the problem. Each ink tank has a minute electrical circuit (a chip) that allows the printer to recognize the ink tank. That is where the problem is. If the printer has worked successfully before you replaced the ink tank, then I would presume that the ink tank is defective. Return it for a new one and install the new one. That should do the trick.
Mar 10, 2009 | Epson Stylus CX4800 All-In-One InkJet...
When you try refilling your ink cartridges, you are taking chances that something may go wrong. I would search the web and purchase re-manufactured ink cartridges, which would be less expensive than the new ones from Lexmark.
Please remember to rate all users who assist you for free :)
Sep 20, 2008 | Lexmark X5470 All-In-One InkJet Printer
Replaced cartridge, unrecognized
Try removing the cartridges and unplug the printer.
Plug it back in and try to install the cartriges.
Dec 31, 2007 | Epson Stylus CX4800 All-In-One InkJet...
Epson stylus cx4800 won't print
Hi, reason we sell epson printers are they are the cheapest to run, but they do get alot of problems with the print heads, if you change from using refill ink kits to compatible ink cartridges you would not have to reset the chip each time, otherwise you will have to change to a more expensive to run printer like the HP, or Lexmark, lexmark is the most expensive for cartridges but it has the print heads built into the cartridge and not the printer itsself, epson only have the chip on the cartridge.
You can use the refill kits on most HP & Lexmark without having to reset the cartridge all you need to do is refill it.
but for every 3 for example you may have to buy a new cartridge which will be more expensive, ie if you get lines through your print, as the print head will probably get blocked on cartrdige.
Happy New Year
Dec 10, 2007 | Epson Stylus CX4800 All-In-One InkJet...
Cx4800 red not printing
I had the cartridges refilled the yellow and red ink. After I renew two T0604 and T0603 ink. It doesn't work. any idea why? Please tell me why and show me how to do it. Thanks
Nov 19, 2007 | Epson Stylus CX4800 All-In-One InkJet...
Black ink cartidge
If a black cartridge will not print, with no error messages, it is probably th printhead. Clean it with proper cleaning solution. Refilled ones if done yourself or by someone else, can also have air bubbles, Try blowing down refill hole with tissue under the cartridge to stop ink spills. Also, if you press a folder non scented wipe under the cartridge firmly, you should get a solid little black line or impression. This will tell you if the ink is getting down ok. Try reprinting.
Oct 13, 2007 | Lexmark X4270 All-In-One InkJet Printer
Epson Stylus CX4800 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
