Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Flapper in Ice Chute broke the mount it adheres to on the door.
The Flapper that flips open (When dispensing ice) and closes the hole in the freezer when your not dispensing ice somehow broke off the one side of the freezer door it mounts to. It was cocked sideways so I removed it and the ice maker works but the whole area around the ice tray auger is icey i guess because of the warm air getting in then freezing the water thats melting. What should I do?
  • 4,070 Answers
You can replace the broken parts.Diagram 4 shows your parts. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5134017
Posted on Jul 01, 2009
Why are the cubes not breaking apart when dumping from the tray?
It is over-filling and the cubes are fused together... If the fill is adjustable, lower it, but you may need a new water valve... Frigidaire Water Inlet Valve 242252702
Jul 31, 2014 | Frigidaire FFSC2323LS 22.6 Cu. Ft....
How to install spring on french door flapper/divider for Samsung RF266
On mine one end of the spring broke off in the hole on the door. It was on top of the hinge so it looked like a pivot pin. I found that this was the second hole for the spring. I pushed the end of the new spring up under the hinge and popped the broke piece of old spring out. Now I could see the 2 holes. You then need to put the spring into each hole. The hole on the flap also needs a white plastic sleeve if that is missing. that goes on the end of the spring and fits into the flap hole. Then the trick part is understanding how the spring works? If you put both ends of the spring in the holes and shut the flap, it now stays in position to close and be flipped open by the guide that swings it open to seal.
Good Luck.
Feb 03, 2014 | Samsung RF266ABRS Bottom Freezer...
How do you remove the face plate off of the ice/water controls on the outside of the freezer door? The spring came off the flapper door that covers up the ice delivery hole, nothing has broke, but I need...
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Sep 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Hotpoint ice dispenser door not sealing
clean with white vinegar to remove lime deposit.
flapper may have got bent, bend back or replace flapper.
Sep 24, 2009 | Hotpoint HSS25GFP Side by Side...
Ice dispensor
Make sure that the "flapper-door" closes about 3 seconds after the ice dispenser button is released. Mine had a habit of catching and staying OPEN. This allows warm air to enter the dispenser / freezer compartment causing your problem.
If it is stuck you have to take the dispenser apart to loosen / lubricate the flapper door cam to allow for free movement.
This is the worst ICE system I've ever seen for a variety of reasons.
Jun 06, 2009 | LG LSC26905TT Side by Side Refrigerator
Ice Dispenser "Flapper" is loose--How does it reattach?
the plastic arms that move the flapper door open and closed are broken. I had this happen to me some months back. You will need to buy a repair kit from your local dealer. Explain what is broken and they can look up their part/kit number. You can't buy just the plastic door. Mine cost about $30 but was worth the price of getting my ice maker dispenser operating again. Very minor mechanics required to open this portion of the mechanism. Mostly some removal of screws and a spring or two. Good luck.
Apr 14, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Ice flapper on door stays open after dispensing ice.
Look closely at the flapper to be sure that it doesnt have a little ice or other "stuff" on it. Then look carefully at the sides of the opening to be sure that they clean. Finally you can spray the hinge area with a little PAM or other no-stick cooking spray
Feb 20, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer side has icing problem
check to see if the flap for the ice maker is open and or in need of cleaning, also look at the gaskets on the unit. Put vaseline on them if they feel brittle and it wilkl rejuvinate them.
Feb 01, 2009 | GE GSS25JFM Side by Side Refrigerator
Ice dispenser chute
most flaps have a solinard that opens and closes the flap,if you can replace or get in there to lube it you should me ok,let me know more-mike
Sep 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
329 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
