Question about Kyocera Slider Cellular Phone
Koycera sonic slider cell phone
I am trying to transfer music files from my computer to phone, my computer is not reconizing phone at all how do you drag and drop if you don't have anywhere to drag to.
2 Suggested Answers
  • 15 Answers
SOURCE: kx5 (slider sonic) from Virgin Mobile USA
You can't save ringtones on your phone. They have to be purchased from virgin mobile. Try or go on the web on your phone. It has a direct link by a one-touch button.
Posted on Mar 15, 2008
  • 226 Answers
you cant transfer ringtones to your phone using cable, you need to download that ringtone from virgin mobile website, or through your phone menu go to VXL
Posted on Feb 06, 2010
0 characters
1 Points
How do i transfer music from my pc to my nokia 5230 using bluetooth
Hi, Not all cell phones come with special software to transfer photos, music, video and other file formats from your computer to your phone. In fact, some cell phone providers desire that you purchase this software separately and make it difficult to transfer music any other way. However, most users can typically hook their cell phone to a computer with a USB cable and transfer music to a cell phone as if it were an external drive, such as a USB stick or an SD card. Note: This process might not work with all cell phones.
Connect your cell phone to the computer using the USB cable.
Wait for the computer to recognize your cell phone as an external drive. If a dialog box does not pop up with the name of your cell phone within a few minutes, open the Windows Explorer folder and navigate to the external drive in the left pane. Sometimes the name of the drive will show up as "Removable Disk."
Open the music folder of your cell phone. In some cases, it might be under a "My Media," "My Music" or similar folder.
Drag and drop the music files into their own folder under the cell phone's music directory. This way, it should be convenient to find the files once they're on the phone. Wait for the files to copy completely.
Disconnect the cell phone from the USB cable. If there is a Safely Remove Hardware icon in the bottom right corner of your taskbar, use this utility to safely remove the drive.
Tips & Warnings
If your cell phone supports an SD or micro SD expansion card, transfer music onto this card using the above method instead of transferring music directly to the phone. This way, you don't hog space with large music files and slow down the performance of your phone.
According to Simple, sometimes a USB connection icon will appear in the window of certain cell phone types when you connect. In some cases you might need to tap this icon to confirm the USB data transfer before you can begin moving files to the phone.
May 23, 2011 | Cell Phones
Hello, I own a iPhone 3G and I first had the problem a little that the sliders weren't working. Now it's worse i can't get anywhere because my sliders don''t work. I resetes and i did the home and power...
Try to restore your phone using iTunes.
That usually does the trick
WARNING !!! You will lose all Music/Apps/Texts/Contacts/Calendar events
So go FILE ---> Transfer Purchases to backup all purchased Music and Apps
Jan 01, 2009 | Apple iPhone Smartphone
No software cd with my camera phone is there any other way to transfer pictures onto computer with just the usb cable?
You will have to have the internet on your phone and e-mail to yourself to your personall computer..I did try to do that same thing but that was the only solution I found that would work. Hope that info helped.
Jul 15, 2008 | Kyocera Slider Remix KX5 / Sonic Cellular...
MP3 Player
I had to format the card then download the music again
Apr 07, 2008 | Kyocera Slider Remix KX5 / Sonic Cellular...
Music file transfer issues for sony ericcson w850
bert - try another usb port
guest - reformat the card
guest -
Mar 17, 2008 | Sony Ericsson W850i Cellular Phone
bluetooth or infrared
bluetooth is the latest application use to transfer data or files it range to other bluetooth device for about 2 meters up away to other deices(make sure both bluetooth is open before you send anything from your files to another) just click the option click send pop-up will via bluetooth then send it thats all.....
Mar 10, 2008 | Kyocera Slider Remix KX5 / Sonic Cellular...
Bluetooth won't transfer
how can i pass music form a other cel phone
Feb 25, 2008 | Kyocera Slider Remix KX5 / Sonic Cellular...
MP3 Player freezes
Before transferring your music into it's phone; in it's current location, right click on the white background, go to view and then click on details. Now you should be able to see more detailed information about your songs. The next thing you should do is right click on the on gray bar column where it defines the name of your song, the artist name, and the size, etc., etc. Right click on the song you want to transfer over to your phone. Song names cannot include any symbols for it will cause your phone to freeze as you have mentioned. I was once in your situation. You can either do it this way or rename your music files with Itunes or any other program.
Feb 17, 2008 | Kyocera Slider Remix KX5 / Sonic Cellular...
Kx5 (slider sonic) from Virgin Mobile USA
Dec 05, 2007 | Kyocera Slider Remix KX5 / Sonic Cellular...
Kyocera Slider Cellular Phone Logo
67 people viewed this question
Top Kyocera Cell Phones Experts
D. E. Hev
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
