Question about Craftsman Garden
Lawn trimmer revs up and dies - Craftsman Garden
WHEN PUT IN FULL RUN POSITION IT STOP
Posted on Jul 12, 2009
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jul 02, 2009
  • Jim Parker
    Jim Parker Jul 06, 2009
    Did this solution solve the problem?
    Jim
Was running great but now won't idle, even at full revs, will just die. Very frustrating.
maybe gas vent is clogged and carb starved for fuel. open gas cap for a second then try restarting
Dec 15, 2015 | Husqvarna Garden
Will start and idle,but give it gas and it dies.
Hi Tammy:
Make sure the air filter is clean.
Check the muffler. Sometimes they get clogged with carbon and the unit will idle but dies when you try to increase revs.
May 04, 2015 | Craftsman Gas Mini - Tiller/Edger
Poulan te450 xl
Probably the metering diaphragm, or the low side of the carb needs adjusted counter clockwise in 1/4 turn increments.
Jul 10, 2014 | Poulan 17" T&E Gas Trimmer
Engine starts then quits
does it have a fuel filter, or air? If it does make sure they are both clean and free of debris as priming will force fuel up line but will die as soon as its burned out
May 30, 2010 | Craftsman 25cc Gas Line Trimmer
It runs normally at high revs but dies on idle
the units came out with EPA carb's some have idle screw adjustment and preset high jet, or the other way depending on the unit. try and change the fuel, use only high octane fuel for 2 cyc no ethanol with fresh oil mix, run for about 5 to 10 min's. if your carb has adjustment screws set your low side idle screw but still change the fuel.
Sep 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Lawn Trimmer wont reach full revs.
you might want to check the magnito for rust build up.
it also wouldn't hurt to check the float or maybe even the valves.
since you adjusted the idle and mixture ur probly gonna have to adjust them again to get them back where they should be especially if rust build up on the magnito is the cause of your problem.
it wouldn't hurt to check the fuel filter either.
Jul 27, 2009 | Troy Bilt Tb70ss Gas Trimmer
Lawn trimmer runs but won't rev
You need to clean the carburetor. Remove & disassemble. Use a Den Tek Brush,
(http://www.shopping.com/xPO-Lustrasilk-Lustrasilk-Cholesterol-Shea-Butter-Mango-20Oz-Bonus), to clean small portals in carb. Spray carb. with carb. cleaner. make sure the small screen in carb. is free of debris. Reassemble and start. If this doesn't work, buy a carb.kit and replace the needle valve, gasket(s), small screen, & diaphragm.
Jim
Jun 06, 2009 | Craftsman 25cc Gas Line Trimmer
Cannot rev to high speed
Remove muffler and check cylinder and muffler for blockage.
Mar 19, 2009 | Garden
Garden Logo
56 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
