Question about Cuisinart DCC-1200 Coffee Maker
Water not dispensing when in brew mode - Cuisinart DCC-1200 Coffee Maker
  • 85 Answers
Hello allydill,
I recently had this similar problem. Try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 08, 2009
I have a saeco super automatica Leaking water
Take the brew unit out when the machine is off and cold. With your finger, check the well next to the large gear on the inside of the machine. This is the gear that fits in the back of the brew unit when it is in place. That well may be clogged with fine coffee grounds and some mildew build up. You might notice that after brewing, very little water will has been flowing into the drip tray. Take a Q-tip and push it through the hole at the bottom of the well to remove the coffee ground buildup. The excess water after brewing will flow through normally now and not behind the brew unit.
Mar 02, 2017 | Saeco Coffee Makers & Espresso Machines
I have a bunn coffee pot that i purchased at KOHLS The serving pot leaves a mess from dripping everytime i go to . please replace the serving pot. Kohls WILL NOT REPLACE TOLD ME TO CONTACT YOU.
* Most decanters are made of tempered glass and unless cracked it should not leak.
* Make sure the two pots you are using (one to pour one to brew) is the same size. Check by filling one then pour into the other. If they don't match then get a matching one.
* Most overflowing pots are caused by over filling brewing tank. This can be caused by re-pouring additional water into the brew tank. (automatic brewers may have a leaking water valve - call your vendor for service)
* Partial brewing (taking coffee from a brewing pot) and then putting in more water.
* Removing the pot BEFORE it stops dripping. It leaves a puddle of coffee on the warmer plate
*Over filling the water tank. Most times the extra water will spill out the back. But some may overflow into the basket area then the warmer plate.
* Follow the MFR brewing instructions for filling.
* All brewers should stop water drips after brewing. If you get a constant drip AFTER brewing then have the brewer checked or replaced. Call your vendor.
Aloha, ukeboy57
PS: I've noted that you don't mention the brand nor model of the server you got from Kohls so I'm guessing it might be a dispenser or even a bunn dispenser which is different from a decanter as it has a serving spout. You find these at banquet halls where it's dispensed from a small faucet. You can find similar faucets from bunn.com or most restaurant supply stores as it's a very common item. Amazon.com has them too. the part tat leaks is the rubber boot or worn spring. best to buy the whole faucet and keep the old one for parts as needed. amazon link:
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=coffee+dispenser+parts+faucet&rh=i%3Aaps%2Ck%3Acoffee+dispenser+parts+faucet
Feb 14, 2017 | Bunn Coffee Makers & Espresso Machines
Grinder works fine. Water pump sounds normal but no water flow when in rinse mode, brewing coffee or in hot water dispense mode. Something is clogged???
Run a simple cleaner through your system without coffee. Pour in white vinegar 4:1 ration. Brew this maybe up to 3 times. Should clean your clog.
Feb 02, 2016 | Saeco Magic Comfort Plus Espresso Machine
Keurig B150 - continuous water dispensing
Their appears to be a scale build up inside the valve that dispenses the water when demanded. This is an electrical solenoid much like in fridge water dispensers but smaller. The scale is not letting the valve close completely after dispense. On a regular brewer running vinegar thru the machine a couple of cycles will usually dislodge the obstruction in the valve. If you can manually add water to the brewer, you should add the vinegar instead to clean the valve. Otherwise you may have to disassemble locate the valve and soak in descaler, or vinegar.
Jan 11, 2015 | Keurig Coffee Makers & Espresso Machines
Water dispensing from stem wand instead or brew nozzles
Overfill problem, could be leaky inlet valve or manual fill lever stuck partly on. Franko (ems.coffee768@gmail.com )
Jan 03, 2014 | Saeco Talea Touch Plus Espresso Machine
Machine will not dispense water at all,leaks behind dispenser, doesn't brew coffee
Hi. Great machine. You have a brew unit blockage. Remove the brew unit and clean. It canbe striped down and cleaned, but does requirer a bit of expertise in stripping them. Dazza REPAIRER
Sep 23, 2011 | Saeco Royal Digital Plus Coffee...
Slow brewing
The coffee maker has three contributory factors for brewing experiences. First, putting enough water in container prior to brewing is expected to dispense in to coffee capture cup. Second, installing the component parts after inserting coffee leaflets should not hinder brew seepage into the cup. Third, allowing enough time for the brew to dispense is a requisite means to coffee impressions. Furth, coffee leaflets require appropiate numbers inserted at the container area lest the machine takes time to sock and dispense. However, refer to the device user guide for appropiate manufacturers instructures to user as expectations during brewing. Also, refer to the user guide to ascertain any conditions that may be signs of damage preventing fast brewing.
Jan 22, 2011 | Oster HDX23 12-Cup Coffee Maker
Gaggia syncrony logic not dispensing water. Just drops pods and red light comes on. have cleaned brew unit shower screen and dispenser tube. still have the problem
Lubricate the brew unit with a food safe grease this should help.
The brew unit becomes stiff and fail to load up fully this stops the water being dispensed
Jan 18, 2010 | Gaggia Syncrony Logic 74884 Espresso...
No water for brew
Remove the brew group and clean the shower screen at the top. This might be blocked.
Jul 13, 2009 | Spidem Trevi Anthracite Espresso Machine
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
206 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
