Question about Hotpoint RGB745 Gas Kitchen Range
Oven doesn't work right
my oven not working right. i put a new glow bar and gas vale on it now
it is hard to light when it does light it sends flames up the sides of the oven.
help charles
    Problem Solver:
  • 9 Answers
Hi the gas line was clug , at the back side of oven clean the nozzle w/ fine wire.
Posted on Dec 25, 2007
Kenmore gas oven 790.78804501 takes an hour to get to 400 degrees
When my oven would not maintain the proper temperature, the thermostat was replaced.
Jul 02, 2016 | Kenmore Ovens
Oven shut off and won't re-light
defective glow bar or bad safty valve. But if the glow bar does not light at all, most likely it will be a bad glow bar
Jul 09, 2014 | Summit WNM4307KW 36" Freestanding Gas...
GE JGSP28SEN4SS bake and broil do not work
Gas ovens need a glow bar igniter to operate as a safety feature. if it is broken (and they do go out often) nothing will work. (it stops the gas from coming into the stove if it is broken, (its purpose light any gas and to send a signal to the valve that (yes I'm on and you can keep sending gas) they are always on when the oven is on they never stop glowing... until you turn off the oven.. they are very visible in their glow.. in most oven you can see them like a red hot iron glowing in the oven before it lights the gas.
in the diagram #316 is the igniters
This is for your info only call the gas company...or a qualified gas oven repairman. Gas ovens can be dangerous.
If the glow ignitors are working (both) then it could be a valve issue but they need a certain amount of resistance from the glow bar to open. (sometimes even if the glow bars are glowing if they are getting old the resistance is not enough to open the gas valve.)
Oct 13, 2013 | GE JGSP28SEKSS Stainless Steel Gas Kitchen...
Gas oven not getting hot - glow bar works but no gas to burner
This happens when an oven igniter (glow bar) is bad. The igniter must draw enough amps to turn on the gas to ignite the flame. If you have a square shaped igniter use this part#5303935066 If your have a round shaped igniter use part#wb2x9154. These igniter will pretty much work universally for most gas ranges or ovens.
  1. Remove the racks
  2. Unplug unit
  3. Take out the screw holding the bottom pan
  4. Remove screws holding manifold where igniter is attached
  5. Remove manifold cut wires about 2in link from igniter and clean leads.
  6. Unscrew and remove igniter
  7. Replace Igniter with new one and fasten onto manifold
  8. Clean wires and screw on ceramic nuts to wires
  9. Tuck wires back and Reinstall all components
Test your new igniter. You might notice it taking a little longer to light up but that is okay.
Please let me know if this was helpful by rating me a 4.
Thanks so much have a great weekend.
Dec 12, 2010 | Frigidaire Gallery 30" Self-Cleaning...
Magic chef self ignitor top,, how do u get the oven to work.. is it self ignite too. i turn on oven ger a glow in the oven,, dont know the model ,,older stove. good shape. bought house with gas stove...
If the glow bar is glowing and the oven doesn't come on in about 30 - 45 seconds.... it probably is the glow bar that needs to be replaced. BUT it could be the oven valve. Usually it is the glow bar.
The glow bar is wired in series with the oven valve and even if it is glowing it may not be sending the correct voltage through to the oven valve. To change the glowbar... unplug the appliance, unscrew 2 screws holding the metal bracket to the burner and remove the ignitor. You can cut the 2 white wires going to the ignitor and use ceramic wire nuts with the new ignitor.
Aug 10, 2010 | Magic Chef 31000 Gas Kitchen Range
GE HotPoint XL44 Gas Range Model RGB528
My bet is that the broiler ignitor has been out for a while and you just never knew it...
I would change the ignitor as a first try to fix it it is themost common failure..
Apr 27, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Our glow bar lights up when gas oven is turned on, then the gas comes out, but it takes a long time to lite the gas resulting in an explosion inside the oven. Or with too much gas filling up the kitchen....
Typically the issue here is a weak glow bar (hot surface ignitor). When they weaken they open the gas valve slowly and it takes a bit for the ignitor to light up the oven burner.
It is a safe bet that you need to replace it.
Apr 20, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens wont light , glow bars work both ovens wont light
the problem is the ignitor or both of the ignitors are not working properly remember just because they glow doesn't mean they are good they have to draw at least 3 amps to open the gas valve if not they will glow all day let me know how you make out
Nov 12, 2008 | Viking VGRC605-6 Gas Kitchen Range
Can i swap the broiler glow bar for the oven glow bar
changing glow bars are not recommend the bake and the broil have different ohm values and probably wont work
Jan 01, 2008 | GE Profile JGS968 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
102 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
