Question about NRS Hoveround MPV 5 - Used Power Wheelchair
Chair will move forward and backwards OK but either will not turn or will go around in a circle very sharply
  • 32 Answers
One of the motors is bad or has bad connection. try raising the chair so the drive wheels are off the ground (free-wheel) turn power on, push joystick forward and watch for drive wheels to turn. the one that wont indicates a bad motor or connection.
Posted on Jul 13, 2009
I have a shoprider steamer. It wants to turn right when I push the stick forward or backwards. When it does go forward, there is a kind of jerking to it. If goes left fine. On and off problem.
The free wheel levers have got to be in drive mode. if one is in drive and the other side is not then the chair will try to go in circles. So if the right side free wheel lever is not in drive position then the chair will try to drive to the right because the right motor is not turning the wheel. The wiring to the right motor may have become disconnected.
Oct 10, 2016 | Shoprider Health & Beauty
Can you stop a task chair from spinning?
There might be two levers on the underside of the chair; one to adjust the seat height that moves forward and backward, and one that locks the chair from spinning, pushes in or out. Push in to lock.
May 01, 2014 | Health & Beauty
Why are the lights blinking and it won't go
read manual,lights flash when in security mode,everyt model has a unlock procedure with the buttons on the joystick control.
Jan 23, 2013 | Pride Mobility Jazzy 1143 Power Chair -...
What are the symptoms of a worn out half shaft on a 0 intrepid es?
It will click and make awful sounds when turning sharply at low speed.
Jan 19, 2011 | Dodge Intrepid Cars & Trucks
The charge indicator lights flash left to right..when moving joystick the chair does not move.
chair is locked out. turn on then push joystick forward till it beeps then pull backward till it beeps then it is unlocked
Jun 15, 2010 | Invacare Pronto M51 Power Wheelchair
Chair stuck in upright position,will not go down but the back of the chair moves backwards and forwards
Hard to say definitively without know the make and model of your particular chair but if your chair is anything like mine the same lever underneath it that makes the chair go up and down will also fix this: the lever can slide left and right as well as being flipped up and down. That's what always fixes it when it happens to my chair anyway.
Jun 02, 2010 | Mobility (EKEYP0001-R) Keyboard
Characters walk around in circle and move backwards .Just bought Modern warfare 2.character won't walk forward only backwards and in circles.same problem in Grand theft Auto Games. My console is xbox 360...
It sounds like you have controller issues, try using another controller and see if they still walk circles. If the joystick is not in the centre home postion when you turn on console it will read left/right/etc as the centre. Also try using a different battery in the controller, mine has the same charging issue and i found that jiggleing the plug and play cord can sometimes turn the charger cord from green(or nothing) to red. Good luck..
Nov 16, 2009 | Microsoft Xbox 360 Console
The power indication display is flashing with all colors visible.
The flashing will come on if the chair is in neutral or if the charger is still plugged in when you turn it on. Place the chair in neutral (freewheel) by shifting the levers out, then place firmly back into drive.
Unplug from the charger and it should fire up. Sometimes, the chair will also go into "sleep mode".
Check your owners manual for this. Note, some have sleep mode potential but it's not in the manual, and if someone inadvertantly hits the right series of motions with the joystick, you can inadvertantly put it to sleep. Try turning the chair off, wait three seconds and power back up, then immediately press the "horn" button. This wakes up most of them. Others you need to power off, turn back on and then move the joystick forward, backward then forward again.
Good luck
Jun 23, 2009 | Electric Mobility Power Electric Scooter...
NRS Hoveround MPV 5 - Used Power Wheelchair Logo
196 people viewed this question
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
